285s vs 33" tires
Old 06-22-2011, 10:25 AM   #1
chilow [OP] chilow is offline
chilow is on a distinguished road
chilow's Tacoma Gallery
285s vs 33" tires
Tried searching, but couldn't find the answer I was looking for. Sorry if this has been covered. What is the difference between 33" tires and 285 tires? From what I read, they are both 33" tires more or less. If that's the case, why the different numbers? Does one get better gas mileage than the other? Why are 33" cheaper than 285s? Thanks! Still a newbie and learning
Old 06-22-2011, 10:27 AM   #2
The Man!
JLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shed
JLee's Avatar
JLee's Tacoma Gallery
There is a compression to a 33x11.50
from the online tire size calculator
Old 06-22-2011, 10:29 AM   #3
ColtsTRD's Avatar
ColtsTRD's Tacoma Gallery
or you could do 295s
Old 06-22-2011, 10:29 AM   #4
The Man!
JLee's Avatar
Also where are you seeing 33's cheaper then 285's unless your looking at 33/11.50/15's
Old 06-22-2011, 10:30 AM   #5
ColtsTRD's Avatar
the reason 33's are a little cheaper is because its a standard size....all the metric stuff gets a little more pricey
Old 06-22-2011, 10:31 AM   #6
The Man!
JLee's Avatar
Hum didn't know that i would think they would be more seeing how not many manufactures even make 33/11.5/16's
Old 06-22-2011, 10:44 AM   #7
Yo! Wat up peeps?
1Bigbird has a brilliant future1Bigbird has a brilliant future1Bigbird has a brilliant future1Bigbird has a brilliant future1Bigbird has a brilliant future1Bigbird has a brilliant future1Bigbird has a brilliant future1Bigbird has a brilliant future1Bigbird has a brilliant future1Bigbird has a brilliant future1Bigbird has a brilliant future
1Bigbird's Avatar
1Bigbird's Tacoma Gallery
Don't think you will get better mileage because (as I know it) you need a lift to run 285's. If you have a lift then the weight of the tire is your next obstacle.
Old 06-22-2011, 10:50 AM   #8
Thanks for the info! If I'm reading the chart correctly, the 33's are slightly bigger. Would the slight increase in size result in less mpg? Or is the difference so small that it wouldn't change the mpg between 285's and 33's?
Old 06-22-2011, 10:53 AM   #9
The Man!
JLee's Avatar
It would be very small but yes a 33/11.5/16 will get less Mpg's but if your worried about mpg's don't even lift your truck just stick with the 265/70/16's
Old 06-22-2011, 10:53 AM   #10
Yo! Wat up peeps?
1Bigbird's Avatar
^^^^ What he said.^^^^
Depends on gearing but will only be a very minor difference!
Old 06-22-2011, 10:54 AM   #11
ColtsTRD's Avatar
Super Swamper is the only one I know of...
Old 06-22-2011, 10:56 AM   #12
The Man!
JLee's Avatar
LOL and those get great MPG's
Old 06-22-2011, 10:57 AM   #13
macgyver is one of the sharper tools in the shedmacgyver is one of the sharper tools in the shedmacgyver is one of the sharper tools in the shedmacgyver is one of the sharper tools in the shedmacgyver is one of the sharper tools in the shedmacgyver is one of the sharper tools in the shedmacgyver is one of the sharper tools in the shedmacgyver is one of the sharper tools in the shedmacgyver is one of the sharper tools in the shedmacgyver is one of the sharper tools in the shedmacgyver is one of the sharper tools in the shed
macgyver's Avatar
macgyver's Tacoma Gallery
I like your quote in your sig.
Lamb of God!
Old 06-22-2011, 10:58 AM   #14
ColtsTRD's Avatar
well you said there were "many"...and there's one LMAO!!
Super Swampers are fugly anyhow...
Old 06-22-2011, 11:00 AM   #15
The Man!
JLee's Avatar
Not many
Old 06-22-2011, 11:00 AM   #16
lol one more question. I was looking on tirerack and there's an option to "add studding" What is that? is it for the $15 per tire to add it? Is it one of those things that are better to have when needed, than not having it at all?
Old 06-22-2011, 11:01 AM   #17
Yo! Wat up peeps?
1Bigbird's Avatar
If you don't know you don't need them!
For ice!
Old 06-22-2011, 11:02 AM   #18
The Man!
JLee's Avatar
Studded tires are for winter were there is lots of snow you don't want that.
Old 06-22-2011, 11:03 AM   #19
ColtsTRD's Avatar
Not many
Old 06-22-2011, 11:05 AM   #20
anethema is one of the sharper tools in the shedanethema is one of the sharper tools in the shedanethema is one of the sharper tools in the shedanethema is one of the sharper tools in the shedanethema is one of the sharper tools in the shedanethema is one of the sharper tools in the shedanethema is one of the sharper tools in the shedanethema is one of the sharper tools in the shedanethema is one of the sharper tools in the shedanethema is one of the sharper tools in the shedanethema is one of the sharper tools in the shed
anethema's Avatar
anethema's Tacoma Gallery
You don't want studding. Studded tires are for ice in the winter. Unless they are dedicated winter tires,no studding (its illegal in most places in the summer).
285 is the width of the tire by the way, its the other number that tells you how big around it is going to be. 285/75 means sidewall is 75 percent height of the width of the tire. So double that, convert to inches, and add your rim size to get the diameter of the tire.
Kind of annoying, but 285s aren't all 33s. There are 285/65 285/70 and 285/75. All pretty different tire sizes.
FS: (4) Toyo MT Tires - 33"x12.5"x20" gkatmar Buy / Sell / Trade 0 10-30-2011 10:03 AM
17" procomp extreme chrome wheels and 33" tires irbya Buy / Sell / Trade 6 09-02-2010 09:25 AM
17" Rims and 33" Tires For Sale CHEAP! Knightryder Buy / Sell / Trade 12 05-16-2010 11:02 AM
For Sale: 17" Wheels and 33" Nitto MT Tires SACTACO07 Buy / Sell / Trade 9 11-23-2009 10:03 AM
16" Ultra Wheels and 33" Pro comp X-Terrain Tires mattyrez09 Buy / Sell / Trade 3 01-12-2008 01:50 PM
