285s with a lift?
Old 12-21-2011, 08:42 AM   #1
rhion82 [OP] rhion82 is offline
The One The Only
rhion82 is one of the sharper tools in the shedrhion82 is one of the sharper tools in the shedrhion82 is one of the sharper tools in the shedrhion82 is one of the sharper tools in the shedrhion82 is one of the sharper tools in the shedrhion82 is one of the sharper tools in the shedrhion82 is one of the sharper tools in the shedrhion82 is one of the sharper tools in the shedrhion82 is one of the sharper tools in the shedrhion82 is one of the sharper tools in the shedrhion82 is one of the sharper tools in the shed
rhion82's Avatar
rhion82's Tacoma Gallery
285s with a lift?
So i just installed a 3" lift (http://tinyurl.com/bma2xrw) on my tacoma. I have moto metal wheels that have a backspacing of 4.50 I believe. My question is if i put a set of 285/75/16 A/T tires on how much trimming will have to be done if any? Thanks for the Help
Old 12-21-2011, 08:45 AM   #2
fishntaco is one of the sharper tools in the shedfishntaco is one of the sharper tools in the shedfishntaco is one of the sharper tools in the shedfishntaco is one of the sharper tools in the shedfishntaco is one of the sharper tools in the shedfishntaco is one of the sharper tools in the shedfishntaco is one of the sharper tools in the shedfishntaco is one of the sharper tools in the shedfishntaco is one of the sharper tools in the shedfishntaco is one of the sharper tools in the shedfishntaco is one of the sharper tools in the shed
fishntaco's Avatar
fishntaco's Tacoma Gallery
A good bit of plastic and possibly chop the cab mounts. Search around the site, this question has been covered alot.
Old 12-21-2011, 09:07 AM   #3
The One The Only
rhion82's Avatar
Oh and I will not be wheeling in this truck so More than likely it will not be maxed out.
Old 12-21-2011, 09:09 AM   #4
countrylivn is one of the sharper tools in the shedcountrylivn is one of the sharper tools in the shedcountrylivn is one of the sharper tools in the shedcountrylivn is one of the sharper tools in the shedcountrylivn is one of the sharper tools in the shedcountrylivn is one of the sharper tools in the shedcountrylivn is one of the sharper tools in the shedcountrylivn is one of the sharper tools in the shedcountrylivn is one of the sharper tools in the shedcountrylivn is one of the sharper tools in the shedcountrylivn is one of the sharper tools in the shed
countrylivn's Avatar
countrylivn's Tacoma Gallery
just a bit of the back plastic of the fender flare ...not much at all .. can use a nice razor blade or dremel .. and you will be good to go .. and kinda depends on if you are running mt or at tires.... at dont have as deep tread so dont catch on as mutch on the boddy pieces..
Old 12-21-2011, 09:09 AM   #5
fishntaco's Avatar
If it wont be flexing you probly wont have to do the cab mount chop, but it varies from truck to truck. You will still have to trim plastic inside the fender well though.
Old 12-21-2011, 09:11 AM   #6
The One The Only
rhion82's Avatar
Yeah I figured I would have to cut the plastic but im just worried about the cab mount being cut. I will be buying AT tires too.
Old 12-21-2011, 09:12 AM   #7
Any dog under 50# is a cat and cats are useless...
jhodge83's Tacoma Gallery
also, a good alignment w/ around 2.5-3* of caster will help out on less trimming at the rear of the fender well.
Old 12-21-2011, 09:16 AM   #8
The One The Only
rhion82's Avatar
Here is the tire I will be putting on in the morning at discounttire store in Alcoa.
They have refereed me to another tire shop that will do my alignment at a good price. so hopefully I will not have to do the chop on the cab.
Old 12-21-2011, 09:20 AM   #9
Don't ask questions you don't want the answer to..
chadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shed
chadderkdawg's Avatar
chadderkdawg's Tacoma Gallery
I've got almost an identical lift, just trimmed some plastic, and all is well.
Old 12-21-2011, 09:21 AM   #10
i'd go ahead and get a firestone lifetime alignment if there are any close to ya. paid $150 and mine has been aligned 6-8 times easily.
Old 12-21-2011, 09:58 AM   #11
yeh op you shouldnt have to cab mount chop ..
Old 12-22-2011, 12:56 PM   #12
Ernesto is on a distinguished road
Ernesto's Avatar
Army:
Ernesto's Tacoma Gallery
What was the tire size you ended up with? What is the size of your wheels?
Old 12-22-2011, 01:31 PM   #13
The One The Only
rhion82's Avatar
I went with the tires above. 285/75/16 so far no issues. I went ahead and trimmed a little plastic yesterday
Old 12-22-2011, 01:40 PM   #14
USCoastGuard12 is on a distinguished road
USCoastGuard12's Avatar
USCoastGuard12's Tacoma Gallery
this is how much i had to trim off.http://www.tacomaworld.com/gallery/s...5/limit/recent
Old 12-22-2011, 01:41 PM   #15
Old 12-22-2011, 02:04 PM   #16
The One The Only
rhion82's Avatar
Originally Posted by USCoastGaurd12 View Post
Yeah I trimmed above that a few inches nothing noticeable.
Old 12-22-2011, 02:12 PM   #17
Super Mod!
BlueTaco07 is one of the sharper tools in the shedBlueTaco07 is one of the sharper tools in the shedBlueTaco07 is one of the sharper tools in the shedBlueTaco07 is one of the sharper tools in the shedBlueTaco07 is one of the sharper tools in the shedBlueTaco07 is one of the sharper tools in the shedBlueTaco07 is one of the sharper tools in the shedBlueTaco07 is one of the sharper tools in the shedBlueTaco07 is one of the sharper tools in the shedBlueTaco07 is one of the sharper tools in the shedBlueTaco07 is one of the sharper tools in the shed
BlueTaco07's Avatar
BlueTaco07's Tacoma Gallery
Not bad. I have those tires with a 3" lift. Rubs on full turn but thats about it
Old 12-22-2011, 08:10 PM   #18
Frostbyte is one of the sharper tools in the shedFrostbyte is one of the sharper tools in the shedFrostbyte is one of the sharper tools in the shedFrostbyte is one of the sharper tools in the shedFrostbyte is one of the sharper tools in the shedFrostbyte is one of the sharper tools in the shedFrostbyte is one of the sharper tools in the shedFrostbyte is one of the sharper tools in the shedFrostbyte is one of the sharper tools in the shedFrostbyte is one of the sharper tools in the shedFrostbyte is one of the sharper tools in the shed
Frostbyte's Avatar
Law Enforcement:
Frostbyte's Tacoma Gallery
you running 285/70/17?
Old 12-23-2011, 05:25 PM   #19
Yea
Old 12-23-2011, 05:32 PM   #20
The One The Only
rhion82's Avatar
2.5 inch lift and 285s, these fit? sambojee Wheels & Tires 12 10-03-2011 09:52 PM
285s with no lift or <2" lift... toyo freak 2nd Gen. Tacomas 7 01-10-2011 04:34 AM
No Lift 285s?? tacoma1 2nd Gen. Tacomas 11 01-03-2011 07:17 PM
Can I run 285s until my lift comes in? jcleve Wheels & Tires 3 12-15-2010 03:53 PM
3" lift with 285s achirdo Wheels & Tires 8 04-15-2010 06:39 PM
