33" tires with aftermarket bumper?
Discussion in 'Wheels & Tires' started by fourbyfour, Jan 12, 2013.
  1. Jan 12, 2013 at 7:44 PM
    fourbyfour
    fourbyfour [OP] Active Member
    British Columbia
    None yet
    I know this question gets asked 10 times a day, and I know that 33" tires will not fit with a 3" lift without some rubbing, but will it make a difference if I'm using an after market steel bumper? They seem to open up the wheel wells a bit more in pictures I've seen. Any thoughts?
  2. Jan 12, 2013 at 8:20 PM
    Boost JuNkY
    Boost JuNkY Well-Known Member
    Billy
    Vancouver, BC
    2003 TACOMA DC OFF ROAD
    35'S ON 3s
    33's do fit on 3" lift. I did it before on stock bumper w/o mud flaps.
    But with your question, It will free up space in the front wheel well but the rear portion is what I find most troublesome, but should not be an issue with proper offset wheels.
    Caster settings can also eliminate rubbing.
  3. Jan 12, 2013 at 8:20 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    255/80/17
  4. Jan 12, 2013 at 8:40 PM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Couldn't have said it better.
