20" Wheels What tire pressure?
Old 06-24-2007, 04:10 PM   #1
kaisersteiner is on a distinguished road
kaisersteiner's Tacoma Gallery
Hello all- Just got 20" wheels on my 07 PreRunner and they have about 55psi of pressure in the tires. What should I run in them? I know they can handle the higher pressure but should I actually run that much? Thanks in advance.
Old 06-24-2007, 05:05 PM   #2
I dub thee malicious!
007Tacoma is one of the sharper tools in the shed007Tacoma is one of the sharper tools in the shed007Tacoma is one of the sharper tools in the shed007Tacoma is one of the sharper tools in the shed007Tacoma is one of the sharper tools in the shed007Tacoma is one of the sharper tools in the shed007Tacoma is one of the sharper tools in the shed007Tacoma is one of the sharper tools in the shed007Tacoma is one of the sharper tools in the shed007Tacoma is one of the sharper tools in the shed007Tacoma is one of the sharper tools in the shed
007Tacoma's Avatar
007Tacoma's Tacoma Gallery
Send a message via AIM to 007Tacoma
The higher pressure will help you with your MPG, but it will make the ride a bit rough (especially on 20's).
Old 06-24-2007, 05:44 PM   #4
How much do you think the pressure will help the MPG? The size is 20x9 and the original was 16x7. The tire size difference is really not huge. How much do you think I am giving up? 285/50/20 from 245/70/16...
Old 06-25-2007, 04:29 AM   #5
007Tacoma's Avatar
The sidewall design of your tire will determine how rough your ride is if you are under pressure (see sidewall for recommended and max PSI). At the recommended pressure your tire should be the optimal balance between comfort and economy for its design. At the max PSI you may gain 1-2 MPG, but BEWARE this will cause uneven wear on your tires. The center line will "ball" or flatten. Under inflation will do the exact oposite and wear the outside of the tread.
Moving from a 245(width)/70(% of width as height)/16(rim size) to a 285/50/20 means that you will loose some economy, but you will gain in dry traction and looks.
I hope this helps.
20" enkei wheels tire size qusetion please help yosimdisam 2nd Gen. Tacomas 33 11-04-2011 04:40 PM
Help: Tire size for 20" wheels with 6" lift dado337 2nd Gen. Tacomas 2 12-21-2010 03:35 PM
What Happens to the Tire Pressure Monitor When I Swap Wheels?? MikeDeason Wheels & Tires 24 03-29-2010 12:08 PM
New Wheels and Tire Pressure Monitor Sensor FARNORCAL Wheels & Tires 1 03-08-2010 04:25 PM
Tire pressure sensor and changing wheels TacomaTim Wheels & Tires 9 09-04-2009 04:02 PM
