Am I the only one who really likes the early first gen rims?
Discussion in 'Wheels & Tires' started by Bullfrog, Jan 20, 2013.
  1. Jan 20, 2013 at 8:45 PM
    Bullfrog
    Bullfrog [OP] "I think I know more than I do."
    McLaren
    North Bend
    98 V6 4x Limited Ugly Canadian Green.
    Accessory Box with CB attached. Alpine Type S front and back. LineX. Bedline SKidplates. In progress: Bilstein 5100s with BFG mudterrains 33x10.5 A/C compressor to Onboard Air compressor mod.
    I like them, what can I say why buy new rims when these look fine. Going to 33x10.5 BFG mud terrains. Anyone see any problems?
  2. Jan 20, 2013 at 8:46 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    No problem at all, go for it!
  3. Jan 20, 2013 at 8:53 PM
    davidjmay
    davidjmay Well-Known Member
    David
    Orange County/Azusa
    '00 PreRunner
    Pioneer HU & door speakers, Alpine type R, Kicker dx1000.1, OME 883 lift, Wheelers 2" AAL, custom mesh grille, smoked LED taillights, LED light bar, Raptor exhaust dumped before axle, custom fabbed roll bar/light bar mount
    33's on stock rims will rub, that's why.. what lift are you running?
  4. Jan 20, 2013 at 8:58 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    incorrect! well sorta..
    33x12.5s will rub on the UCA due to width and the BS of stock rims.
    but a 33x10.5 is the same width as a stock 31x10.5 so he will be fine..other then the pinch weld rubbing probably due to the hieght.
    i loved my stock 15s. But i wanted 12.5s and you can't run a 12.5 on a 7'' wide rim like stocks.
    but stock rims are sweet!.
    I repainted mine and they were awesome.
  5. Jan 20, 2013 at 9:07 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    3rd gen runner wheels FTMFW
  6. Jan 20, 2013 at 10:00 PM
    Bullfrog
    McLaren
    North Bend
    Going to 2.5 5100s and 3 inch coils
  7. Jan 20, 2013 at 10:02 PM
    Bullfrog
    McLaren
    North Bend
    What rims are those? And how much did that grill guard set you back??
  8. Jan 20, 2013 at 10:03 PM
    650H1
    Michael
    VA
    you can get that grill guard cheap on JC whitney IIRC..
  9. Jan 20, 2013 at 10:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Didn't pay for the grill guard. Came with the truck. They are worthless though. If you hit anything wi it it'll just fold over onto the truck. I actually think they are pricey. More worth it to get an offroad bumper.
    Rim also came with the truck but I think they are 4runner rims. I found a site with em once for 70 a piece.
  10. Jan 21, 2013 at 10:37 AM
    TexasTacoma37
    Wait....you're going to use 3" coils AND set the billies to 2.5"?
  11. Jan 21, 2013 at 10:43 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    96' X-Cab 4x4 TRD Off Road Clusterfuck
    JVC Deck, 10" sub mountd in rear seat cubby, 2 LED off road lights mounted in grille, amber raptor style grille lights, LED rock lights, square led bed light, custom made fuse block tray, 12 blade Blue Sea fuse block, 100a marine circuit breaker, black plasti dipped full grille, tinted tail lights + third, Uniden 520 with 4' firestik, Bilstein 5100s with 620lb Eibach coils, Diff drop, Chevy 63 leaf swap, TG creeper joints, 14" triangulated biletein 5125s, 8" extended steel braided brake line, TG Rock Sliders, CBI Moab 1.0 front bumper, custom fabbed bed rack, full TRD E-Locker axle swap and matching re-gear with custom stand alone wiring circuit, 29 spline pinion flange from an 06 wishbone runner, tubbed for 35x12.5" general grabbers on Ultra type 181 wheels, crush sleeve eliminator, Mini ARB compressor, front ARB locker, garage fab aluminum front skid plate, custom built high clearence rear bumper, removable mothafuckin doors
    I agree, I think those stock wheels (the ones I have with 33x10.5x15 BFG AT) are the best looking tacoma wheels for the 1st gen by far. I just derped them flat black and they work great and look great.
    x2, get the 3"coils and set the billies at 0", not 2.5.
  12. Jan 21, 2013 at 12:37 PM
    Bullfrog
    McLaren
    North Bend
    Maybe I'm confused about how I'm suppose to set it up. I am planning to run 33s on 2.5-3 inches of lift I was planning on buying 5100s and 3 inch taller coils. Maybe I should be asking how I should set this up?
  13. Jan 21, 2013 at 12:42 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    The adjustability of the 5100s is made for stock length coils. If you buy longer coils, you eliminate the need for the height adjustment. Buy longer coils (i.e. Eibachs or OME) and set the 5100s at 0, will yield ~2.5-3" lift. Some people have gotten away with setting the 5100s to 0.85 with longer coils, but your ride will be much better setting them at 0
  14. Jan 21, 2013 at 12:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    There are no 3'' longer coils. No shock you could run on stock UCAs and LCAs will fit one that long.
    im assuming you mean 3'' lift coil. most likely the Toytech Eibachs? You do NOT want to precompress them at all. The 5100s adjust for just stock coils. If you get 883 OME coils or Eibach Toytech coils you MUST set the 5100 on the lowest setting. Or you wont have any CV axles for very long.
    Im running the 5100s and Eibachs. Love them.
    THis. Except on there is no .85'' lift selection on 1st gen 5100s. There is on 2nd gens and 2nd gen tacomas run the eibachs at .85 to get 3'' of lift as you have a bigger motor and diff and well..heavier truck.
    1st gen 5100s only have 0'', 1.25'' and 2.5'' for adjustablity.
  15. Jan 21, 2013 at 2:44 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    Ah. Got it, I knew I had seen people talking about them on here. Good to know :thumbsup:
  16. Jan 21, 2013 at 2:48 PM
    Bullfrog
    McLaren
    North Bend
    So how does it work having taller coils without taller shocks. This doesn't make sense too me when you adjust them does it make them taller or does it just compress the coils more? Some technical explanation would be helpful.
  17. Jan 21, 2013 at 3:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Eibachs are taller then stock coils. But not 3" taller. They are also much heavier duty coils meriting just over 3" of lift
    5100s just compress the coils more to provide lift. This works okay on stock coils but you should never compress coils that provide lift by themselves.
    If you got a 3" physically longer coil you would have to be running long travel as eh run 8" or 10" travel long shocks as opposed to the 6" travel shocks stock amd 5100s provide.
    Our trucks can't handle more then 3" of lift very well amd the eibachs push the limit as it is.
    Make sense??
  18. Jan 21, 2013 at 5:15 PM
    Bullfrog
    McLaren
    North Bend
    So they really aren't taller they are much stiffer so they don't compress as much under load. This makes a lot more sense now.
  19. Jan 21, 2013 at 8:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well they are longer. Not 3" longer. Probably more like 1"ish taller. But yes they are much stiffer to take a heavier load like bumpers skids winch dual batteries and what not.
    Either way.
    Do not get lift coils and then precompress them the 5100s. They must be set at 0 with bigger lift coils.
  20. Jan 21, 2013 at 8:51 PM
    Bullfrog
    McLaren
    North Bend
    Will it be really rough ride because its so stiff?
