do these suck ???
Old 05-08-2011, 02:28 PM   #2
The Mad Scientist
jberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shed
jberry813's Avatar
jberry813's Tacoma Gallery
Originally Posted by stevenstaco View Post
All spacers suck.
Old 05-08-2011, 02:35 PM   #3
Sheppymach is one of the sharper tools in the shedSheppymach is one of the sharper tools in the shedSheppymach is one of the sharper tools in the shedSheppymach is one of the sharper tools in the shedSheppymach is one of the sharper tools in the shedSheppymach is one of the sharper tools in the shedSheppymach is one of the sharper tools in the shedSheppymach is one of the sharper tools in the shedSheppymach is one of the sharper tools in the shedSheppymach is one of the sharper tools in the shedSheppymach is one of the sharper tools in the shed
Sheppymach's Avatar
Sheppymach's Tacoma Gallery
they do not suck, they are just not hub centric. i love mine
Old 05-08-2011, 02:36 PM   #4
Banned
Originally Posted by jberry813 View Post
All spacers suck.
X2
Old 05-08-2011, 02:42 PM   #6
The Mad Scientist
jberry813's Avatar
how can you tell if they are hub centric ........and if spacers suck whats another way to fit bigger tires
Hubcentric spacers will have a little hub ring for the wheel hub to center on (look at the spidertrax spacers below)
Get wheels with a smaller backspacing.
Old 05-08-2011, 02:45 PM   #7
B A N N E D
stevenstaco is one of the sharper tools in the shedstevenstaco is one of the sharper tools in the shedstevenstaco is one of the sharper tools in the shedstevenstaco is one of the sharper tools in the shedstevenstaco is one of the sharper tools in the shedstevenstaco is one of the sharper tools in the shedstevenstaco is one of the sharper tools in the shedstevenstaco is one of the sharper tools in the shedstevenstaco is one of the sharper tools in the shedstevenstaco is one of the sharper tools in the shedstevenstaco is one of the sharper tools in the shed
stevenstaco's Avatar
stevenstaco's Tacoma Gallery
thank you I see the difference ...I found a set of 4 on cl for 80 but I guess Ill go a different route
Old 05-08-2011, 02:45 PM   #8
Tacomanator's Avatar
Tacomanator's Tacoma Gallery
If you must have wheel spacers, get Spidertrax. Lots of guys run them on here and have no complaints.
Old 05-08-2011, 02:50 PM   #9
The Mad Scientist
jberry813's Avatar
Were you trying to stick with stock wheels?
If so, I wounldn't consider any spacer but the spidertrax ones (because they are hubcentric).
Factory wheels are hubcentric. Most aftermarket wheels are lug centric. If you attempt to use your factory wheels on a spacer that is lug centric, you sir, have a deathwish.
Without a spot for the hub to center on, well there's no way to center the wheels. Factory lug nuts are not lug centric lugs. And you can't use lug centric lugs on a factory wheel. Well...you could, but you'd end up pulling a Jacob Wood.
Old 05-08-2011, 02:51 PM   #10
B A N N E D
ill prob just put bigger tires on my stock rims ...from what Ive read if I wanna get 285s I need spacers?
Old 05-08-2011, 02:59 PM   #11
The Mad Scientist
jberry813's Avatar
It'll work for mall crawling. What are your 5100's set at up front?
No matter what, you're just going to rub the sway bar with a 5" BS and maybe the frame at full lock/compression. I squeezed 285's on my wifes 4th gen runner with factory Tundra wheels (also have a 5" BS). I've driven the shit out of her runner at Pismo before and it did ok. Just tried to avoid full lock. I have the Toytec coilovers on the runner is set at 3" right now, but there are definetly shiney spots on the sway bar.
Exhibit A:
Exhibit B (notice the shiney spots):
Exhibit C (fender trimming required too)
Old 05-08-2011, 03:01 PM   #12
ColtsTRD's Avatar
ColtsTRD's Tacoma Gallery
this!
Old 05-08-2011, 03:03 PM   #13
B A N N E D
Exhibit A:
they are at 1.75 now but will be going up to 2.5 when my aal arrives maybe Ill just go 265s............we have an 06 runner also
Old 05-08-2011, 03:06 PM   #14
The Mad Scientist
jberry813's Avatar
I shall keep a close eye out for a set of used wheels with 4.5" BS for you good sir.
Old 05-10-2011, 08:38 AM   #15
Sheppymach's Avatar
Im running the all pro hub centrics with 285's on stock rims
Girlfriends Suck 05offroad Off-Topic Discussion 55 02-22-2011 12:51 AM
U bolts suck...HELP?? wolfgang123 1st Gen. Tacomas 26 01-23-2010 04:14 PM
why do little pieces suck kjf216 2nd Gen. Tacomas 3 12-19-2009 12:27 AM
Next semester is going to SUCK DanGer Off-Topic Discussion 22 10-22-2009 11:51 PM
The Titans SUCK BravesFan Sports, Hobbies & Interests 18 10-21-2009 03:41 PM
