Will these Black Rock wheels fit?
Discussion in 'Wheels & Tires' started by michaelg589, Jun 1, 2011.
  1. Jun 5, 2011 at 6:26 PM
    #21
    michaelg589
    michaelg589 [OP] Well-Known Member
    So I've done a bunch of searching around and also got an answer from Jegs customer service.
    The Steel Black Rock Type 8 wheels that I posted WILL fit a 05+ 4x4 Tacoma.
    Black Rock Type 8 Steel rim in 16x8 weighs 37 pounds.
    Stock TRD Off-road rim weighs roughly 25 pounds - this is something I gathered from several different areas. All numbers I found were about the same, give or take a pound.
    Black Rock Yuma rim in 16x8 weighs 29 pounds.
    So I will stick with the Yumas to try and limit the addition of unsprung weight to my truck. With the Type 8 steelies, I'm adding more than 45 lbs. of rims and and a bunch more with the slightly larger and beefier tires that Ill use (Goodyear Wrangler Duratracs). My gas mileage is bad enough. lol
  2. Jun 20, 2011 at 8:15 PM
    #22
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    so how did the 16 inch black rock 908's work out any pics?
  3. Jul 6, 2011 at 4:29 PM
    #23
    michaelg589
    I went with the Black Rock Yumas. They are backordered until July 18. SO i should have them in 2-3 weeks.
  4. Jul 26, 2011 at 6:23 AM
    #24
    Cesar
    Cesar New Member
    lemoore, ca
    06 TRD Off Road
    I've been looking at those exact wheels in the same size(16x8). I'm about to pull the trigger on them, but i'm just waiting for a post from u saying they do fit. I'm hoping they do
  5. Jul 26, 2011 at 3:16 PM
    #25
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    to give you an idea i have 16 inch aftermarket wheels on my truck with 4.25 backspace. my tires are the stock dunlops for now. 245-75-16 this is how much they stick out . [​IMG]
  6. Jul 26, 2011 at 7:23 PM
    #26
    michaelg589
    That looks pretty good. Hopefully mine should look about the same since my tire will be almost an inch wider.
    Im still waiting on the wheels. I was told I should have them by the second week of August. This is certainly taking a long time. They arrived in California on Monday and will take a few days to get through customs. Oh well, just gives me more time to save up for tires.
  7. Jul 26, 2011 at 8:14 PM
    #27
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Fyi, the pro comp steelies won't fit without 1/2" wheel spacers in the front. Neither will recentered H1 beadlocks, at least on 05+ Tacos. IMG_0120_54aa1b65320b2a0ad873cec0671351ac8f81be6c.jpg
    I've got 4 extra 1/4" spacers if you need them.
  8. Aug 6, 2011 at 12:10 PM
    #28
    michaelg589
    Got the wheels in yesterday. They look great... in the box lol. They also feel lighter than I expected. However, I just bought a motorcycle, so tires might be a while. lol
  9. Aug 8, 2011 at 12:01 AM
    #29
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    FYI, Soft 8 or Type 8 wheels have historically never cleared the caliper face of the Tacomas....
    the holes are dimple die and the inside lip of the holes hit the brake vein on the caliper face...
    the 8 hole alloys will clear...
    the steels, you will need wheel spacers like Username (Logan) mentioned above...
  10. Dec 14, 2011 at 2:47 PM
    #30
    michaelg589
    And.... they fit.
    Now I just have to get these put on them.
  11. Dec 14, 2011 at 3:16 PM
    #31
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    sweet looking wheels... definitely not the Soft8... they look like alloys... might be why they seemed lighter?
  12. Dec 14, 2011 at 3:18 PM
    #32
    michaelg589
    They are alloys, correct.
  13. Dec 14, 2011 at 3:21 PM
    #33
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    just saw your edit... yah, they are alloys...
    the holes are cut/cast differently than the Soft8s...
    as Logan showed in his post, the true steel Soft8 will need the wheel spacer...
    the alloy version the OP got is a great wheel...
  14. Dec 17, 2011 at 11:54 AM
    #34
    michaelg589
    On the truck :)
  15. Dec 19, 2011 at 4:00 PM
    #35
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    Looks great! What size Duratecs are those?
  16. Dec 20, 2011 at 6:40 AM
    #36
    michaelg589
    Thanks. They're 265-75-16s
  17. Dec 20, 2011 at 10:29 AM
    #37
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    running a set of the 8069s in a 16x8 and did not need to grind/shave the caliper...granted, they only clear by maybe 1/16"
  18. Jan 8, 2012 at 4:20 PM
    #38
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Michael - I dropped you a PM. I would also LOVE to see a parallel body shot to see how far they stick out past the fender.
  19. Jan 8, 2012 at 5:37 PM
    #39
    michaelg589
    Ill try to get more pics up soon
  20. Jan 11, 2012 at 7:01 AM
    #40
    bigdaddytaco
    bigdaddytaco Well-Known Member
    jared
    sylva nc
    2000 tacoma
    ARB bumper 3 inch oldman emu lift piaa fog lights
    ya wont to see some pix
