who is running 285/60/18's with stock suspension?
Discussion in 'Wheels & Tires' started by TheRiddleOfSteel, Mar 3, 2011.
  1. Mar 3, 2011 at 4:53 PM
    TheRiddleOfSteel
    TheRiddleOfSteel [OP] Well-Known Member
    Phx
    08 TRD sport
    Looking for some pics (im prob putting them on a black trd sport) and I want to make sure its the look im going for before I pull the trigger.
    thx
  2. Mar 3, 2011 at 5:05 PM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    It's not exactly what you're looking for because I have 5100's in the front set at 1.75", but I am running 285/60/18's on stock rear suspension here, so just imagine the front a little lower:
    PS: I was running that tire on stock suspension with no rubbing issues once the front mud flaps were removed.
  3. Mar 3, 2011 at 5:19 PM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    mine are 265/65/18 which is .1 in larger so they are the same and i have billies at 1.75 and dont have any rubbing
  4. Mar 3, 2011 at 6:40 PM
    TheRiddleOfSteel
    Phx
    08 TRD sport
    265/65 is bigger than 285/60?
  5. Mar 3, 2011 at 6:45 PM
    TheRiddleOfSteel
    Phx
    08 TRD sport
  6. Mar 3, 2011 at 6:48 PM
    Archangel
    Archangel Insurance Agent
    Charlotte, NC
    '13 IS250
    you won't be able to run that setup on bone stock suspension. You'd need spacers on stock setup. You can get Billy 5100's and fix that.
  7. Mar 3, 2011 at 6:48 PM
    TheRiddleOfSteel
    Phx
    08 TRD sport
    how do u like those duratrecs? I was prob going with nitto
  8. Mar 3, 2011 at 6:51 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Jason
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    your gonna rub like crazy on stock suspension. i have bilstein 5100's @ 2.5 and the rear spring TSB (about 2 inches) with 285/75/16 and my shit rubbed pretty bad until i cut and molded the fenders and bumper.
    here is what mine looks like with almost a 3 inch lift.
    if you put a tire on that big with stock suspension, you are gonna destroy some shit............like your bumper
  9. Mar 3, 2011 at 6:52 PM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    I know of a couple people, including myself, that ran that setup on bone stock suspension. With the mud flaps removed, there was nothing I could do TO make them rub.
  10. Mar 3, 2011 at 6:56 PM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    I absolutely love my Duratrac's, they're the best tire I've ever owned. I was running Cooper Zeon LTZ's in 285/60/18, which is basically the same as the Nitto Terra Grappler and they were a great tire and lasted forever, but my Duratrac's perform a lot better in the rain and snow.
  11. Mar 3, 2011 at 6:58 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    Advice is worth what you paid for it right? But at stock ride height, if you want to go oversize and run an 18" rim, I'd suggest 265/65R18. You'll likely still have to remove front mudflaps, or live with rubbing against them.
  12. Mar 3, 2011 at 7:01 PM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    Man, why does everybody keep saying this? I PERSONALLY ran this setup on stock suspension and DID NOT rub EVER.
    Also, you can't compare a 285/60/18 to a 285/75/16, there's almost a 1.5" size differential.
    285/60/18 = 31.46
    285/75/16 = 32.83
    commbubba19 likes this.
  13. Mar 3, 2011 at 7:07 PM
    Detective_Dan
    Jason
    Colorado Springs
    true, but
    (this is just an example, not real measurements)
    you could get a 285/60/18 nitto terra grappler and a 285/60/18 toyo open country M/T and put them next to each other and be able to see a huge difference, sometimes up to 1" +
    not all tires are EXACTLY the same size, even though they are both 285/60/18's.
    backspacing and offset of wheels play a large factor in rubbing as well
  14. Mar 3, 2011 at 7:09 PM
    TexasTacoma37
    You CAN run this setup on stock suspension.
    The tires aren't tall enough (32") to hit the uca, even in the 285 width.
    A certain chris4x4 :spy: ran this setup before he lifted, as did Brett, who posted above......SilvertacoZach is currently running 285/60/18's, no lift, no rub, as well.
  15. Mar 3, 2011 at 7:11 PM
    TexasTacoma37
  16. Mar 3, 2011 at 7:11 PM
    Detective_Dan
    Jason
    Colorado Springs
    thats why i said this^^^^^^
  17. Mar 3, 2011 at 7:25 PM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    You won't find someone that will argue this exact point more than me (in fact I have pointed out in previous threads that tire sizes are based upon barrel and not outer diameter). But you can't compare two tires that have an almost 1.5" different barrel size.
  18. Mar 5, 2011 at 11:50 AM
    scdevall
    scdevall Member
    Denham Springs, LA
    06 DC Tacoma
    Looking to add Bilstein 5100's and wnat to put 305x60's on my 06 DC. Will they rub?
  19. Mar 5, 2011 at 12:14 PM
    ucr2027
    ucr2027 Well-Known Member
    chicagoland/las vegas
    06 tacoma 4x4
    pro comp 7089 w/ 285/75/16 pro comp tires, built right UCA, Icon Coilovers,
    Quick Question. Am going w/ Icon Coilovers, TC UCA for my 06 taco. I need to save for some rims. In the mean time can I use stock 16's with this rim with the 3 inch lift without shreding my tires.
    also which bk rims work best with these tires "rubbing"
  20. Mar 6, 2011 at 7:24 AM
    TexasTacoma37
    4.5" backspacing is best to avoid rubbing.
    You'll need wheel spacers to run 285/75/16's on your stock rims.
