Steelie help?
Discussion in 'Wheels & Tires' started by winker71, Jul 28, 2012.
  1. Jul 28, 2012 at 12:52 AM
    winker71
    winker71 [OP] New Member
    I'm new to the forum and realize this question may have been answered elsewhere but have lost my patience trying to find the answer. Does anyone run the OEM Tacoma 17" steelie (spare) or FJ steelie wheels? I like the look of the OEM steelies but have read elsewhere that the FJ steelies do not have the proper backspacing...but I see a lot of people running various FJ Alloys?? I have seen a Tacoma OEM 17" steelie spare that looks identical to the OEM 17" FJ steelie. Anyone know the difference? Does the Tacoma OEM 17" steelie spare have the correct backspacing? Eventually I want to run 33's with an Icon 2.5 or OME 885 with Bilstein 5100's. I realize there are other steelie options out there so no need to suggest those. Thanks.
  2. Jul 28, 2012 at 11:46 AM
    chewingonabone
    chewingonabone Well-Known Member
    Josh
    Charlotte, NC
    09 Tacoma SR5
    Retrax One tonneau, bull bar, step bar, PL8521
    Are you talking about the stock tacoma steelies that are 16 inches?
  3. Jul 28, 2012 at 8:20 PM
    winker71
    Not sure, I've seen 15, 16, & 17 steel spares advertised. Not the stock steel wheels but the spare tire wheel is what I'm referring to. It looks identical to the FJ Steelie. I'm interested in the 17's. I've read before that the FJ steelies don't work due to the backpsacing but I see lots of guys running FJ alloys. Just wondering what the difference is or if anyone has run the Tacoma steel spare wheel(s).
  4. Jul 29, 2012 at 9:53 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    FJ 17" steelies with 265/70/17, at stock height and no adpaters
    same setup lifted 3" with 1.5" adpaters
  5. Jul 30, 2012 at 10:38 AM
    winker71
    Thanks looks good. Wondering if they will work on 2nd gen.
  6. Jul 30, 2012 at 10:53 AM
    92LandCruiser
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    They'll bolt up just fine, don't know back spacing or what you're after.
    Can always use spidertrax.
    I've always like the look of the stock steelies.
  7. Jul 30, 2012 at 3:14 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    You shouldn't have any issues on the 2nd gen.
    Ditto. At stock height, it will pretty much tuck in almost like stock. It's only when you lift it that you should consider adding adapters unless you prefer the tuck in look.
  8. Jul 30, 2012 at 3:36 PM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Not sure of the BS on the FJs
    Since you have a 2nd Gen 5.25" is stock & the first gen TRDs I have on mine the BS is 4.5" so they stick out .75" farther than stock.
    Stock 5.25" BS with 245/75/16s
    1st Gen TRDs 4.5" BS with 255/85/16s
