what tire size could i fit on a 2.5" lift?
Old 03-18-2011, 07:29 AM   #1
bigalsyota [OP] bigalsyota is offline
bigalsyota is on a distinguished road
bigalsyota's Tacoma Gallery
I have a 2004 doublecab 2x4. Im about to purchase a 2.5"leveling kit as well as 1.5" blocks for the rear. Im looking to put 285/75/16 Definity Dakota m/t. Will they fit? aslo, what does backspacing have to do with it?
Old 03-18-2011, 08:39 AM   #2
Master Toyota Certified Technician
red yoda is a splendid one to beholdred yoda is a splendid one to beholdred yoda is a splendid one to beholdred yoda is a splendid one to beholdred yoda is a splendid one to beholdred yoda is a splendid one to beholdred yoda is a splendid one to behold
red yoda's Avatar
red yoda's Tacoma Gallery
is it a prerunner? i have 285/50R20 on mine. im selling them cause i dont want 20 any longer. but they fit. so 31's or 33's of you add spacer. i got the rough counrty 2.5 lift on mine. they only silghtly rub when backing up and cutting it to the right. but its not bad.
Old 03-18-2011, 08:48 AM   #3
yeah i have a prerunner. Did you mean a wheel spacer or a lift spacer?
Old 03-18-2011, 08:53 AM   #4
I think I will get the lift and tires. but if im running 285/75/16, what size wheel spacer should i get?
Old 03-18-2011, 08:54 AM   #5
red yoda's Avatar
if you want to run 33's your gonna need wheel spacers. unless you get after market rims with a different offset. if you dont you'll be hitting the upper a-arm. my 285's are 32.7"inches tall which is about the same as some 33's and im about 1/4" away from the a-arm with the truck on the ground. if i lift in in the air the tires hit the a-arm and wont turn. what are you looking for? look or function?
Old 03-18-2011, 08:55 AM   #6
red yoda's Avatar
if your running 285/75R16 you wont need spacers
Old 03-18-2011, 08:59 AM   #7
I want it for both look and function. I just want to make sure i get the biggest tire i can. I just didnt know spacers would be so expensive.
Will i have trouble with the tires hitting the wheel wells? will i have to shave them down?
Old 03-18-2011, 09:00 AM   #8
2009tacoma has a spectacular aura about2009tacoma has a spectacular aura about
Army: SPC, 1BCT 4ID
2009tacoma's Tacoma Gallery
im running 285 75 16 stock rims wiht 3'' leveling kit and i had to use wheel spacer because the tire was rubbing on the a-arms i used the spider trax wheel spacer they work great
Old 03-18-2011, 09:04 AM   #9
1.5" wheel spacer?
max tire size on stock 17" rim with 2.5-3" lift KRich Wheels & Tires 32 04-08-2014 04:05 PM
3" Suspension Lift With 1.5 Body Lift Tire Size? 05Wheeler Suspension 7 05-01-2012 01:36 PM
Help: Tire size for 20" wheels with 6" lift dado337 2nd Gen. Tacomas 2 12-21-2010 04:35 PM
Tire size with 3" lift Jet Wheels & Tires 5 09-02-2010 09:14 PM
Not another "what's the biggest tire size i can fit" thread Biff Wheels & Tires 9 03-19-2010 12:04 PM
