Ahhh Help I Am Dizzy
Discussion in 'Wheels & Tires' started by cfenn, Dec 23, 2008.
  1. Dec 23, 2008 at 5:01 PM
    cfenn
    cfenn [OP] Well-Known Member
    San Antonio, Texas
    PreRunner
    TRD exhaust,TSB, 5100's on the front, 884 springs, Total Chaos UCA, 5100's on the rear, Wheelers HD rear springs , Nitto 285/70/17's on MB TKO 17x8.5's
    Been searching and searching the forum but I need an answer. I have 5100's set at 2.5 and the TSB. 38" at the fender but I can not decide on 265/70/17 or 285/70/17... Will the 285's fit?
  2. Dec 23, 2008 at 5:17 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    285s will fit. You may have some slight rubbing on the inner fender, so you'll have to trim some of that.
    If you're running stock wheels, you'll need spacers so your wheels don't rub the UCA.
    265s will fit no problem.
  3. Dec 23, 2008 at 5:22 PM
    rick
    rick `
    true that
  4. Dec 23, 2008 at 5:24 PM
    cfenn
    San Antonio, Texas
    PreRunner
    Getting 17X8's or 17X9's what ever is needed... No problem with trimming
  5. Dec 23, 2008 at 6:37 PM
    Delmarva
    Tucson, AZ
    sounds like you'll be good then :D
    post pics when you get it all done.
  6. Dec 26, 2008 at 9:26 PM
    cfenn
    San Antonio, Texas
    PreRunner
    Ordered today should be here early next week pics to come:)
  7. Jan 2, 2009 at 3:43 PM
    cfenn
    San Antonio, Texas
    PreRunner
