what could be wrong with my Pro comps?
Discussion in 'Wheels & Tires' started by Scope3334, May 3, 2012.
  1. May 3, 2012 at 1:12 PM
    Scope3334
    Scope3334 [OP] Well-Known Member
    Maryland
    2012 White Tacoma TRD Sport
    Aries Bull bar, Westin Nerf bars, WeatherTech Deflectors, OEM Roof Rack
    So i just got new 17x8 pro comp 7089 wheels with 265/70/17 nitto terra grapplers put on today. I love the wheels and tires but i have noticed a vibration in the stearing wheel and seats. I do not have a lift kit installed yet but want to know what i can start to do to fix the problem. Any help would be great.
  2. May 3, 2012 at 1:16 PM
    jberry813
    Jason
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Tire's aren't balanced correct.
    Road force balance the tires.
  3. May 3, 2012 at 1:20 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    X2 Go to a another tire shop and let them balance it
  4. May 3, 2012 at 3:00 PM
    Scope3334
    Maryland
    For the pro comp 7089 17x8 does anyone know what hub centric rings I would need. Have been doing reading and I think this will help. However I can not find the hub centric ring size.
  5. May 3, 2012 at 3:23 PM
    jberry813
    Jason
    Lake Tahoe
    2012 DCSB Sport
    Toyota hubs are too big. The hub centric rings are for chevy's.
    Like I said before, the problem is with the balance. Factory wheels are hub centric. Most aftermarket wheels are lug centric. Whoever did your balance most likely ran you gear through a hub centric spin without putting on a lug adapter, let alone doing a road force balance.
    Find someone close by that has a Hunter Road Force balancer and you'll be set.
    http://www.gsp9700.com/search/findgsp9700.cfm
  6. May 3, 2012 at 5:24 PM
    Scope3334
    Maryland
    Nice 10 miles from my house is a place that can do it, Thanks so much. tomorrow ill post pics of my vehicle if i get the lift on.
  7. May 3, 2012 at 5:30 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    Steve
    San Jose CA
    '11 Std Cab 4x4 5sp
    Feh. Don't do it. Don't compound your problems. Fix your tire/wheel related vibration first. THEN install your lift.
    One problem at a time to identify fix and solve is much easier than multiple complicating unintended consequences.
  8. May 3, 2012 at 6:24 PM
    Scope3334
    Maryland
    Well even more reading and i think the problem my also be because of my lugnuts. They installed non shanked lugnuts. The ones in the pics are what they installed.Would it be worth it to buy shanked?
    43020d1304788363-lug-nuts-procomp-7089-n_0dd9d0fbba667cd1b79b85b1884901ac2b347bb5.jpg
  9. May 3, 2012 at 6:26 PM
    jberry813
    Jason
    Lake Tahoe
    2012 DCSB Sport
    That shouldn't cause a balance problem, but you should definitely running extended thread lugs with aftermarket wheels.
  10. May 3, 2012 at 6:27 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    If your thread engagement is less than the diameter of the stud, you are at risk of losing a wheel.
  11. May 3, 2012 at 6:48 PM
    Scope3334
    Maryland
    So i just bought these. Hope there better? Also does it matter that my tires stock where 265/65/17 and now i have 265/70/17?
  12. May 23, 2012 at 5:09 PM
    Doug2000
    Doug2000 Well-Known Member
    London, Ontario, Canada
    2017 Tundra 5.7L
    Did you get it fixed, if it's not the balance, the wheel center could be off, the quality control of wheels is really poor, my dealer said he recently sent back 2 of 4 wheels because the wheel center was off.
    The machine shop I used to work at couldn't make a set of wheels for less than $5000, how do you sell a wheel for $145, and make a profit.
  13. May 23, 2012 at 11:30 PM
    DevL
    DevL Well-Known Member
    You buy from china like everyone else
  14. May 24, 2012 at 7:56 AM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
  15. May 24, 2012 at 8:16 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    This is kind of a silly argument... how many people do you know that spend $5,000 on a set of wheels unless they're racing and need perfect tolerances?
    If your machine shop were set up for high volume production, and not a one time thing, they could make a set of wheels for WELL under $5k.
  16. May 24, 2012 at 5:47 PM
    MGMAddict
    MGMAddict Well-Known Member
    Doylestown,PA
    TRD Sport
    Bilstein ULC
    I have pro comps, hub rings are needed at least for mine they were a 106mm to 108mm I think. Fixed all my issues. Problem is even though our trucks are lug centric the skinny lugs aren't enough to fully center and support the wheel hence the vibrations. If you look the oem lugs you'll see why.Plus try and use thicker wheel weights for truck tires, more weight in the area needed for the weight so the shop is constantly not counter balancing just my 2 cents.
  17. May 24, 2012 at 5:48 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    my guess its because your wheels are:
    not balanced correctly
    they are not hub centric
    and a combo of the above
