3" lift, stock rims, tire size?
Old 03-10-2012, 07:46 PM   #1
TRD11 [OP] TRD11 is offline
TRD11 is on a distinguished road
TRD11's Tacoma Gallery
I am going to install a 3" lift. Leaving the stock 16" Baja wheels. I do not want to have to cut or trim anything. Are 285/75/16's a safe bet? If I need wheel spacers, what millimeter thickness? What size could I get away with without spacers?
Thanks!
Old 03-10-2012, 07:48 PM   #2
near the Tannhauser Gate
OZ-T's Avatar
OZ-T's Tacoma Gallery
255/85/16
For 285/75/16 you will need wheel spacers like Spidertrax 1.25" and you will still need to trim the inner fender , remove the mud flaps and maybe trim the cab mount
Old 03-10-2012, 07:54 PM   #3
"The Situa-Seen"
sean266 is one of the sharper tools in the shedsean266 is one of the sharper tools in the shedsean266 is one of the sharper tools in the shedsean266 is one of the sharper tools in the shedsean266 is one of the sharper tools in the shedsean266 is one of the sharper tools in the shedsean266 is one of the sharper tools in the shedsean266 is one of the sharper tools in the shedsean266 is one of the sharper tools in the shedsean266 is one of the sharper tools in the shedsean266 is one of the sharper tools in the shed
sean266's Avatar
sean266's Tacoma Gallery
Originally Posted by OZ-T View Post
255/85/16
This. It's what I did
Old 04-25-2012, 03:37 PM   #4
TJ'sTOYCOMA
tmreyes1 is one of the sharper tools in the shedtmreyes1 is one of the sharper tools in the shedtmreyes1 is one of the sharper tools in the shedtmreyes1 is one of the sharper tools in the shedtmreyes1 is one of the sharper tools in the shedtmreyes1 is one of the sharper tools in the shedtmreyes1 is one of the sharper tools in the shedtmreyes1 is one of the sharper tools in the shedtmreyes1 is one of the sharper tools in the shedtmreyes1 is one of the sharper tools in the shedtmreyes1 is one of the sharper tools in the shed
tmreyes1's Avatar
tmreyes1's Tacoma Gallery
Did you HAVE to do the cab mount chop. I am running BFG 285/75/16 TA KO 3 inch Toytec lift and slightly rubbing the control arm.
Old 04-26-2012, 05:46 PM   #5
Do you have stock wheels? You can get 1-1.5 inch wheel spacers and that will take care of your control arm rubbing issues.
Old 04-27-2012, 12:51 PM   #6
TJ'sTOYCOMA
tmreyes1's Avatar
Ordered the spidertrax 1.25. Will be here tomorrow
Old 04-28-2012, 02:06 PM   #7
Nice, did you order all four or just two for up front?
Old 04-29-2012, 10:19 AM   #8
TJ'sTOYCOMA
tmreyes1's Avatar
Ordered all 4 from toytec. Cheaper than the spidertrax Web site since toytec accepts the RE coupon code. Installing today and will put pics
Old 04-30-2012, 02:43 AM   #9
Longtime Toyman
4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed
4Wheelin4Banger's Avatar
Navy: DDG 996
Location: Ferntucky, NV Halfway between Reno & Falabama
4Wheelin4Banger's Tacoma Gallery
I have a full 3" lift front & rear with OME 885s & Dakars.
255/85/16 BFG KM2s on 1st Gen TRDs. No trimming or rubbing.
Old 05-04-2012, 07:59 AM   #10
What is the RE coupon code?
Old 05-05-2012, 08:34 AM   #11
TJ'sTOYCOMA
tmreyes1's Avatar
Spacers installed and no trimming needed and no vibrations
Old 05-05-2012, 02:14 PM   #12
Looks good. What width size did you go with...1.25"? Also, what is the RE coupon code?
Old 05-06-2012, 05:15 PM   #13
Never mind, found it!
max tire size on stock 17" rim with 2.5-3" lift KRich Wheels & Tires 32 04-08-2014 03:05 PM
biggest tire with stock rims and 4.5" lift kuntry09 Wheels & Tires 6 06-28-2011 05:55 PM
3" Toytec Lift- Largest Tire on Stock 17 Rims NathanielG11 Suspension 1 02-22-2011 05:31 PM
best tire for 3" lift stock rims? sledneck207 Wheels & Tires 6 10-03-2010 10:24 AM
1.75" up front TSB in rear, stock rims, biggest tire size possible? zero niner Wheels & Tires 1 03-04-2009 06:00 PM
