32 or 33 inch tires?
Old 07-20-2012, 04:07 PM   #1
tristen [OP] tristen is offline
tristen is on a distinguished road
tristen's Tacoma Gallery
I can fit 32s on 16s without a rim, or should I pay extra for about a 2 in lift and get 33s on 17s? Im 16, and paying for my upgrades so im kind of on a budget. Since my truck is a prerunner and I don't do much off roadng, wouldn't it be more practical not to lift? I've also heard there's no point in lifting a 2wd truck that much. I need peoples opinions on what to do because I will be purchasing tires and rims soon. Any opinion will be appreciated!
Old 07-20-2012, 04:11 PM   #3
My bad! How do I delete this?
Old 07-20-2012, 04:14 PM   #4
Taco
superswamper003 is a name known to allsuperswamper003 is a name known to allsuperswamper003 is a name known to allsuperswamper003 is a name known to allsuperswamper003 is a name known to allsuperswamper003 is a name known to all
superswamper003's Avatar
superswamper003's Tacoma Gallery
Lots of people lift their prerunners on here. If you lift your truck, try not to buy a spacer lift as that will make your truck ride really rough.. My truck came with a 3 inch spacer lift and I cant wait to swap it out for toytecs ultimate lift kit someday really soon. 32 arnt really that much of a difference from 33s so if your just driving mostly on street, id just leave it how it is and go with 32s. Or you can go with the lift and 33s, either or
Old 07-20-2012, 04:15 PM   #5
32s will still look nice, correct?
Old 07-20-2012, 04:18 PM   #7
Locked and Lifted "02" DC TRD.
Matic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shedMatic is one of the sharper tools in the shed
Matic's Avatar
Matic's Tacoma Gallery
Id go with 285/75/16's on a 3 inch lift level kit.
881 ome coils up front, Pro comp or ather AAL in rear. OME nitrocharger shocks all the way around. your good to go.
Old 07-20-2012, 04:20 PM   #8
What kind of price am I looking at?
Old 07-20-2012, 04:21 PM   #9
Matic's Avatar
Mod should switch it to the appropriate topic soon.
Old 07-20-2012, 04:22 PM   #10
Matic's Avatar
Gimme a sec.
Do you need rims and tires or just the lift?
Old 07-20-2012, 04:30 PM   #11
Matic's Avatar
OME 881 coils. (2) $170
Pro comp AAL. (2) $40
OME Nitrochargers. (4) front-$263, rear $189
You also need a bpv bracket but you can make one pretty easy.
total. $660 plus shipping.
If thats to much you can skimp on the shocks for the front, you can use your stock ones for a lil while. And you can go with cheaper pro comp shocks on the rear.
However I think you will be unhappy with the ride if you skimp. Just save up and plan on spending the $675
Old 07-20-2012, 04:42 PM   #12
I think I might stick with the 32s, if I can sell my dirtbike id have all the money for the rims and tires, 32s and 33s don't look much different, so should I just.go for 265/75/16 or 285/75/16
Old 07-20-2012, 04:49 PM   #14
I like the look when the tires fit snug without a lift, if you know what I mean. So 265 should do fine
Old 07-20-2012, 04:54 PM   #15
Bullwinkle J. Moose
bjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shed
bjmoose's Avatar
bjmoose's Tacoma Gallery
On a budget, check.
Likes the "wheels snug in the wheelwell look," check.
Not much offroading, check.
Yeah - go with 265/75R16 tires. If you're getting rims also, be careful not to get too much "negative offset" or even the 265/75R16 won't fit.
But 265/75R16 will fit on the stock rims.
What you want is a 7.5" or 8" wide rim with +6 or +12 offset.
Old 07-20-2012, 04:55 PM   #16
Taco
I think that will be fine, you may rub a little but not sure
Old 07-20-2012, 04:56 PM   #17
Matic's Avatar
Originally Posted by bjmoose View Post
On a budget, check.
What about a standard 265/70/16?
Old 07-20-2012, 05:12 PM   #18
What is the off set mean? And the rims im looking at are 8 wide
Old 07-20-2012, 05:34 PM   #19
Matic's Avatar
http://www.wheelsnext.com/content/wheel_tech.html
Old 07-20-2012, 06:01 PM   #20
So why wouldn't I want 0 offset?
3:91 Gears and 33 Inch Tires Monkeysuncle 1st Gen. Tacomas 22 10-03-2013 03:14 PM
Do I need to regear with a 3inch lift and 33 inch tires? anasseef 2nd Gen. Tacomas 3 05-27-2011 08:43 PM
33 inch tires? GabeMazie Wheels & Tires 42 11-03-2010 01:12 PM
wtb- 33 inch tires for 17 inch rims toyotadude5 Buy / Sell / Trade 1 11-23-2009 03:46 PM
33 inch tires, what gears should i go? TacoNinja12 1st Gen. Tacomas 2 10-09-2008 09:14 PM
