LSC15's 95 Tacoma 4x4
TPMS troubles sort of
* Tire Finding Tools Thread Tools Search this Thread Display Modes
Old 02-21-2012, 12:15 PM   #1
Backmarker [OP] Backmarker is offline
Tinkerer
Backmarker is on a distinguished road
Backmarker's Avatar
Backmarker's Tacoma Gallery
I just purchased new rims to replace the 16" steel wheels that came on my 09 Tacoma 4x4 AC. I went with these:
I ordered them online from DiscountTireDirect.com.
When I went to have my tires put on the new rim, the stock TPMS sensors would not work. The seal at the valve stem would not flush out therefore the tire would not hold air.
I called DiscountTireDirect and told them about my TPMS problem. The advisor asked me if anyone had called me after I placed my order asking me about the TPMS. I said no, because no one had. He said he would comp me a full bracket style TPMS system to go with the new rims because of their mistake. Outstanding customer service, they rock.
Now to the point of my thread. As I was speaking to the unnamed tire guy, he said in the past, when he has run into this problem on other vehicles, as well as Tacomas, he has pulled the valve stem internals from the stock Tacoma TPMS sensors, taped each sensor, sans valve stem internals, to the inside of the rim, then ran regular valves on the rim itself.
The unnamed tire guy said that it works just as well as having the sensor in the stock position because it senses air pressure only regardless of its position.
I told him that I would wait for the new sensors to arrive, thank you anyways, but I thought I would pass along this info incase someone runs into this issue like I had, and cannot get ahold of new TPMS sensors.
***No idea if it would actually work like he said it will, havent tried it, but this is for information only. ***
Thoughts?
Old 02-21-2012, 12:20 PM   #2
Pasti-Dip Free Since 1983
Pugga's Avatar
Pugga's Tacoma Gallery
There are companies that make steel straps to strap the sensor to the inside of the rim like you said. I wouldn't simply tape it in because it if comes loose it'll get destroyed in the tire and probably make a hell of a racket when it does.
Old 02-21-2012, 12:45 PM   #4
KPT KPT is offline
sees what you did there.
KPT's Avatar
KPT's Tacoma Gallery
I have the TPMs straps, Discount tire installed them for me. No issues after 40K miles and multiple dismounts of individual tires.
Old 02-21-2012, 12:56 PM   #5
Skadumz is on a distinguished road
Skadumz's Avatar
Marines:
Skadumz's Tacoma Gallery
When i was shooping for Wheels I found out that most all new wheels made come with the new angles due to many wheels coming with the system from factory. Only if you are taking the TPSM from an alloy to an alloy or a steel to a steel. But the dealer spoke of the strap and he said they use them alot with no issues. But there are many different options and to buy new ones at the right angle just arent worth it.
Old 02-22-2012, 06:28 AM   #6
Tinkerer
Backmarker's Avatar
I just have to be patient, again, and wait for the new sensors to come in. I have a lift waiting to be put on but I wanted to get the new rims on first. Thanks for all of the info.
Old 02-22-2012, 05:37 PM   #7
Tinkerer
Backmarker's Avatar
Got my TPMS straps in the mail today, going to try again to get the wheels put on tommorow.
Old 02-27-2012, 08:37 AM   #8
Tinkerer
Backmarker's Avatar
Here are some before and after pics..
Before:
After:
And all did not go well with the installation. The TPMS straps that DiscountTireDirect.com sent me did not work with the stock TPMS sensors from the steel wheels.
I called my local Toyota dealer for info. What they said was the steel rims use a sensor that has a 20 degree angled valvestem, and the alloy sensors have a 40 degree angled valvestem. The cost? $116 per sensor.
So I called Americas Tire store and they had TPMS sensors. I drove there, 35 minutes one way, and had them test fit the sensors in my new wheels. They fit and were $60.00 per wheel. So I sucked it up and bought them. 1/2 the cost of Toyota sensors.
I went back to my local tire place, again, 35 minutes one way, and had them install the tires on my new rims.
All is well? Nope, they could not reset the TPMS monitor in the truck, it had to be done through the OBD plug, which they did not have.
SOOOO, 35 minutes back to Americas Tire and they reset them for free.
My 8am tire appointment was completed at 1:30pm. Long day but I love my new rims. This week, the lift install....
TPMS troubles sort of-imag0243.jpg   TPMS troubles sort of-imag0259.jpg   TPMS troubles sort of-imag0260.jpg   TPMS troubles sort of-imag0254.jpg
Display Modes
New name, old member (sort of) jbrandt New Members 5 02-13-2011 09:09 AM
Sort tarheelfan_08 Technology 25 03-07-2010 07:55 AM
New guy, sort of... SilverStreak05 New Members 4 02-26-2010 08:28 PM
I'm Back (sort of) FLtaco4x4 2nd Gen. Tacomas 8 12-13-2009 03:34 PM
New here (sort of)... 09WhiteTaco4x4 New Members 9 07-19-2009 04:51 PM
