CHALK TEST: Dynapro ATm at 16,000 miles
Discussion in 'Wheels & Tires' started by David K, Jun 27, 2012.
  1. Jun 27, 2012 at 3:09 PM
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Differential Breather Mod Light Bar: 4 Cree LED lamps Bilstein 5100s Ride Rite Air Bags
    I did this test a couple months ago, and the subject came up in another thread, and it took me forever to find this reply I did... So, I am creating a new thread so I can find it and for anyone interested in what a tire wear chalk test looks like, who hadn't seen it before!
    The Hankook's now have 20,000 miles on them, and look great (still)!
    Step 1, check that your tires are all at the pressure you assunme to be correct.
    For my Dynapros, they all are at 37 psi. I have (by feel) determined 36-40 psi to be a good range for these 44 psi max. tires on my lightly loaded to unloaded 4 door Tacoma.
    Step 2, with big sidewalk chalk, make a one inch bar across the tread.
    Step 3, drive for approx. 100 feet and then see how the chalk wears off.
    If it wears mostly in the center, too much air. If more wears on the outsides, then too little air. If wears is even across the tire, you are gold!
    Right Rear Before and After:
    Right Front Before and After:
    Left Front Before and After:
    Left Rear Before and After:
    There you go.... looks pretty even, yes? Maybe just a hair high? What do you think?
    FYI, these tires have 16,000 miles on them. Hankook Dynapro ATm 265/75-16.
    OH, and after doing the test, I have lowered the psi to 35 on all 4... soon I will re-test and see if we have improved wear even-ness...
    ExGunner and Jenco80 like this.
  2. Jun 27, 2012 at 3:11 PM
    PkTaco
    PkTaco Well-Known Member
    David
    Zanesville Ohio
    A hair eye high. I'd leave them the way you've got them though.
  3. Jun 27, 2012 at 3:11 PM
    xgalvanxgx
    xgalvanxgx seymour butts
    Gerardo
    OC (Lake Forest) California
    TRD Off-Road BlackSandPearl 07 PreRunner
    DTF Race Kit with 2.5 x 10 Kings, DMZ SUA rear with 16" triple bypass Kings, King bumpstops front and rear, 17" KMC RG1 powdered in Matte Bronze with black ring with 37" BFG KO2s, front and rear DTF bumpers, front Fiberwerx glass and Mcneil trophy bedsides, K&N 77 Series Intake, Magnaflow, Pioneer touchscreen, Rockford Fosgate 10" sub with box and amp. Dyanamat walls, Andres' devil horn emblem, 50" D4 curved LED bar, rear chase light rack (brake, ambers, white lights) Engine brace, deleted inner wheel wells for max up travel. Cab roll rage built into bedcage.
    STEP 1: find your little nieces chalk**
    Bleep100 likes this.
  4. Jun 27, 2012 at 3:31 PM
    David K
    Thank you, however, as I said these photo were taken last April and because it showed a bit over-inflated at 37 psi, I dropped to 35 psi. It has been 4,000 miles... everything is doing great. I may do a new Chalk Test at 5,000 miles to see if the wear is a bit more even.
  5. Jun 27, 2012 at 3:39 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    I'd say you're good - the edges of front tires wear faster than the centers anyway due to the act of turning, so it might be perfect to offset that a bit by a pattern that your tires exhibit.
    I would venture to say that the chalk test is a good test for overpressure, but tires inflated below pressure would still wear the chalk evenly, yes? The only way that you could tell would be if the tires are so low they exhibit "cupping", which I believe would be a drastic level of underinflation and not be evident at, say, 30 psi.
  6. Jun 27, 2012 at 3:47 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If the tire is underinflated, you'll notice the edges wearing faster than the center.
    Cupping can be caused by a lot of different things and it's not always clear what causes cupping. For instance an unbalanced tire or blown shock could cause cupping.
  7. Jun 27, 2012 at 4:03 PM
    Polymerhead
    Missouri
    Eventually, yes - but my hypothesis is that this would not show on the chalk test since a full contact patch would be maintained, even with underinflated tires.
  8. Jun 27, 2012 at 4:07 PM
    Pugga
    Massachusetts
    You're probably right in most cases unless you were severly underinflated (in which case just looking at the tires should tell you something is wrong).
    What I meant though was by the time you see the tires cupping, the outter edges will be worn if they're underinflated.
    I guess you're better off starting a little higher and backing pressure off until you get an even wear patch.
  9. Sep 29, 2012 at 9:21 AM
    David K
    The Hankook Dynapro ATms are nearing 25,000 miles... they appear to be about 50% worn... still doing fine, although I thing I hear them more than when they were new. I have had a rock puncture the same tire twice (in the same spot, so a patch failure perhaps?) and a slow leak from a hole, but no nail or ? was in the tire... that was patched.
  10. Mar 5, 2013 at 11:18 AM
    David K
    Now at 28,000 and am starting to research for the next tire purchase.
    Same tire (Dynapro ATM), but in an LT version?
    Toyo Open Country AT II?
    Falken Wild Peak/Rocky Mountain?
  11. Mar 7, 2013 at 9:54 AM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Really, getting to the end of their lives at 28K? I had the 265/70/17 Es on my runner and got about 55K out of them before they wore to the "acceptable" limit, and probably could have gotten more, but sprang for some duratracs at the beginning of winter. Maybe the LTs wear better, yours were P rated or C?
    The LTs I had were great, only one puncture with quite a bit of off road crawling use, and the puncture I did get was on a gravel road from a sharp piece of gravel that hit the tread block just right, who would have thought.
  12. Mar 7, 2013 at 10:05 AM
    WillT
    WillT Well-Known Member
    Colorado
    '21 Colorado ZR2 Bison
    Had Toyo Open Countries on my Rav4, worst tires I've ever owned. Ice skates in the winter, and very prone to hydroplaning in turns in the wet. I ditched them for Dynapro ATMs and it was a world of difference. Can't wait for my Rugged Trails to die on my Taco so I can justify upgrading to Dynapros again.
  13. Mar 8, 2013 at 1:04 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I have the 295 'kook RT03's (8 ply)
    like them a bunch...
    I have never done any chalk test
    but roll them at 34(F)/32(R) psi (street)
    They seem to be wearing good.
    When I rolled 285 KMII's (10 ply)... 33(F)/31(R) psi (street)
    they wore fairly well.
    kudos for sharing your test results [​IMG]
  14. Mar 8, 2013 at 6:33 PM
    David K
    P rated... and I am maybe over-reacting to the wear... I showed them to a friend and he said those look like new tires... I think he was trying to make me feel good?
    I guess I should take photos and post them for opinions... I like a tire to be meaty when I go off road... as I said, the thinnest tread measures 1/4" deep. I guess it can go to 1/8" (Lincoln's head), right? Again, I am thinking off road and not street or beach driving which doesn't need deep treads.
  15. Mar 8, 2013 at 6:41 PM
    David K
    Interesting... I had good luck with my ATs on my '05 Taco... 35,000 miles easy. I live near San Diego just above sea level, so no ice worries... but if I ddrive to the snow, I want them to work. The DynaPros were amazing in the snow when I took them out in it 2 years ago, when they were new.
    The TOYO Open Country AT II's look really better than the orignials, so that's why I considered them... as I would Cooper Discoverer ATRs I also ran on my '05 Taco.
    I got rid of the Rugged Fails at 20,000 miles, after two little rock punctures (the first at 13,000 miles)!
  16. Mar 8, 2013 at 6:42 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    I'm happy with my LT Hankook ATm's
  17. Mar 8, 2013 at 6:42 PM
    David K
    How many miles on them so far OZ?
  18. Mar 8, 2013 at 6:45 PM
    OZ-T
    Peter North
    British Columbia
    I will check my invoice from the shop and let you know
  19. Mar 8, 2013 at 6:46 PM
    David K
    Cool, and if your truck is using KILOMETERS, I know how to convert! :D
  20. Mar 8, 2013 at 7:13 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Nice ongoing analysis, David
    Thanks for sharing the Data
    CC
