2-1/2 in leveling kit biggest tires that can fit?
Old 03-13-2012, 01:47 PM   #1
Stickyleek [OP] Stickyleek is offline
Stickyleek is on a distinguished road
Stickyleek's Tacoma Gallery
Putting on a 2-1/2 leveling kit on a 2004 double cab prerunner.... looking at the nitto grappler i know i can fit the LT265/75R16 (measures at 31 and a half and 10 and a half wide) but i would like to go bigger. There is a bigger terra grappler but it measures in at slightly over 32 and a half inches and a little over 11 and a half inches wide. Truck is also on stock rims. Will the bigger tires fit?
Old 03-13-2012, 07:46 PM   #2
rossivey is on a distinguished road
rossivey's Tacoma Gallery
i doubt they'll fit without some trimming.
Old 03-13-2012, 07:50 PM   #3
TACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shed
Firefighter:
TACOMABOSS's Tacoma Gallery
What back spacing do your stock wheels have? If they are like mine the tires should fit. i have 32x11.5 tires with a 2 inch lift and they dont rub
Old 11-21-2014, 12:42 PM   #4
TT2013 is on a distinguished road
Navy: PO1/E-6
TT2013's Tacoma Gallery
I have a 2 1/2" lift front and back level with 265/70/16 can I go 315/75/16?
Old 11-21-2014, 01:50 PM   #5
Salesman by trade, Gentleman by habit
Mr. Biscuits is one of the sharper tools in the shedMr. Biscuits is one of the sharper tools in the shedMr. Biscuits is one of the sharper tools in the shedMr. Biscuits is one of the sharper tools in the shedMr. Biscuits is one of the sharper tools in the shedMr. Biscuits is one of the sharper tools in the shedMr. Biscuits is one of the sharper tools in the shedMr. Biscuits is one of the sharper tools in the shedMr. Biscuits is one of the sharper tools in the shedMr. Biscuits is one of the sharper tools in the shedMr. Biscuits is one of the sharper tools in the shed
Mr. Biscuits's Avatar
Mr. Biscuits's Tacoma Gallery
OK boys let's beat this dead horse one more time.
lifting doesn't change the biggest size you can run. Full compression is full compression regardless of average ride height.
The biggest you can ride ever? 265/75r16
The biggest you can ride most of the time without much modification or rubbing? Probably around a 32x11.5r16 which I'm not sure has a metric equivalent.
Old 11-21-2014, 01:56 PM   #6
DCSBMGMORFTMFW
geekhouse23 is one of the sharper tools in the shedgeekhouse23 is one of the sharper tools in the shedgeekhouse23 is one of the sharper tools in the shedgeekhouse23 is one of the sharper tools in the shedgeekhouse23 is one of the sharper tools in the shedgeekhouse23 is one of the sharper tools in the shedgeekhouse23 is one of the sharper tools in the shedgeekhouse23 is one of the sharper tools in the shedgeekhouse23 is one of the sharper tools in the shedgeekhouse23 is one of the sharper tools in the shedgeekhouse23 is one of the sharper tools in the shed
geekhouse23's Avatar
geekhouse23's Tacoma Gallery
An aggressive CMC, ditch wheel well liners front and rear, beat the pinch welds in the front flat, sure. Local guy here is running 315s on 2.75-3" lift. Depending if you have stock UCAs, going to need wheel spacers.
Biggest tire on stock rim with fat Bob's leveling kit (5lug) 05RedTaco Wheels & Tires 9 11-01-2010 12:14 PM
what size tires will fit under a leveling kit? irontaco Wheels & Tires 5 01-29-2010 04:48 AM
Biggest tires i can fit? DaytonLax14 Wheels & Tires 1 11-28-2009 06:05 PM
2.5" leveling kit w/stock rims whats biggest tire i can run. abnranger80 Wheels & Tires 2 02-26-2009 09:24 PM
Leveling kit and TSB what size tires will fit? rwcfrank Wheels & Tires 1 11-02-2008 12:54 PM
