Tire size
Old 01-15-2013, 11:33 PM   #1
emilminasian is on a distinguished road
emilminasian's Tacoma Gallery
Tire size
I have the Trd sport rims the Size is 265/65/17 , I'm wondering if 285/70/17 would possibly fit on my rims and would it rub against my fenders ?
Old 01-15-2013, 11:37 PM   #2
OZ-T's Avatar
OZ-T's Tacoma Gallery
Needs wheel spacers to clear the UCA
Old 01-18-2013, 11:40 AM   #3
TSB 0305-08 Rev2 & TSB 0373-09 DONE
Goblin is a glorious beacon of lightGoblin is a glorious beacon of lightGoblin is a glorious beacon of lightGoblin is a glorious beacon of lightGoblin is a glorious beacon of lightGoblin is a glorious beacon of light
Goblin's Avatar
Navy: Operations Specialist - Combat Information Center
Goblin's Tacoma Gallery
What about 275/70 16's? I was told they would fit without issue if I just wanted a little more width. Hm? BF Goodrich Rugged Terrain T/A http://www.discounttiredirect.com/di...TA&code=014532
Old 04-07-2013, 02:56 PM   #4
2xR 2xR is offline
2xR is on a distinguished road
Army:
2xR's Tacoma Gallery
265/70 or even 75 16s will fit but nothing bigger without wheel spacers
Old 04-07-2013, 02:58 PM   #5
OZ-T's Avatar
I run 275/70/17 on stock Sport alloys with no wheel spacers
Old 04-08-2013, 02:38 PM   #6
Emminasian is on a distinguished road
Emminasian's Tacoma Gallery
Any pictures ?
Old 04-08-2013, 03:41 PM   #7
OZ-T's Avatar
Originally Posted by Emminasian View Post
Any pictures ?
I assumed you were asking me
Old 04-09-2013, 02:39 PM   #8
fishstix is on a distinguished road
fishstix's Avatar
fishstix's Tacoma Gallery
I am running 275/70/17's
Billi's 5100 on all 4 corners
AAL 1.5
Stock Rims
I just added the spyder trax 1.25" wheel spacer and I am getting some rubbing on the UCA.. It only rubs with full wheel turn while off roading...
I am not sure if the rubbing was going on before the spacers because I never went off road....
I am wondering if larger spacers would help or should I just take them off...?
Old 04-16-2013, 11:49 AM   #9
DAR DAR is offline
DAR is on a distinguished road
DAR's Tacoma Gallery
Hi, I researched this topic quite a bit. I have a 2013 Toy Tac Double Cab Limited 4x4. The truck is stock with no lift. I just had 275/65/18 installed at Discount Tire. We test fitted the 275/70/18 and they were a bit large so we dropped down to the 65. Discount Tires was great and took the time to do the test fit. You can research all you want but if you are trying to get the largest tire that will work I recommend the test fit. I did take off both front and rear mud flaps from the front wheel wells and I also detached the wheel well plastic and pushed it back as far as possible and reattached it to create more room. It worked well and you can't even tell I did anything.
Tire tread a factor in tire size? nvdeserted Wheels & Tires 19 10-24-2010 07:59 PM
I need help with tire size n rim size anyone? maui808 New Members 3 09-07-2010 06:49 PM
Stoopid Noobs Question, Part 5: Calculating Tire Size from Rim Size 283 Wheels & Tires 5 01-24-2009 05:11 PM
