Changing tire sizes on base 2012 Tacoma 4x4 from 245/75/16 to 265/70/R16
Old 07-20-2012, 07:55 PM   #1
kyleTRDtaco12 is one of the sharper tools in the shedkyleTRDtaco12 is one of the sharper tools in the shedkyleTRDtaco12 is one of the sharper tools in the shedkyleTRDtaco12 is one of the sharper tools in the shedkyleTRDtaco12 is one of the sharper tools in the shedkyleTRDtaco12 is one of the sharper tools in the shedkyleTRDtaco12 is one of the sharper tools in the shedkyleTRDtaco12 is one of the sharper tools in the shedkyleTRDtaco12 is one of the sharper tools in the shedkyleTRDtaco12 is one of the sharper tools in the shedkyleTRDtaco12 is one of the sharper tools in the shed
kyleTRDtaco12's Avatar
kyleTRDtaco12's Tacoma Gallery
My question is, is Changing tire sizes on base 2012 Tacoma 4x4 from the factory base size 245/75/16 to 265/70/R16 ok to do?? Seeing as the size i want to change to, the 265/70's is a factory size (offered on the TRD off road package) would this change cause any problems?? I was told it could possibly alter the speedometer readings and the way the transmission shifts, if it was an automatic, but I shouldn't have any transmission issues because I have a manual trans, are these statements correct?? Because I really like the look of the 265's.. And if anyone is interested, I'd like to sell the set of 245/75/16's BFG all-terrain T/A ko's I have on there now, they are brand new, only have about 700 miles on them, asking $180 per tire, bought them new for $216 per tire, please let me know, thank you!
Old 07-20-2012, 08:02 PM   #2
Banned
265/75/16s will give you more tires options and they fit with a tiny bit of rubbing on the front flaps.
Old 07-20-2012, 08:04 PM   #3
Bullwinkle J. Moose
bjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shed
bjmoose's Avatar
bjmoose's Tacoma Gallery
245/75R16 and 265/70R16 are the same diameter. It's all good. By all means swap 'em!
But, but, shouldn't you have thought of this, oh, 725 miles ago??
And as whipper sez - many folks go "oversize" to the 265/75R16 size.
Old 07-20-2012, 08:06 PM   #4
Lord of War
KenLyns's Avatar
KenLyns's Tacoma Gallery
I think the rubbing only occurs if you have 0mm offset wheels. Stock inset wheels won't rub at all, at least based on limited sample size (OZ-T, for example).
Old 07-20-2012, 08:08 PM   #5
Banned
Just giving a warning anyway because I have seen some members claim that the 265/75s rub.
Old 07-20-2012, 08:10 PM   #6
TRUCK YEAH
Saskquatch11 is one of the sharper tools in the shedSaskquatch11 is one of the sharper tools in the shedSaskquatch11 is one of the sharper tools in the shedSaskquatch11 is one of the sharper tools in the shedSaskquatch11 is one of the sharper tools in the shedSaskquatch11 is one of the sharper tools in the shedSaskquatch11 is one of the sharper tools in the shedSaskquatch11 is one of the sharper tools in the shedSaskquatch11 is one of the sharper tools in the shedSaskquatch11 is one of the sharper tools in the shedSaskquatch11 is one of the sharper tools in the shed
Saskquatch11's Tacoma Gallery
I have 265/75/R16s with stock suspension in the front, no rubbing.
Old 07-20-2012, 09:16 PM   #7
well i do not want to oversize, but excuse my ignorance here but they really do have the same rolling diameter?? but, how is that so? because im under the impression that, the first number, the 265 is wider than the 245, and (this is where the difference is mde in my head) that the 75 side wall is bigger than the 70 sidewall?? so isnt the rolling diameter smaller on the 265/70/r16's?? just curious because i wanna be 100% sure b4 i go through with this, thanks for all the input! and yes.. i should have done this 725 miles ago lol and the only reason i kept the stock size was because i thought i was doing the wise and correct thing by keeping the OEM size, because it says in the drivers door jam that the replacement tires should be the same size as the original equipment tires. so idk.. tires sizes get confusing, my head is going 1000mph lol
Old 07-20-2012, 09:50 PM   #8
Lord of War
KenLyns's Avatar
The middle number is a percentage of the tread width, not an absolute value.
http://www.tirerack.com/tires/tirete...e.jsp?techid=7
75% of 245 mm is close enough to 70% of 265 mm
Note these dimensions are approximate. You should check the table from the manufacturer. Go to this page:
http://www.bfgoodrichtires.com/tire-...techspec_table
For BFG KOs, 245/75R16 is 30.5" dia. 265/70R16 is 30.7" dia.
Old 07-20-2012, 10:35 PM   #9
wow thank you for showing me that link on bfg's website, that really cleared things up.. yeah. in all reality we are talking about tenths of an inch, literally then lol. but it really helped alot.. i still dont understand why the two look so different on the truck tho, it must just be me lol.. so i guess its not really worth changing tires then hm?
Old 07-21-2012, 01:47 PM   #10
Bullwinkle J. Moose
bjmoose's Avatar
They look different because the 265 are wider than the 245.
Old 07-21-2012, 09:55 PM   #11
very true, and i have one last question, since im going to go through with the swap to the 265/70/R16's, there wont be any Upper Control Arm rubbing issues at any steering angle, or will there be?? because my truck is a base and a the 265's are from the TRD off road package?? i mean it is after all, technically speaking a 'factory or OEM' size tire, i wouldnt think toyota would change UCA size between packages right lol?? I know ive probably answered my own question, but i just want to confirm, thank you!
Old 07-21-2012, 10:00 PM   #12
Banned
All 2nd gen 6 lug suspension is the same basic design regardless of trim level. The larger tires will be fine on your truck.
Old 07-22-2012, 08:54 AM   #13
alright thats great news! thank you for your input, it really appreciate it things with this tire size swap as well as my suspension upgrade are coming along slowly but surely lol thanks again!
Old 07-22-2012, 09:11 AM   #14
Slow as shit. Cute as Hell.
Steves104x4 is one of the sharper tools in the shedSteves104x4 is one of the sharper tools in the shedSteves104x4 is one of the sharper tools in the shedSteves104x4 is one of the sharper tools in the shedSteves104x4 is one of the sharper tools in the shedSteves104x4 is one of the sharper tools in the shedSteves104x4 is one of the sharper tools in the shedSteves104x4 is one of the sharper tools in the shedSteves104x4 is one of the sharper tools in the shedSteves104x4 is one of the sharper tools in the shedSteves104x4 is one of the sharper tools in the shed
Steves104x4's Avatar
Steves104x4's Tacoma Gallery
So what brand of tire are you putting on?
Old 07-22-2012, 09:20 AM   #15
Dustyroades is one of the sharper tools in the shedDustyroades is one of the sharper tools in the shedDustyroades is one of the sharper tools in the shedDustyroades is one of the sharper tools in the shedDustyroades is one of the sharper tools in the shedDustyroades is one of the sharper tools in the shedDustyroades is one of the sharper tools in the shedDustyroades is one of the sharper tools in the shedDustyroades is one of the sharper tools in the shedDustyroades is one of the sharper tools in the shedDustyroades is one of the sharper tools in the shed
Dustyroades's Tacoma Gallery
You're going to swap brand new 245/75R16s for 265/70R16s? That sounds like a huge waste of money, all you're getting is an extra 20 mm in width...
If you're going to do it at least upsize in diameter as well.
Old 07-22-2012, 09:29 AM   #16
AcadianTaco is a jewel in the roughAcadianTaco is a jewel in the roughAcadianTaco is a jewel in the roughAcadianTaco is a jewel in the rough
AcadianTaco's Avatar
AcadianTaco's Tacoma Gallery
I run the stock suspension also, my winter tires are 265 75 R16. Under normal driving condition no rubbing. I had them rub before, but usually turning in reverse and hitting bumps. Although I did feel them rub, it was very minor rubbing, rubber on plastic. So 265 70 R16 should be good.
Old 07-23-2012, 10:55 AM   #17
Lwb053 is on a distinguished road
Navy: Former Nuke Electronics Tech/Reactor Operator (Submarines)
Lwb053's Tacoma Gallery
So, the consensus is that I could go from the 245/75 16 to a 265/75 or 265/70 without a problem. (My truck is a stock 2010 PreRunner Regular Cab). Can I shove a 285 under there without rubbing? Right now it looks like a chubby gal on a set of ice skates....
(Sorry if I offended any chubby ice skaters!)
Old 07-23-2012, 03:14 PM   #19
alright sweet! thanks for the reassurance and just curious, would u happen to know the cold tire PSI rating on the 265/70/16's ?? thanks!
Old 07-23-2012, 03:15 PM   #20
well from what im hearing and understanding, i wouldnt really go past a 265/75/R16 on a stock suspension
265/70/16 or 245/75/16 auart Wheels & Tires 5 05-04-2012 08:58 AM
Manual says 265/70/16 tire sticky says 265/75/16 why? squirrelNUts 2nd Gen. Tacomas 3 04-04-2012 06:08 PM
Tires 245-75-16 VS. 265-70-16 fergman61 Wheels & Tires 1 05-24-2011 04:13 PM
245-75-16 Vs 265-70-16 fergman61 New Members 1 05-24-2011 01:30 PM
245/75 vs 265/70 tires on an 02 Tacoma? Georgia Boy Wheels & Tires 0 06-20-2010 06:44 AM
