The Perfect Offset for 285/75/16 ???
View Poll Results: Wich Offset for 285/75/16 on 8"wide with 3" lift?
0 mm 9 39.13%
-6mm 4 17.39%
-12mm 8 34.78%
Other 2 8.70%
Voters: 23. You may not vote on this poll
Old 02-03-2013, 09:34 PM   #21
george2pak [OP] george2pak is offline
george2pak is one of the sharper tools in the shedgeorge2pak is one of the sharper tools in the shedgeorge2pak is one of the sharper tools in the shedgeorge2pak is one of the sharper tools in the shedgeorge2pak is one of the sharper tools in the shedgeorge2pak is one of the sharper tools in the shedgeorge2pak is one of the sharper tools in the shedgeorge2pak is one of the sharper tools in the shedgeorge2pak is one of the sharper tools in the shedgeorge2pak is one of the sharper tools in the shedgeorge2pak is one of the sharper tools in the shed
george2pak's Tacoma Gallery
Originally Posted by CrAiG View Post
I would help, but I got the same questions you do
Old 02-04-2013, 11:02 AM   #22
Stealth Custom Series™
SCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shed
SCSPerformance's Avatar
SCSPerformance's Tacoma Gallery
0, -6, or -12 will all give you the clearance needed on your UCA. It boils down to how aggressive you want the stance to be. The more negative offset you go, the wider the wheelbase which tends to create more rubbing in the cab mount area. Although with 285s, a CMC is definitely recommended.
Check out our F-5 wheels if you're interested. They're 16x8 with +0 offset and weigh 19lbs each.
Old 02-04-2013, 12:27 PM   #23
Because 4R
Wishbone Runner is one of the sharper tools in the shedWishbone Runner is one of the sharper tools in the shedWishbone Runner is one of the sharper tools in the shedWishbone Runner is one of the sharper tools in the shedWishbone Runner is one of the sharper tools in the shedWishbone Runner is one of the sharper tools in the shedWishbone Runner is one of the sharper tools in the shedWishbone Runner is one of the sharper tools in the shedWishbone Runner is one of the sharper tools in the shedWishbone Runner is one of the sharper tools in the shedWishbone Runner is one of the sharper tools in the shed
Wishbone Runner's Avatar
Wishbone Runner's Tacoma Gallery
Originally Posted by SCSPerformance View Post
0, -6, or -12 will all give you the clearance needed to not run on that UCA. It boils down to how aggressive you want the stance to be. The more negative offset you go, the wider the wheelbase which tends to create more rubbing in the cab mount area. Although with 285s, a CMC is definitely recommended.
Agreed. I voted -6, but run -12 for the wider stance and prefer it. So, it comes down to stance and how much chopping you may want/need to do.
Old 02-04-2013, 01:39 PM   #24
Thank you for the help!
I'm looking more for functionality then look. I want less CMC as possibles.
Old 02-04-2013, 03:38 PM   #25
Can those that choose "other" to specified what they mean?
Old 02-06-2013, 12:41 AM   #26
Master Jedi Member I am...
chad68 is a splendid one to beholdchad68 is a splendid one to beholdchad68 is a splendid one to beholdchad68 is a splendid one to beholdchad68 is a splendid one to beholdchad68 is a splendid one to beholdchad68 is a splendid one to behold
chad68's Avatar
Location: In a (Toyota) van down by the river! Sonoma Cownty
chad68's Tacoma Gallery
The rule of thumb is if you're running 285/75/16's on 8" wide wheel, go with 4.5" BS'ing.
If you were to run a 305/70/16 on an 8" wide wjeel, you would probablly want 4.0" BS'ing which is what I have and no body mount rubbing on my 2009.
Old 02-06-2013, 07:41 AM   #27
KPT KPT is offline
sees what you did there.
KPT's Avatar
KPT's Tacoma Gallery
For an 8" wide wheel, the answer is zero. anyone saying anything to the contrary is incorrect.
Ask psu taco85. He has 8" wide wheels with 4.0 BS, which is -12 offset, and had to do a ton of cutting and pounding to get them to stop rubbing on the outer edge of the wheel due to them sticking out too far.
-12 is ideal for 9" wide wheels.
Old 02-06-2013, 07:44 AM   #28
Resident Jackass
Krazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shed
Krazie Sj's Avatar
EMS: EMT - Alberta Health Services - Olds
Krazie Sj's Tacoma Gallery
Originally Posted by george2pak View Post
I thought that is obvious that I don't want spacers.
(I need spacers or new rims)
Actually no, it's not obvious.
Old 02-19-2013, 11:43 AM   #29
Do you think you are funny, Funny man? Six shooter? What you gonna do, laugh them to death?
Old 02-19-2013, 12:13 PM   #30
It's anyway possible to get a hub cap with those F-5?
Old 02-27-2013, 09:59 PM   #31
After few debates I decided that the perfect offset for a Tacoma is +0mm.
That being said, I ordered a set of Stealth Custom Series rims. So far there's no need for BMC. Enjoy the pictures:
Old 02-27-2013, 10:28 PM   #32
That looks great Big G! You should receive the darker grey decal by tomorrow. I think they will match the truck a little bit better.
If you get a chance, take of the rear wheels and shoot a couple coats of semi-gloss black on the rear hubs. It will make a nice improvement.
Don't hesitate to contact me if you need anything else.
Old 02-27-2013, 10:36 PM   #33
Thank you for the tip Vin! I might need some touch up paint. One rim got scratched when they installed it.
Old 02-27-2013, 10:40 PM   #34
Maximus is one of the sharper tools in the shedMaximus is one of the sharper tools in the shedMaximus is one of the sharper tools in the shedMaximus is one of the sharper tools in the shedMaximus is one of the sharper tools in the shedMaximus is one of the sharper tools in the shedMaximus is one of the sharper tools in the shedMaximus is one of the sharper tools in the shedMaximus is one of the sharper tools in the shedMaximus is one of the sharper tools in the shedMaximus is one of the sharper tools in the shed
Maximus's Avatar
Maximus's Tacoma Gallery
Looks good man. How much trimming was done?
Old 02-27-2013, 10:46 PM   #35
As right now, none. For every day driving I'm good. I might have to do some for OFFroading. That's why I was trying to find the perffect Offset.
Old 02-27-2013, 11:49 PM   #36
Xer0 SiN is a glorious beacon of lightXer0 SiN is a glorious beacon of lightXer0 SiN is a glorious beacon of lightXer0 SiN is a glorious beacon of lightXer0 SiN is a glorious beacon of lightXer0 SiN is a glorious beacon of light
Xer0 SiN's Avatar
Army: veterans affairs
Xer0 SiN's Tacoma Gallery
im rocking icon extended travel coilovers, smooth body 2.5 icon rears, and icon ucas. sitting slightly higher than 3" in the front. just bought some welds 16x8 w/+3 offset and some 285/75/16 firestone destination mts. ill update this thread to let you guys know if i rub. there is a ton of space right now with my 265/70/17 4runner trail wheels, so i kinda doubt im going to have to trim, if any.
Old 02-28-2013, 06:25 PM   #37
Hey Vin! I took your advice and this is how it looks.
The Perfect Offset for 285/75/16 ???-img_4835.jpg   The Perfect Offset for 285/75/16 ???-img_4836.jpg   The Perfect Offset for 285/75/16 ???-img_4837.jpg
Old 02-28-2013, 10:25 PM   #38
That definitely looks a lot better! Nice work.
Old 02-28-2013, 11:41 PM   #39
Thank you!
Old 07-29-2013, 08:21 PM   #40
What about that update?
WTB - 285/70/16 or 285/75/16 Swank Wheels & Tires Marketplace 0 02-01-2013 06:09 AM
WTT 285/75/16 KM2's for 285/75/16 AT/KO's Gabex35 Wheels & Tires Marketplace 7 09-17-2012 07:46 PM
Pic of 265/75-16 and 285/75-16 equipped Tacos SxS x2468 1st Gen. Tacomas 17 08-19-2012 01:30 AM
WTT NorCal: 265/75/16 BFG AT's for 285/75/16's SCRunner12 Buy / Sell / Trade 0 07-16-2012 02:23 PM
With 1.75" up front...do I go 265/75/16 or 285/75/16?? Dakota 08 Wheels & Tires 12 05-16-2011 04:31 PM
