265/70/16 stock size or 265/75/16 for new AT3's
Discussion in 'Wheels & Tires' started by peto48, Dec 13, 2012.
  1. Dec 13, 2012 at 7:58 PM
    peto48
    peto48 [OP] Well-Known Member
    Central NY
    2020 Tacoma DCSB TRD Off Road Cement 4x4
    Salex Center console organizer, glove box organizer, Husky Xact contour front and rear digital floor liners, OEM black running boards, TRD PRO Sema 4runner wheels black, Blackout badge kit, Bakflip MX4 hard folding tonneau.
    Getting some cooper AT3's very soon, been reading up on tire sizes. Now I'm at a crossroads, which size do I go with, the 70's or 75's? Is there a noticeable difference in look and or performance? I have read on many posts that the 75's fit with no rub or need to trim, just want to verify. Looking for knowledgable opinions either way so I can make an informed decision. Thanks for the help.
    I have a stock 2012 trd off road with the stock 16 inch alloy wheels.
  2. Dec 13, 2012 at 8:05 PM
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
    75s imo will look better, thats about it. wont notice a noticable diff in mpg or offroad traction
  3. Dec 13, 2012 at 8:17 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Differential Breather Mod Light Bar: 4 Cree LED lamps Bilstein 5100s Ride Rite Air Bags
    75s add 1/2" ground clearance and make speedometer work correctly!
  4. Dec 14, 2012 at 4:24 AM
    adrstout
    adrstout Well-Known Member
    Adam
    Indiana
    '12 4cyl SR5 4x4
    2.5" lift, 265/75r16 Cooper AT3, All Pro Front Skid, KBVoodoo bed rack, a bunch of other random stuff
    What David K said.
  5. Dec 14, 2012 at 4:35 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    265/75r16. i have 265/75in nitto terra grapplers. looks really nice.(look at my sig pic VVVVVVV
  6. Dec 14, 2012 at 2:02 PM
    adrstout
    Adam
    Indiana
    '12 4cyl SR5 4x4
    BTW, I have AT3s in 265/75. Only had them about 800 miles but I really like them so far. If you search down a little ways in the wheels and tires section, you should see I have a thread on them. Don't have much, but plan on adding more soon. Especially once I have a chance to take them off pavement. Herre are some comparison pics. From the side, the 245s I had and the 265/70s should look about the same.
    From the day I got the new At3s...
    245s...
    265/75s!!!!
    Old side pic w/ 245s
    More recent side one w/ 265s-hauling skids for work
  7. Dec 19, 2012 at 9:21 AM
    peto48
    Central NY
    Do I need to get any sort of spacer or anything extra if I am putting the 75's on the stock alloys that came on the trd off road. Or can I just throw the 265/75/16's on the factory wheels with no rubbing?
  8. Dec 19, 2012 at 9:24 AM
    peto48
    Central NY
    Here is the pic
  9. Dec 19, 2012 at 9:25 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The 265/75's will fit just fine. No spacers needed.
  10. Dec 19, 2012 at 10:43 AM
    David K
    The 265/75-16 fits right on the stock TRD Off Road wheels, like it was made for them... No rubbing off or on road... The speedometer reads correctly, too... It is as if the truck was made for the 75 series tire!
  11. Dec 19, 2012 at 2:08 PM
    LAMB01
    LAMB01 SENIOR MEMBER
    Nick
    Tennessee
    Silver 4x4 Tacoma
    I
    Have the ion alloy 174 16 x 8 on my 03 Tacoma. Thinking bout getting spacers will that make wm rub my fenders? I'm wanting them to stick out more and I know I can't run a ten inch wheel but what of I get a one inch spacer??
  12. Dec 19, 2012 at 2:11 PM
    Pugga
    Massachusetts
    Except the ODO will read off... It's like Toyota couldn't make up their mind and half the factory designed for 265/70 and the other half designed for 265/75 :laugh:
  13. Dec 19, 2012 at 2:55 PM
    adrstout
    Adam
    Indiana
    '12 4cyl SR5 4x4
    What Pugga mentioned bugs the hell out of me.
  14. Dec 19, 2012 at 4:08 PM
    peto48
    Central NY
    Please explain further, I am about to make a decision on 265/75/16 or factory 265/70/16. From what I have read so far, the speedometer will be correct, how is the odometer effected? Everyone has been recommending the 75's but I want to know all the effects on the vehicle. Thanks.
  15. Dec 19, 2012 at 4:38 PM
    David K
    Not anything to worry about... I use the odometer while making maps in Baja and it is either right on or very close to the figures the auto club has on their Baja map.
  16. Dec 19, 2012 at 5:16 PM
    LAMB01
    Nick
    Tennessee
    Silver 4x4 Tacoma
    okay im wanting to put a leveling kit on my 1st gen tacoma, the front sits down and i want to pick the front up,what do i need to buy for it?
  17. Dec 19, 2012 at 5:19 PM
    Pugga
    Massachusetts
    If you go with factory size, 265/70R16 tires, your odometer will be dead on but your speedometer will read a little slow (all Tacomas are like this from the factory, no idea why). If you go with the taller sized tires, your speedometer will read dead on but your odometer will read low. You're talking about 3% difference so take your pick wheter you want the difference to be in the speedo or the odo.
  18. Dec 19, 2012 at 5:29 PM
    peto48
    Central NY
    Just to clarify the 3% slow read on the odometer = when you travel 100 miles, the odometer only reads 97?
  19. Dec 19, 2012 at 5:41 PM
    Pugga
    Massachusetts
    If you go with the 265/75 tires, when you travel 100 miles, your odometer will read 97 miles.
