Grinding Calipers to Fit Wheels : **How To**
Old 02-17-2011, 06:31 PM   #1
Bam-Ba-Lam
Detective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shed
Detective_Dan's Avatar
Air Force: SSgt - A.G.E. Mechanic
Detective_Dan's Tacoma Gallery
Arrow Grinding Calipers to Fit Wheels : **How To**
I TAKE NO RESPONSIBILITY OF DAMAGE THAT YOU DO TO YOUR OWN VEHICLE. IF YOU DO NOT FEEL COMFORTABLE WITH DOING THIS MODIFICATION, BUY WHEELS THAT FIT. IF YOU DAMAGE YOUR CALIPER IT IS NOT MY PROBLEM
ok, so ive been looking around and there isnt a deffinate how to on this, so i fugured i would make one while i was doing it.
mods, sticky possibly?
ok. there are a few different tools you can use to do this. a file (which takes forever), a dremmel (very precise, this is also what i used), or a pneumatic grinder (i didnt like the idea of taking a grinder to my caliper lol)
I only had to grind down about 1/16 of an inch so its not like you are cutting half of the caliper or anything
start by breaking loose all of the lugnuts on one of the front wheels.
then using the bottle jack that came with your truck and lift one of the front wheels off the ground
completely remove all of the lugnuts and the wheel from the caliper and hub assembly.
then take your new wheel and place it on the hub assembly while pressing it flat against the hub. while pressing, rotate the wheel so that it "marks" where the wheel is hitting the caliper.
then take off the wheel and using your dremel or tool of choice, grind on the caliper where it is hitting.
the exposed are where it says "R1" is where mine grinds
this is what it should look like when you start grinding (all of the darker area on the caliper vein)
just grind a little bit, then place the wheel back on to "mark" it again to see if it is hitting, if it is, just grind down a little more. grind it just enough to where the wheel barely clears without rubbing. be very careful to not grind off too much. if you go too deep, you run the risk of damaging your caliper.
here is the final result of my caliper. every wheel will most likely be rubbing in about the same area as mine did, but there is always an exception.
after this you should be good to go!
Old 02-17-2011, 07:07 PM   #3
Nothin' Special
especk is one of the sharper tools in the shedespeck is one of the sharper tools in the shedespeck is one of the sharper tools in the shedespeck is one of the sharper tools in the shedespeck is one of the sharper tools in the shedespeck is one of the sharper tools in the shedespeck is one of the sharper tools in the shedespeck is one of the sharper tools in the shedespeck is one of the sharper tools in the shedespeck is one of the sharper tools in the shedespeck is one of the sharper tools in the shed
especk's Avatar
especk's Tacoma Gallery
sweet. looks good. how much room do you have now? my new wheels only give me about 1/16" and im not sure if i should be concerned.
I probably would have got some steel procomps but didnt want to do any grinding. plus i really like the wheels i ended up getting.
Old 02-17-2011, 07:10 PM   #4
Bam-Ba-Lam
i have about enough room to fit a strand of hair in between the caliper and wheel. its not going to hurt anything, the caliper slightly moves inwards when you press the brake, away from the wheel
Old 02-17-2011, 07:13 PM   #6
Nightstr is one of the sharper tools in the shedNightstr is one of the sharper tools in the shedNightstr is one of the sharper tools in the shedNightstr is one of the sharper tools in the shedNightstr is one of the sharper tools in the shedNightstr is one of the sharper tools in the shedNightstr is one of the sharper tools in the shedNightstr is one of the sharper tools in the shedNightstr is one of the sharper tools in the shedNightstr is one of the sharper tools in the shedNightstr is one of the sharper tools in the shed
Nightstr's Avatar
Nightstr's Tacoma Gallery
Nice!
Old 02-17-2011, 07:13 PM   #7
Bam-Ba-Lam
this needs to be a sticky.......chris.....i know you are lurking in the shadows....
Old 02-17-2011, 07:16 PM   #8
Lord of War
KenLyns's Avatar
KenLyns's Tacoma Gallery
What's safer, this or wheel spacers?
Old 02-17-2011, 07:18 PM   #9
Bam-Ba-Lam
probably this. wheel spacers either mean buying extended thread lug nuts to hold better, or extended studs. both are fairly expensive when you need to buy 24 of them
Old 02-17-2011, 07:43 PM   #10
Lord of War
KenLyns's Avatar
Why would you need either? Wheel spacers like Spidertrax or All-Pro have their own studs.
Old 02-17-2011, 07:46 PM   #11
Mall Crawler
MrGrimm is one of the sharper tools in the shedMrGrimm is one of the sharper tools in the shedMrGrimm is one of the sharper tools in the shedMrGrimm is one of the sharper tools in the shedMrGrimm is one of the sharper tools in the shedMrGrimm is one of the sharper tools in the shedMrGrimm is one of the sharper tools in the shedMrGrimm is one of the sharper tools in the shedMrGrimm is one of the sharper tools in the shedMrGrimm is one of the sharper tools in the shedMrGrimm is one of the sharper tools in the shed
MrGrimm's Avatar
Marines:
MrGrimm's Tacoma Gallery
Good writeup! I grinded mine the same way about 2 years ago and still going strong.
Old 02-17-2011, 07:47 PM   #12
Bam-Ba-Lam
true, but if you have a wheel with 4" backspacing like i do, they will stick out past the fender already, add a 1.25" wheel spacer on top of that, and you will stick past the fender almost 3"
i was talkin about the 1/4" spacers, the small thin ones
Old 02-17-2011, 07:51 PM   #13
Nightstr's Avatar
Here is mine, same wheel with the 1.5" AP wheel spacers but I might take them off in the near future and grind down the caliper....
Old 02-17-2011, 07:55 PM   #14
Tacomanator's Avatar
Tacomanator's Tacoma Gallery
nice wheels. any pics of them completely installed?
Old 02-17-2011, 08:53 PM   #15
Bam-Ba-Lam
unfortunantly not till this weekend
Old 02-17-2011, 10:25 PM   #17
Mob dirt parking lots.
ryanjboutin is one of the sharper tools in the shedryanjboutin is one of the sharper tools in the shedryanjboutin is one of the sharper tools in the shedryanjboutin is one of the sharper tools in the shedryanjboutin is one of the sharper tools in the shedryanjboutin is one of the sharper tools in the shedryanjboutin is one of the sharper tools in the shedryanjboutin is one of the sharper tools in the shedryanjboutin is one of the sharper tools in the shedryanjboutin is one of the sharper tools in the shedryanjboutin is one of the sharper tools in the shed
ryanjboutin's Avatar
Navy: RM/ET2(SS) veteran/Air Force contractor
ryanjboutin's Tacoma Gallery
bizzump
chris 4x4, sticky?
Somebody's proud. lol
Good idea.
Old 02-17-2011, 10:27 PM   #18
Bam-Ba-Lam
Good idea.
hey you.....
SHHHHHHHHHHHHHHHH!!!!!!!!!!!!
Old 02-18-2011, 08:02 AM   #20
Bam-Ba-Lam
Originally Posted by KPT View Post
Good writeup Dan.
thanks keith
15x8 wheels that clear 2nd gen 5 lug Tacoma calipers? IceTaco 2nd Gen. Tacomas 14 11-17-2014 10:26 AM
32's fit,but rims hit calipers :( zero offset the fix? whiteout 1st Gen. Tacomas 34 11-22-2011 06:22 PM
Grind Calipers or wheels? AZtacoma05 2nd Gen. Tacomas 52 12-23-2010 10:39 AM
Smaller calipers for 15" wheels? Good351 Wheels & Tires 6 12-02-2009 12:16 PM
Will my V6 calipers fit under a 15x10 wheel? Captain_Ron80 Wheels & Tires 7 01-12-2009 01:00 PM
