Spare tire carrier
Old 12-18-2008, 07:49 AM   #2
mjp2's Avatar
mjp2's Tacoma Gallery
Looks like one of the more study products I've seen. The design seems solid and the price is definitely right.
What's got you hesitant about pulling the trigger?
Old 12-18-2008, 07:57 AM   #3
longbow [OP] longbow is offline
I see you now..................
longbow is one of the sharper tools in the shedlongbow is one of the sharper tools in the shedlongbow is one of the sharper tools in the shedlongbow is one of the sharper tools in the shedlongbow is one of the sharper tools in the shedlongbow is one of the sharper tools in the shedlongbow is one of the sharper tools in the shedlongbow is one of the sharper tools in the shedlongbow is one of the sharper tools in the shedlongbow is one of the sharper tools in the shedlongbow is one of the sharper tools in the shed
longbow's Avatar
longbow's Tacoma Gallery
My tire/wheel combo I am running, 16X8 wheels and 285/75/16's BFG M/T's. Now I know it would work, issue is I am trying to keep my cover on.
It's an Undercover, but I believe I am peeing in the wind sort of speaking.
I need to weigh out all the options.
I need to figure the width of the wheels, (inflated) to see how much clearance I would have. I believe the hold down screw bar will be the issue, but then again "don't know" and I need to do something, I NEED the full size spare.
Old 12-18-2008, 08:05 AM   #5
Hardcore wheeler, try and keep up.... if you can.
SnoBoarder has much to be proud ofSnoBoarder has much to be proud ofSnoBoarder has much to be proud ofSnoBoarder has much to be proud ofSnoBoarder has much to be proud ofSnoBoarder has much to be proud ofSnoBoarder has much to be proud ofSnoBoarder has much to be proud of
SnoBoarder's Avatar
SnoBoarder's Tacoma Gallery
The Flat Version of this for $65, right?
I'd want to see the topside and bottom side mounting plates. My TireGate Flat Mount is solid, about $155 shipped.
The Top Mounting Plate:
The Bottom Mounting Plate fits perfectly.
An included D-Ring on the Top Plate and a D-Ring welded on the V Bar allows the use of the included steel security cable to secure the V Bar and the wheel, or at least help deter theft:
I think the TireGate Flat Mount is well worth it, very high quality, high strength and good fitment. My bed is empty 99% of the time so I have no issues with the spare there and the wheel can be removed in 1 minute. I also removed the OEM spare from underneath.
Old 12-18-2008, 08:09 AM   #6
mjp2's Avatar
I've got a solution for you if the tire fits in the bed by itself.
Figure out where you want the thing, mount 3 anchors in the bed around the tire, and use a Y-strap to hold it in place. Mine's tied into the cage but you'll get the idea:
Make sure those anchors are solid because there will be a lot of stress on 'em and I'd hate to hear that one tore through the composite bed. That issue aside, this should work for you.
KarTek (http://www.kartek.com) usually has the straps in stock. They'll know what you're talking about when you call.
Old 12-18-2008, 08:12 AM   #8
mjp2's Avatar
Originally Posted by SnoBoarder View Post
Looks great! Does any of that stick up above the bedrails when it's all in place?
Old 12-18-2008, 08:17 AM   #10
SnoBoarder's Avatar
Thank you. My Access LiteRider rolls over top and hides the Hi Lift, Spare and a fuel and water jerry can not shown.
Old 12-28-2008, 01:08 PM   #12
SnoBoarder's Avatar
17x9 DC-1 with a 285/70/17 Nitto TG
Old 12-28-2008, 01:11 PM   #14
Machine gun shits
paintdiddy is one of the sharper tools in the shedpaintdiddy is one of the sharper tools in the shedpaintdiddy is one of the sharper tools in the shedpaintdiddy is one of the sharper tools in the shedpaintdiddy is one of the sharper tools in the shedpaintdiddy is one of the sharper tools in the shedpaintdiddy is one of the sharper tools in the shedpaintdiddy is one of the sharper tools in the shedpaintdiddy is one of the sharper tools in the shedpaintdiddy is one of the sharper tools in the shedpaintdiddy is one of the sharper tools in the shed
paintdiddy's Avatar
paintdiddy's Tacoma Gallery
i fukn luv this truck.
spare tire carrier dirty dangler Southern California 21 03-03-2011 06:29 AM
Spare tire carrier Pugga Wheels & Tires 6 11-30-2010 05:15 PM
spare tire carrier 7tac0ma7 1st Gen. Tacomas 5 10-17-2010 04:23 PM
Spare Tire Carrier AR_Taco Wheels & Tires 1 06-10-2009 09:41 AM
Spare Tire Carrier longbow Wheels & Tires 2 07-29-2008 05:15 PM
