255/85/16 Tire Help Needed
Old 04-27-2011, 08:47 PM   #1
ouengineering is on a distinguished road
ouengineering's Tacoma Gallery
Need your help and expert insight. I bought a 2006 Tacoma a couple of years ago. The stock tires are worn out. It has a slight lean to the left which means I think that I have a bad left strut. I want to make it a little highter and put on a more aggressive tires and also address the strut problem. It'll be a pavement truck with some dirt roads but no 4-wheeling or rock climbing. I'm also trying to keep costs down. So...Trick Trucks can put 2.5 inch lift Bilstein struts on which will raise the front end and solve my lean problem. They will also put on Bilstein replacement shocks on the back all for under $900 for struts and shocks which I think is a fair deal. I'm currently running 265/70/16s...I can run 265/75/16s with stock suspension. So...here are my questions.
1) With a 2.5 inch Bilstein strut lift up front and no lift in the back, can I run 255/85/16s?
2) If #1 is yes, do I have to remove mud flaps?
3) If #1 is yes, do I have to trim the inner wheel well?
4) If #1 is yes, will the tire rub at full turn?
5) If #1 is yes, will I need to change gearing?
6) If #1 is yes, what brand of tire do you recommend?
7) If #1 is no, what should I run?
Your helps is appreciated!
Old 04-27-2011, 08:52 PM   #2
KPT KPT is offline
sees what you did there.
KPT's Avatar
KPT's Tacoma Gallery
First off, Tacomas lean naturally, because the driver and the gas tank are on the same side. It's called the "taco lean". So you likely do not have a bad shock. (That wouldn't affect ride height at all, just spring dampening)
Secondly, adding bilstein 5100's will not fix the taco lean, because it still uses the stock springs and preloads them the exact same amount, to the lean will be the same.
1. Yes, if you buy aftermarket wheels with 4.5" backspacing, or use wheel spacers.
2. Likely
3. yes.
4. Maybe, you might have to chop your cab mount.
5. no
6. search.
7. N/A
Can you run front mudflaps with 255/85/16 or 255/80/17 ? OZ-T Wheels & Tires 101 04-18-2013 05:34 PM
Last Question About Tires 255/85-16 Toyo MT or 265/75-16 Duratrac Magnetic Wheels & Tires 1 08-15-2011 08:14 AM
Using a 255/85/16 as a spare for 285/75/16? Tacoma831 Wheels & Tires 11 04-05-2011 04:37 PM
Minimum lift needed for 255/85/16s m3zy6 Wheels & Tires 5 10-02-2010 09:05 PM
