BFG TA KO 285/65/18 on Chrome XD Monster with 3" Lift
Old 02-15-2011, 05:44 PM   #21
jrgaither1 [OP] jrgaither1 is offline
jrgaither1 is on a distinguished road
jrgaither1's Tacoma Gallery
All:
Just updated with front window tint. Makes a big difference.
FYI: $60 in TX to tint.
After some time w/o lift. I have decided to lift it at least 2 inches.
But first, I want add bed cover.
Old 02-15-2011, 06:02 PM   #22
LEX LEX is offline
LEX is one of the sharper tools in the shedLEX is one of the sharper tools in the shedLEX is one of the sharper tools in the shedLEX is one of the sharper tools in the shedLEX is one of the sharper tools in the shedLEX is one of the sharper tools in the shedLEX is one of the sharper tools in the shedLEX is one of the sharper tools in the shedLEX is one of the sharper tools in the shedLEX is one of the sharper tools in the shedLEX is one of the sharper tools in the shed
LEX's Avatar
LEX's Tacoma Gallery
I thought you did some trimming? What exactly did you glue?
Old 02-15-2011, 06:33 PM   #23
Ulysess:
Front wheels
Rear fender well
Thin plastic
Tire rubs due to plastic not secured to fire wall.
Sticks out about 1/2"
Glued it down to hold it back.
Reduced rub to minimal.
Minimal rub broke glue loose.
Now rubs on full turns.
Will now try to use metal screw into fire wall to hold down plastic.
Old 02-15-2011, 06:44 PM   #24
Sorry fogot to show trim spot.
Old 02-15-2011, 07:33 PM   #25
LEX LEX is offline
LEX's Avatar
Looks like you aren't rubbing much. Have you looked into Bilstein 5100 shocks and Eibach springs? If a small lift is what you want and ride quality is a concern, you should look into it.
Old 02-16-2011, 06:57 AM   #26
Bash Fabriction & Off-Road
01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed
01Tac0ma's Avatar
01Tac0ma's Tacoma Gallery
x2 You will love em!
Old 02-16-2011, 10:22 AM   #27
zimm52 has a brilliant futurezimm52 has a brilliant futurezimm52 has a brilliant futurezimm52 has a brilliant futurezimm52 has a brilliant futurezimm52 has a brilliant futurezimm52 has a brilliant futurezimm52 has a brilliant futurezimm52 has a brilliant futurezimm52 has a brilliant futurezimm52 has a brilliant future
zimm52's Avatar
zimm52's Tacoma Gallery
looks sharp!
Old 02-16-2011, 04:25 PM   #28
trd sport is on a distinguished road
trd sport's Tacoma Gallery
Did you end up going with the 285/65/ 18 or the 285/60/18? I know the 60 will fit with minor rubbing, but according to your thread 65's are the same minimal rubbing?
Old 02-16-2011, 04:54 PM   #29
TRD Sport"
Seeing is believing:
BFG TA KO 285/65/18
Black KMC XD Monsters
Old 02-16-2011, 05:17 PM   #30
All:
I preferred the 5.7bs X +18os to the 4.5bs X -12os. See how it tucks up under the fender flare better.
Old 02-17-2011, 12:28 PM   #32
LEX LEX is offline
LEX's Avatar
Did you screw that in, yet? I'm curious as to how it turns out.
Old 02-17-2011, 12:36 PM   #33
Still not worthy!
Sawick has much to be proud ofSawick has much to be proud ofSawick has much to be proud ofSawick has much to be proud ofSawick has much to be proud ofSawick has much to be proud ofSawick has much to be proud ofSawick has much to be proud ofSawick has much to be proud of
Sawick's Avatar
Air Force: Security Forces
Sawick's Tacoma Gallery
60/65
I'm thinking of going 285/65/18 or 275/70's on my truck as well. I'll probably get the 5100s and TSB for my lift. I really don't want to cut a whole lot of stuff under my truck, I wonder if adding a 1.25" spacer might help? Maybe sticking with 265/70/17's would be better and get me the same look with the spacer anyhow.. I wish I knew, lol.
Old 02-17-2011, 02:07 PM   #34
Smile lift?
So correct me if I'm wrong, you fit 285-65-18 with 5.71bs and +18 of on your truck with no lift and minor trimming.... Please let me know because I will be all over this quickly.
Old 02-17-2011, 06:12 PM   #35
Sawick/TRD Sport:
Yes.
Just:
Tires: BFG 285/65/18
Wheels: KMC XD Monsters 5.7bs +18os
Minor Trim: On Hard Plastic Rear (They will do it for you) with knife or small hack saw. Don't sweat it - no one will ever see it. The cut starts at about 1 inch back and at 45 degree angle to 1 inch in the front of plastic piece. See pic above (Lightning bolt).
Tuck: Thin Plastic Fender Well (Glue Will NOT Hold) Must use metal screw. Option - You can cut the thin plastic, but I preffered not to.
That's it. Your done. Drive home looking like a champ!
You will still get minor rub 1% of the time on thin plastic piece (when making full 90 degree turns up into driveway or backing down out of driveway). A small annoyance but nothing major. Again, I will state - It is my opinion (since a do not have a lift) that even with a 2-3 lift, you will experience a minor rub on the front fender well on turn in and on rear on turn outs.
Do not fear. Once you do it, you will be glad you did. If you dont like the minor rub - do cut of thin plastic and/or lift later. Try w/o lift first then decide. Good Luck.
Old 02-17-2011, 06:54 PM   #36
Still not worthy!
Sawick's Avatar
I must have read through 20 threads on here about people with 285s on their ride. Some had to chop and cut tons off even after a 3" lift to stop rubbing. Then others like jrgaither1 can slap them on and only have to trim a little bit... I think this is what makes it so hard for me to figure out.
Old 02-17-2011, 07:05 PM   #37
All:
Here is the best comparison I can make to the difference in 4.5bs to 5.7bs.
My 5.7bs is first pic.
Next 2 are TW member (se7en) Copper Zeon LTZ 285/60/18 with 4.5bs
Note: My 5.7bs does splash the side. So, my opinion is the 4.5bs must really splash side and throw rocks and debris on the sides. In the end, I personally just liked the tires under the fender flares. So, I went with the 5.7bs.
Old 02-18-2011, 01:24 PM   #39
uca
Wow that is incredible, stuffing 285/65 without a lift and minor trimming! Great looking ride! Any issues with the UCA's rubbing the 65's?
Old 02-18-2011, 02:25 PM   #40
LEX LEX is offline
LEX's Avatar
I think the difference here is they chop and cut a lot to have close to ZERO rubbing when wheeling.
3" lift, 17" wheels, BFG 275/70/17 TA KO's Tacofly Suspension 16 11-27-2013 02:34 PM
Tire Pressure For 285 70 R 17 BFG AT TA KO jjudd 2nd Gen. Tacomas 1 11-25-2011 12:11 PM
FS: 4 BFG All Terrain KO like new 265/65/18 (WA) Eurosport Buy / Sell / Trade 0 10-07-2011 05:28 PM
XD HOSS 16" w/ BFG AT ko 285/75 MMMPinkTACOs 2nd Gen. Tacomas 9 09-07-2011 07:58 PM
BFG TA KO or Nitto Terra Grappler 285/60/18??????? Mtnbker343 Wheels & Tires 0 02-07-2011 02:00 PM
