Well that sucks.
Discussion in 'Wheels & Tires' started by babytruck, Nov 27, 2011.
  1. Nov 27, 2011 at 2:44 PM
    babytruck
    babytruck [OP] Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    About two weeks ago I went from stock steelies and tires to BFG Rugged Terrains (NOT Rugged Trails) size 265/70/17. From what I understood and was told, that these tires would fit fine with no rub.
    Well, I got rub. Rubs both on the front of the wheel well and on the flaps. I removed the flaps but it still rubbed just a tad at full crank.
    I don't want to cut both front and back of wheel wells so the next thing is to go down in size to 265/65. Had the guy check for recommended size in the computer and yep! It's supposed to be 265/65 not 70.
    Kills me to think that for some reason a lot of you can fit that size but for some reason I still touch rubber. :(
    Just a heads up on these tires and on a 2010 4x4 with stock height.
  2. Nov 27, 2011 at 2:45 PM
    TexasTacoma37
    What's the specs on the wheels? Sounds like they either have too little backspacing, (<4.5") or are a little too wide (9" or more)
  3. Nov 27, 2011 at 2:46 PM
    babytruck
    NorCal
    17x9 4.5 bs
  4. Nov 27, 2011 at 2:47 PM
    TexasTacoma37
    I've heard of people rubbing with 9" wide wheels before, where the wheels stick out far enough that the outside of the tire rubs.
    Is it the outside edge of the tire that's hitting the plastic?
  5. Nov 27, 2011 at 2:48 PM
    babytruck
    NorCal
    The outside edge when I turn it full crank.
  6. Nov 27, 2011 at 2:51 PM
    TexasTacoma37
    Yeah with the 9" wide wheels some people do rub at full lock with no lift. That, in addition to the fact that many 265s are not approved for use on 9" wide wheels, is why I usually try to steer folks away from that combo.
    Fwiw though it seems to be hit or miss. I know many people do not have a problem with this setup, including myself (although I have 5.4" bs so my wheels sit in quite a bit further).
    How much plastic would you need to trim to alleviate the problem?
  7. Nov 27, 2011 at 2:52 PM
    babytruck
    NorCal
    Probably about three inches up on the front and about two inches on the back. Do you think going down in tire size would help? From 70 to 65? It barely touches. It's not like if I go full crank I'll tear up plastic, it just rubs a little. I put black tape on the spot to see where it's actually rubbing and it rubs light enough to scuff the tape but not tear through it.
    I could be wrong but in searching I thought those tires were one of the few that were safe to use on 9 inch wheels.
  8. Nov 27, 2011 at 2:53 PM
    TexasTacoma37
    I think you'll have a hard time finding tires in that size that are approved for 9" wide rims.
    9" rims are really more for 285+ section widths.
    Unfortunately the rims are the problem here not the tires.
  9. Nov 27, 2011 at 3:05 PM
    TexasTacoma37
    I'm glad that you searched to make sure the ones you selected were approved. Most people don't do that :thumbsup:
    But that doesn't mean they will fit without rubbing. The wider wheel stretches the tire out and makes it have a wider turning arc.
    Would you consider doing a ~1" lift up front? I think that's a far easier solution than returning wheels or tires.
  10. Nov 27, 2011 at 3:12 PM
    babytruck
    NorCal
    But then I'd have to dish out more money....
  11. Nov 27, 2011 at 3:14 PM
    TexasTacoma37
    Could try some 1/2" top plate spacers for $25 at toytec.
  12. Nov 27, 2011 at 3:42 PM
    babytruck
    NorCal
    KPT thanks for the suggestions and for your help. Thinking again about the nine inch wheels got me a little insecure so I just went again to BFG's website for those tires and under options avail it says the tires are approved for 7"-9" rims. :) http://www.bfgoodrichtires.com/tire...R16+T1/OE/BNW/rugged-terrain-t-a/tire-details
    Called the tire guy and he said that he asked the veteran guys there if they've seen an improvement on rub by going down in sidewall height and they said it should work, we are looking at about a half inch in difference (which should be enough for clearance, as I visually see). Cross your fingers, lets hope that it's going to be okay.
  13. Nov 27, 2011 at 3:47 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    It sounds like you've made your decision- but what is wrong with trimming the plastic away??
  14. Nov 27, 2011 at 3:50 PM
    joes06tacoma
    joes06tacoma Well-Known Member
    Joe
    Central Coast, CA
    06 4x4 Off Road Access Cab v6 6spd
    LEER Shell with dome lights operated with 3 way switches, aux backup lights with relay and 3 position switch, modified wiring to compass/temp display and clock to include switch that disables dimming function (poor man's DRL solution), Scan Gauge 2
    I'd run it. In 5K miles, it might not rub at all.
  15. Nov 27, 2011 at 3:50 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    Do you have a pic of the new tires and wheels? I think after a few miles the corners of tires should wear down a bit.
  16. Nov 27, 2011 at 3:56 PM
    TexasTacoma37
    Alrighty keep us updated.
  17. Nov 27, 2011 at 4:00 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    if it's barely rubbing your tape test, i say leave it as is and don't downsize. in 6 months, you're going to add some kind of lift(given you hang around TW enough) and you're going to regret downsizing.
    as KPT recommend, you can add a 1" spacer lift up front. it's pretty cheap and you can level out the truck.
  18. Nov 27, 2011 at 4:29 PM
    babytruck
    NorCal
    I really don't want to cut the car quite yet. It's still new to me, I've got 4,400 miles on it.
    I was thinking that too but currently I can't even park the truck without hearing the sound.
    Ignore the thumbs up. This is when the truck was brought to me with the wheels on as a surprise. I was saving up and didn't quite have enough when my husband went ahead and had it done. Please note that the mud flaps have been removed.
    Will do!
    I don't think I'll be doing a lift any time soon so for now I'm hoping I don't regret anything.
    If this doesnt work, I'll have to consider the 1" spacer.
  19. Nov 27, 2011 at 5:43 PM
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    why does the truck look so low? :confused: or is it just me?
  20. Nov 27, 2011 at 5:50 PM
    Rain
    Rain Well-Known Member
    John
    Washington
    2011 TRD Off Road
    I see what you mean. The wheel well looks too "full" for that tire. Maybe something else has been done to the truck.
    Nice Red!
