Will these tires fit?
Old 09-08-2011, 09:39 AM   #1
Jdswails [OP] Jdswails is offline
Jdswails is on a distinguished road
Jdswails's Tacoma Gallery
I got a 2002 tacoma and it's time for new tread had 32x11.50 Maxxis bighorns on it and I just got a deal on a set of 305/60/18 Mickey thompson Baja ATZ I have a 3 inch suspension lift from rough country. Will they fit?
Old 09-08-2011, 10:05 AM   #2
KPT KPT is offline
sees what you did there.
KPT's Avatar
KPT's Tacoma Gallery
What is the backspacing of your wheels?
Old 09-08-2011, 10:14 AM   #3
18x9 with 4.5 inch backspace
Old 09-08-2011, 10:16 AM   #4
KPT KPT is offline
KPT's Avatar
4.5" backspacing is stock for 1st gen. I think that's going to be too much. I believe guys running that wide a tire (around a 295) are in the 3.75" BS range.
Old 09-08-2011, 10:24 AM   #5
The Man!
JLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shedJLee is one of the sharper tools in the shed
JLee's Avatar
JLee's Tacoma Gallery
It's going to be close with a 4.5" BS I'm running 33/12.5's with a 3.75 BS and I rub the frame at full lock and full compression but it's not bad on the street I would never hit.
from the online tire size calculator
Old 09-08-2011, 10:29 AM   #6
I got the tires for 700 dollars with only a 1000 miles on them so I really wanna use them. I haven't bought any wheels yet I'm just tryin to figure out the spacing. It's the 18x9 monster XD wheel. What would you recommend?
Old 09-08-2011, 10:33 AM   #7
Take your flame, ignite the world!!!!
04taco2wd is one of the sharper tools in the shed04taco2wd is one of the sharper tools in the shed04taco2wd is one of the sharper tools in the shed04taco2wd is one of the sharper tools in the shed04taco2wd is one of the sharper tools in the shed04taco2wd is one of the sharper tools in the shed04taco2wd is one of the sharper tools in the shed04taco2wd is one of the sharper tools in the shed04taco2wd is one of the sharper tools in the shed04taco2wd is one of the sharper tools in the shed04taco2wd is one of the sharper tools in the shed
04taco2wd's Avatar
04taco2wd's Tacoma Gallery
Im not sure there are many wheels out there that come in 18" with less than 4" of bs...
Old 09-08-2011, 10:41 AM   #8
The Man!
JLee's Avatar
Well you might be SOL on the wheels but you can get wheels with a 5.25" and 1.5" wheel spacers to put your BS to 3.75" that's if they make those wheels in a 5.25" BS
Old 09-08-2011, 10:59 AM   #9
They offer them in a -12, +18, and a +35
Old 09-08-2011, 12:09 PM   #10
KPT KPT is offline
KPT's Avatar
If they are 9" wide, then the -12 will be the 4.5" backsapcing. The other offsets are even higher backspacing, so they aren't an option.
Old 09-08-2011, 12:27 PM   #11
Honey badger hits whatever tree he wants to hit!!
Honey badger is one of the sharper tools in the shedHoney badger is one of the sharper tools in the shedHoney badger is one of the sharper tools in the shedHoney badger is one of the sharper tools in the shedHoney badger is one of the sharper tools in the shedHoney badger is one of the sharper tools in the shedHoney badger is one of the sharper tools in the shedHoney badger is one of the sharper tools in the shedHoney badger is one of the sharper tools in the shedHoney badger is one of the sharper tools in the shedHoney badger is one of the sharper tools in the shed
Honey badger's Avatar
Army: 99 Zulu
Honey badger's Tacoma Gallery
I have 305/70/16 on 16x9 wheels with the -12 offset and 4.5 BS at full lock I rub just a bit and off road just on small trail out on our hunting lease I rub a lot. I have a suspension lift as well as a body that will be coming off soon. When I comes off I will do a lot of hacking to get them to fit but my next set of tires I believe will be 285/75.
Old 09-08-2011, 12:33 PM   #12
How much difference is there between the 70's and the 60's
Old 09-08-2011, 12:46 PM   #13
KPT KPT is offline
KPT's Avatar
10% of the tire width.
Old 09-08-2011, 02:53 PM   #14
Would I be better off selling the tires and down sizing or try and make them work
Will these wheels fit? What tires fit these rims? BigRedToy Wheels & Tires 13 07-12-2011 11:00 AM
Will these tires fit? Koov 2nd Gen. Tacomas 7 05-28-2010 12:34 PM
Will these tires fit? boxing83190 Wheels & Tires 1 05-11-2010 09:08 PM
Need new tires, what will fit? c0b2a Wheels & Tires 6 11-03-2009 07:18 PM
Will these tires fit? mjp2 Off-Topic Discussion 19 09-29-2009 10:49 AM
