Yet another backspacing question. HELP
Old 07-10-2012, 12:48 AM   #1
WillzTaco [OP] WillzTaco is offline
WillzTaco is on a distinguished road
WillzTaco's Tacoma Gallery
Ok guys. i need some help. Im looking to get some new wheels that are going to be 17x8. I called the guy today and he said that they only made them in -13mm and +10mm offset (kinda think he was wrong). I swore they made them in 0mm. So my question is the -13mm offset would be about 4" of BS and the +10mm would be about 5"BS. Im going to run a 285/70-17 MT so which offset should i get. Of course the 0mm would be the perfect 4.5'' of BS but the guy said they didnt have those. Im going to call again and ask tomorrow. But as of now, which should i get?
Old 07-10-2012, 12:51 AM   #2
RelentlessTaco's Avatar
Go with the -13/4" bs
Old 07-10-2012, 06:31 AM   #3
tacoma07pre is on a distinguished road
tacoma07pre's Avatar
Law Enforcement:
tacoma07pre's Tacoma Gallery
I just ran into the exact same situation. I went with the +10 offset because I am not planning on running a 285. If I were I would have went with the -13. There may still be rubbing issues with a 285/70 if I understand correctly.
Old 07-10-2012, 07:17 AM   #4
Hdeuce22 is on a distinguished road
Hdeuce22's Tacoma Gallery
Do you have any lift? If not,you're going to have A LOT of rubbing with that 285 and trouble getting it stuffed under the fender. You will probably even have to do some trimming with close to 3" of lift. As far as the BS,if you want that size tire then you are definitely going to want the 4"BS b/c if not,you will be all up on your UCA at that point.
Old 07-10-2012, 11:24 PM   #5
Oh yea i forgot to mention the lift info. Im running a 3'' toytec ultimate lift right now
Old 07-11-2012, 10:22 AM   #6
DevL's Tacoma Gallery
Your lift has zero to do with rubbing... just how much compression till rubbing occurs.
Old 07-11-2012, 10:25 AM   #7
You say they and them... some wheels are made in a 0 offset some are not. Your description of "they / them" wheels is not enough to know if you can get 0 offset.
Old 07-11-2012, 10:47 AM   #8
Lord of War
KenLyns's Avatar
KenLyns's Tacoma Gallery
The "8" in 17x8" is measured from the inside of the rim lip, where the tire bead seats. BS is measured from the outside of the rim lip to the hub face. Depending on rim design, 17x8" with 0mm offset could be 4.25", 4.5", 4.7" BS... You need to get the actual BS from the seller or ask him to take measurements (easy to do with a ruler or tape).
+10 mm offset won't work (i.e. tire will rub on UCA). -13 mm is less backspacing than you need, so UCA will have good clearance, but the tire will rub more on the fender flare or cab mount.
Old 07-12-2012, 04:55 PM   #9
Well, i think ill go with the -13 then. Here they are in case you all were wondering
[/url][/IMG]
Old 07-12-2012, 05:30 PM   #10
Law Enforcement:
Those are the same wheels I just ordered in 17x8 +10 offset. I did so because I have no desire to run 285s because of the necessary trimming. With the +10th 265s work great and look really good too. If you don't mind the trimming with 285s then do the -13 offset.
Old 07-12-2012, 10:26 PM   #11
Can i asked where you ordered them from? Ever one i talk to doesnt have them yet
Old 07-12-2012, 10:28 PM   #12
Bam-Ba-Lam
Detective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shed
Detective_Dan's Avatar
Air Force: SSgt - A.G.E. Mechanic
Detective_Dan's Tacoma Gallery
keith.......here boy......COME!!
Old 07-12-2012, 10:32 PM   #14
Bam-Ba-Lam
Originally Posted by HomerTaco View Post
He's traveling...
damnit....
wheres my dog whistle?
Old 07-14-2012, 09:18 AM   #15
Law Enforcement:
I ordered them from sd wheel Corp. The 17x8 are $525 per set shipped and arrived in 4 days from placing order. I found them on eBay and ordered over the phone for that price. I was also able to use my tpms with these wheels and ordered a black lug kit off eBay for $17 shipped. Had them installed yesterday and all is great. Very happy customer.
Old 07-14-2012, 09:20 AM   #16
Law Enforcement:
Also FYI..... The red in pictures looks like it may be an anodized look but is pretty much a direct match to radiant red.
Old 07-15-2012, 10:19 AM   #17
Are you sure the guy didn't just paint the chrome ones red? Lol also post some pics of them mounted please!
Old 07-15-2012, 03:18 PM   #18
Law Enforcement:
These are the Tuff t01 17x8 +10mm offset with 255/75/17 BFG Mud Terrain KM tires on a my 2007 Radiant Red Tacoma. I am running 5100s in the front on 0 setting with OME 885x coils and a 2" wheelers add a leaf in the rear.
Old 07-15-2012, 04:57 PM   #20
Law Enforcement:
No, no trimming necessary.
Backspacing question Yizazell Wheels & Tires 4 11-17-2011 11:01 AM
Backspacing question 207Copper 2nd Gen. Tacomas 0 11-14-2011 12:34 AM
another backspacing question supadave888 Wheels & Tires 12 07-26-2010 04:10 PM
question on wheel backspacing Hologram Wheels & Tires 0 11-26-2009 10:10 PM
another damn backspacing question crazydaze_95 Wheels & Tires 7 07-02-2009 07:59 PM
