285 vs 315 Why one over the other?
View Poll Results: Which would you pick?
285/70R17 20 52.63%
315/70R17 18 47.37%
Voters: 38. You may not vote on this poll
Old 12-28-2012, 07:52 AM   #1
thegreatwall23 is a splendid one to beholdthegreatwall23 is a splendid one to beholdthegreatwall23 is a splendid one to beholdthegreatwall23 is a splendid one to beholdthegreatwall23 is a splendid one to beholdthegreatwall23 is a splendid one to beholdthegreatwall23 is a splendid one to behold
thegreatwall23's Avatar
thegreatwall23's Tacoma Gallery
A couple of questions on this... First, let me say that I have a front bumper, lift, CMC, Icon tubular ucas, 4.56 gears, etc... So, I am not that concerned with it fitting. I have had 305's and had no issues. With that being said, the 305's wheels had 5 backspacing and 0 offset. Do you think a 315/70r17 would rub the uca with 4.5 backspacing and -12 offset?
Second question... I have read why many people like a 285 or 315 over the other. Most of the time it comes down to not being able to fit the bigger one, or the narrow one is better in the snow, wider is better in the mud, the list goes on and on. So, if fitting the tire under your truck wasn't an issue, which would you pick and why? Why is one better than the other?
Old 12-28-2012, 08:00 AM   #2
alnewt1234 is on a distinguished road
alnewt1234's Avatar
Army:
alnewt1234's Tacoma Gallery
I have 285's and that is because that is the biggest tire that would fit. I wouldn't go any bigger if I could tho looking back on it. I personally don't have any need for larger tires than that and kills the gas mileage and makes the truck work harder.
Old 12-28-2012, 08:20 AM   #3
Bullwinkle J. Moose
bjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shedbjmoose is one of the sharper tools in the shed
bjmoose's Avatar
bjmoose's Tacoma Gallery
The short answer is that once the suspension is fully compressed, the wheelwell isn't any bigger than it was from the factory - unless you made it bigger by cutting. Now, with a stiff aftermarket lifted suspension, this is unlikely to happen on the street; as opposed to the stock suspension which is pretty easy to hit the bump stops on the street. But full stuff can and does happen off-road.
A 33x11" tire needs about 1" extra clearance all the way around.
a 35x12" tire needs about 2" extra clearance all the way around.
So everyone picks their combination of
* cutting (including cab-mount-chop, pinch weld, etc...)
* rubbing (often unnoticed, least of your worries when you've driven into a really hard hit)
* not driving to stuff the wheels (milder driving style or milder terrain)
Pick your poison man. It sounds like you want the 315s and I'm not going to try and talk you out of them.
Old 12-28-2012, 08:51 AM   #4
nofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shed
nofords08's Tacoma Gallery
Meh stuffing 35's isn't all that hard, these are quite a bit bigger than a 315/70r17 too
i used to have a 6" lift and 33's, now i have a 3" lift n 35's and tackle stuff i never would have imagined doing with the 6" and 33's. the 35's have treated me very well off road!
Old 12-28-2012, 09:06 AM   #5
nfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shed
nfs257's Avatar
Navy: GSM1
nfs257's Tacoma Gallery
Im rubbing horribly in turns with 315's I need to beat the pinch weld into submission some more.
Old 12-28-2012, 09:14 AM   #6
how much have you trimmed?
Old 12-28-2012, 10:32 AM   #8
NorthWest Member
J88logue is one of the sharper tools in the shedJ88logue is one of the sharper tools in the shedJ88logue is one of the sharper tools in the shedJ88logue is one of the sharper tools in the shedJ88logue is one of the sharper tools in the shedJ88logue is one of the sharper tools in the shedJ88logue is one of the sharper tools in the shedJ88logue is one of the sharper tools in the shedJ88logue is one of the sharper tools in the shedJ88logue is one of the sharper tools in the shedJ88logue is one of the sharper tools in the shed
J88logue's Avatar
Gender: Tranny
J88logue's Tacoma Gallery
lol why one or the other...Really...well i'm here anyways....
one is heavier = less power, lower gas mileage.
one has 1" more clearance = better ground clearance.
One is wider = not enough to matter.
One is more expensive = less TacoBell money
One is smaller = less possibility of rubbing/more clearence.
It should be completely obvious why one would want one of the other, the answer if nearly in the question. Best of luck to you
BTW i run 285s
Old 12-28-2012, 10:37 AM   #9
BTW i run 285s
yeah, I know all of the obvious ones, I just thought I would let people chime in and give their opinion and help me spend my money! lol... I have had 305's, then moved to 285's, thinking about going back up to 315's since I regeared.
Old 12-28-2012, 10:40 AM   #10
NorthWest Member
J88logue's Avatar
Gender: Tranny
Yeah you def could!
Old 12-28-2012, 10:41 AM   #11
Go home if you don't like guns liquor and whores.
maxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shed
maxamillion2345's Avatar
maxamillion2345's Tacoma Gallery
I don't think you'll fit them like you think you will
Old 12-28-2012, 10:50 AM   #12
oh yeah, you have to accept the fact a saws all will and grinder will be used on your nice Tacoma
Old 12-28-2012, 12:16 PM   #13
hum... Do you have any rubbing or issues? What kinda of issues do you see me having? Like I said I have run the 305's and I had no rubbing anywhere, but I did have a very deep cab mount chop and pinch weld job done and some trimming on the fender flares. The new tires according to the tire calculator would be .75" taller and .3" wider. I just don't see how it would be too much different.
Thanks for your input! I need to make sure I am not missing anything.
Old 12-28-2012, 04:23 PM   #14
nfs257's Avatar
Navy: GSM1
Noford I have the cab mount chop and tube bumper and fiber glass. I just need to beat the pinch weld.
Old 12-28-2012, 05:34 PM   #15
Hmm how much lift?
Old 12-28-2012, 09:08 PM   #16
Bullwinkle J. Moose
bjmoose's Avatar
Are those glass fenders? I certainly can't see the stock front fender flares in that pic and there aren't any fender holes.
Old 12-28-2012, 09:10 PM   #17
No those are glass, even before glass i found most of the rubbing to be the pinch weld area and of course body mount
AP Glass 2" rise 3" Flare
Old 12-28-2012, 10:51 PM   #18
Sublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shedSublime is one of the sharper tools in the shed
Sublime's Avatar
Sublime's Tacoma Gallery
And ohhh sooo sexy!
I'm getting 35's next! You can play with getting enough caster to push the wheel forward as to not rub the firewall (pinch weld area) but the pinch weld will need to be flat and cab mounts chopped to give an extra inch or so in that area! You will deff need glass fenders or trim a few inchs off the stockers since the up travel will also be an issue!
Old 12-29-2012, 09:33 AM   #19
nfs257's Avatar
Navy: GSM1
4" lift spindles and kings lifting about an inch or 2.
Old 12-29-2012, 10:49 AM   #20
Dave
TacTRDFreak is on a distinguished road
TacTRDFreak's Tacoma Gallery
Have an 08 with 3/2 suspension lift. How far oversize can I go on tires without rubbing?
315/70/17?? Sack17 Wheels & Tires 6 04-03-2013 10:51 PM
Tacos With 35's/315's VABUCKAROO 2nd Gen. Tacomas 9 08-11-2012 10:59 AM
Would 315's work on a 2.5" lift? Sheepdog 1st Gen. Tacomas 41 04-18-2011 07:22 PM
WTT 315's for smaller DTFtacoma Buy / Sell / Trade 6 12-14-2010 09:27 AM
315/70/17 jarroddorraj Wheels & Tires 9 04-17-2009 07:20 PM
