BS/Offset???Confusing? I thinks so....
Old 03-17-2012, 08:10 PM   #1
60guy [OP] 60guy is offline
BADASS
60guy is on a distinguished road
60guy's Avatar
Army: UH-60/C-12/RC-12 Pilot
60guy's Tacoma Gallery
I'm looking at some Dick Cepek DC-2s in 17x9 for my DCSB Off-Road.
My question is how much farther will they stick out vs. the OEM TRD Off-Road wheels
TRD Off-Road Wheels:
16x7
+32 mm offset
5.25" backspacing
DC-2s:
17x9
- 12 mm offset
4.5" backspacing
I looked at the BS and Offset sticky and tried to do the math, but I'm still confused.....
Old 03-18-2012, 08:19 AM   #2
KPT KPT is offline
sees what you did there.
KPT's Avatar
KPT's Tacoma Gallery
16x7
+32 mm offset
5.25" backspacing
DC-2s:
17x9
- 12 mm offset
4.5" backspacing
They will stick out 2.75" more than stock. 0.75 from backspacing, 2" from width
Old 03-18-2012, 09:58 AM   #3
Cvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shedCvd2312 is one of the sharper tools in the shed
Cvd2312's Tacoma Gallery
I think it would be more like 1.75" further than stock. The 2" wider wheel width doesn't all go to the outside, it also goes inside and sits closer to the frame and suspension.
Old 03-18-2012, 10:01 AM   #4
KPT KPT is offline
KPT's Avatar
Backspacing already takes the spacing on the inside into consideration. So all of the extra width gets added to the outside.
Old 03-18-2012, 10:06 AM   #5
kane is one of the sharper tools in the shedkane is one of the sharper tools in the shedkane is one of the sharper tools in the shedkane is one of the sharper tools in the shedkane is one of the sharper tools in the shedkane is one of the sharper tools in the shedkane is one of the sharper tools in the shedkane is one of the sharper tools in the shedkane is one of the sharper tools in the shedkane is one of the sharper tools in the shedkane is one of the sharper tools in the shed
kane's Tacoma Gallery
THIS is correct
Old 03-18-2012, 10:06 AM   #6
KPT KPT is offline
KPT's Avatar
I.e. if you add some of the width to the outside, and some to the inside, you have now changed the backspacing.
Old 03-18-2012, 10:20 AM   #7
The offset is what gives you the appearance of the "dish" of the wheel ... high neg offset will give you a "Deep Dish " look
.... of course the bs is part of this too.... large bs will not allow a high neg offset
Old 03-18-2012, 11:02 AM   #8
BADASS
60guy's Avatar
So it looks like 2.75"s farther. Do you think this is too much? Or will it be good to go. I want them to stick out a little more, but don't know if the 2.75" will make them stick out too far???
Old 03-18-2012, 11:06 AM   #9
KPT KPT is offline
KPT's Avatar
What size tire do you want to run and on how much lift?
Old 03-18-2012, 11:10 AM   #11
BADASS
60guy's Avatar
Going with 265/70R17 Hankook ATMs. I have th Eibach 1.6" springs up front w/5100s set to 0.0, and TSB springs with additional 1.5" add a leaf in the rear.
Old 03-18-2012, 11:29 AM   #12
KPT KPT is offline
KPT's Avatar
Should be good to go. Are the 265/70 ATMs approved for 9" wide wheels
Old 03-18-2012, 11:33 AM   #13
BADASS
60guy's Avatar
Yes they are. That is why I am going with them. Was looking at Duratracs but the are only good up to 8.5" wheels.
Old 03-18-2012, 01:03 PM   #14
Member Caught Off Road
AWorthyOpponent is one of the sharper tools in the shedAWorthyOpponent is one of the sharper tools in the shedAWorthyOpponent is one of the sharper tools in the shedAWorthyOpponent is one of the sharper tools in the shedAWorthyOpponent is one of the sharper tools in the shedAWorthyOpponent is one of the sharper tools in the shedAWorthyOpponent is one of the sharper tools in the shedAWorthyOpponent is one of the sharper tools in the shedAWorthyOpponent is one of the sharper tools in the shedAWorthyOpponent is one of the sharper tools in the shedAWorthyOpponent is one of the sharper tools in the shed
AWorthyOpponent's Avatar
AWorthyOpponent's Tacoma Gallery
http://www.rimsntires.com/specs.jsp
Play with it.
ET = Offset
Old 03-18-2012, 01:17 PM   #15
BADASS
60guy's Avatar
Play with it.
ET = Offset
Dude, that is AWESOME! According to this they new set up will stick out 1.7" more then the OEM set up, which is pretty much exactly what I'm looking for.
That tool should be sticked or something! And Rep points for you!
Old 03-18-2012, 01:45 PM   #16
KPT KPT is offline
KPT's Avatar
Nice tool indeed. And the discrepancy between what I told you and what it tells you for "how much more it will stick out" is that I was referring to the wheel only. Their calculator uses the tire too. Because the tire is stretched more (9" vs 7"), it will not stick out as far out from the wheel as the stock setup does from the wheel. .
Old 03-18-2012, 01:56 PM   #17
BADASS
60guy's Avatar
Yes, I noticed the difference once once the tire was added in as well. The 1.7" with the whole set up made me feel much better then the 2.75" with just the wheel.
Thanks again!
Old 03-18-2012, 01:57 PM   #18
KPT KPT is offline
KPT's Avatar
Thanks again!
No problem
17x9 +10 offset 5.4 bs alpooch New Members 1 08-05-2011 10:50 AM
5"BS x Zero offset, 20x9? Blkturbo! Wheels & Tires 7 01-16-2011 10:26 AM
17x9 6x139.7 with 4.75" of BS and -6 offset CaptMorgan Wheels & Tires 14 11-08-2010 12:16 PM
BS and Offset for 18x9 XD Monsters: roxspin72 Wheels & Tires 15 04-30-2010 07:37 PM
Will 4.75 bs & 0 offset work? Drock42 Wheels & Tires 1 09-24-2009 06:31 AM
