285/75/16 hankook dynapro atm PSI
Discussion in 'Wheels & Tires' started by Detective_Dan, Feb 27, 2011.
  1. Feb 27, 2011 at 5:58 PM
    Detective_Dan
    Detective_Dan [OP] "Place original and witty user title here"
    Jason
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    i recently installed my 5100's and new wheels and tires, hankooks. i went to get a front end alignment to fix the camber on the front wheels. the guy who did my alignment comes in the waiting room and says to me, "you know you only have 35 psi in those tires right? they are rated at 80 psi. your gonna wear them down fast if you dont have enough psi in them so im gonna put them at 80psi"
    i said ok. the only problem with that is it rides like i have no suspension at all because the tires are rock hard now.
    i know my truck is not that heavy compared to chevy, dodge, and ford full size trucks that also use these tires.
    so my question to you is...........
    HOW MUCH PSI SHOULD I BE RUNNING!!!!???????!?!?!??!??!
  2. Feb 27, 2011 at 5:59 PM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    Don't run 80 psi! Do a chalk test to figure out the right psi. I run my nitto trails grapplers at 35/38.
    Oh and the guy who told you to run at 80 because you will wear them down is an idiot. The owner of my truck before me had his tires at 60 and they wore really badly.
  3. Feb 27, 2011 at 6:01 PM
    TexasTacoma37
    80 PSI!?!?!?! AHHHHHH go deflate those things back down to somewhere in the 30's!!!
    NEVER take your truck to that shop again!
  4. Feb 27, 2011 at 6:01 PM
    Detective_Dan
    Jason
    Colorado Springs
    thats what im saying. i know 80 is way to much for a 4500lb truck. wtf is a chalk test though. can someone provide a link
  5. Feb 27, 2011 at 6:03 PM
    MontanaTaco
    Colter
    14 DCLB Sport
    OME lift
    Take a piece of chalk and run a line on your tires then drive in a straight line for about 50 ft or so. Check to see how evenly the chalk wore off. It should be uniform across the tire. If its not fill or in your case deflate to where it is unifom.
  6. Feb 27, 2011 at 6:05 PM
    Detective_Dan
    Jason
    Colorado Springs
    ok so run it along the width of the tread.
    never heard of that one before. ive done water to check how the tread is pressing on pavement, but never chalk
  7. Feb 27, 2011 at 6:05 PM
    TexasTacoma37
    I'm sorry for yelling Jason, I got a little upset @ the technician there :eek:
  8. Feb 27, 2011 at 6:06 PM
    Detective_Dan
    Jason
    Colorado Springs
    ZOMG!!!!!!!!KEITH IS GONNA SHOOT MEEEEE!!!!!
  9. Feb 27, 2011 at 6:06 PM
    MontanaTaco
    Colter
    14 DCLB Sport
    OME lift
    Yeah I heard it on here and tried it out. It works pretty good.
  10. Feb 27, 2011 at 6:07 PM
    Detective_Dan
    Jason
    Colorado Springs
    apology accepted haha
  11. Feb 27, 2011 at 6:07 PM
    Detective_Dan
    Jason
    Colorado Springs
    ok so obviously if there is still chalk on the outer part of the tread, there is too much psi?
  12. Feb 27, 2011 at 6:08 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    You shoulda been like " oh yeah my bad you may as well take it to 100 since they'll deflate some with cold temps" and then watch him blow your tire up hehe
  13. Feb 27, 2011 at 6:08 PM
    Detective_Dan
    Jason
    Colorado Springs
    no cause im pretty sure he would have died hahhahah
  14. Feb 27, 2011 at 6:11 PM
    Fienoma
    Fienoma Well-Known Member
    Hieu
    New Mexcio
    2007 double cab Off road 4x4
    BHLM, In bed lights mod, K&N intake,OEM bed extender....more to come?
    x2 on the chalk test..2 years ago the idiots at costco set my 265 BFG A/Ts at 65 psi..always check the psi yourself..that way you know its done right
  15. Feb 27, 2011 at 6:12 PM
    malander
    max
    01 limited trd 4x4
    Maybe he deserved it for believing they needed to be at 80 FRICKEN PSI. I kid I kid, but in all seriousness go back and tell him to quit his job
  16. Feb 27, 2011 at 6:12 PM
    TexasTacoma37
    I'm going to shoot the guy who told you to put the 80 psi in there....
  17. Feb 27, 2011 at 6:14 PM
    Detective_Dan
    Jason
    Colorado Springs
    he didnt tell me to do it, he did it.
    it was 8:00 in the morning, i had been drinking untill almost 4:00am that morning, and my brother randomly showes up from florida that morning at around 5:30 so i was kinda out of it. when he said im puttin 80psi in there i was like ya ok haha
  18. Feb 27, 2011 at 6:17 PM
    TexasTacoma37
    I wonder how many people near you are running 80 psi in their tires because of that guy.
  19. Feb 27, 2011 at 6:19 PM
    Detective_Dan
    Jason
    Colorado Springs
    probably too many. ill drop the psi to around 35-38 tommorrow morning before work and they will be back to normal because thats what discount tire put in them when they were mounted
  20. Feb 27, 2011 at 11:46 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Differential Breather Mod Light Bar: 4 Cree LED lamps Bilstein 5100s Ride Rite Air Bags
    I had Cooper STTs on my '05... 3 ply sidewall LT tire, and 40 psi was good on it... 32 psi was too squishy feeling.
    I have the Dynapro ATMs, but the P rated (44 psi Max.) and 35 psi feels good on them.
    The stock Rugged Trails (P rated) are the ones you read the door jam PSI for (29 front and 32 rear)... 35 psi max. on them!
    The chalk test is GOOD ADVICE!
