Are 285's A Huge Tire and A Huge Mistake
Discussion in 'Wheels & Tires' started by ivoryaddict, Feb 12, 2013.
  1. Feb 12, 2013 at 9:40 PM
    ivoryaddict
    ivoryaddict [OP] Well-Known Member
    Andy
    Northern California
    09 TRD offroad MGM DCSB
    Custom Headache Rack, BAMF Kick-out sliders with fill plate Level Kit, ARB bumper, Warn Winch Ruff Tuff Digital Camo Seat Covers Fuel 16" Boost Wheels Duratrac 285/75/16 X-tra D-Rings in Bed
    I'll try to make a long story short. I have a 2009 DCSB TRD 4x4. Wanting a little lift, went with a leveling kit. Then realized the truck looked a little weird with stock tires (265/70/16). Decided to buy new wheels and tires and fill up some wheel well. After reading many posts on Tacomworld 265/75/16 sounded like the safest option. Some folks have been running 285/70/17 with "little" trimming. Went to a shop weeks ago and was told that the Duratrac didn't come in a 265/75/16 at that time, I think they do now. However, the salesman said that they have installed 285/70/17 on quite a few tacos with no problems. Well needless to say, they didn't fit, especially because the offset/backspacing made the wheel hit on the UCA. Didn't even sound like they could get them to bolt on (Fuel Boosts). After driving 100 miles to the shop, I was stunned. The salesperson did more checking and calling and let me know that a 285/75/16 on a 16x8 Fuel Boost with proper offset would work or they would do what it takes to make it work. At this point I feel a morbid curiosity to find out what happens. Am I just being dumb standing here waiting for a train wreck, which is my truck, to take place. Or should I quit worrying because it will work out and look decent in the end?
  2. Feb 12, 2013 at 9:46 PM
    92LandCruiser
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Ummm... long as you have the proper backspacing 285s should fit pretty easy, especially if you only street it. You may have to clearance a little plastic and maybe the cab mount but that's all pretty non-invasive stuff
  3. Feb 12, 2013 at 9:55 PM
    ivoryaddict
    Andy
    Northern California
    Thanks for the positive input maxamillion, that is reassuring. Nice build by the way.
  4. Feb 12, 2013 at 9:58 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Thank you! Trying to go back down to 285s actually (long story...)
    Best of luck with your new wheels and tires, or rather enjoy!
  5. Feb 12, 2013 at 9:58 PM
    Sloweburn
    Sloweburn Well-Known Member
    Steve
    Woodstock, ON
    19 Tacoma TRD Sport Premium
    3" lift. $10K in TRD options. Richie's semi-hidden bumper, and soon his Elka suspension
    I have 285/75/16 BFG All Terrains on mine, using stock rims. They rubbed the UCAs a little bit on hard turns. I put on 1.25" Spidertrax spacers for now, until I get new rims.
    There is a bit of rubbing on my mudguards when I back up and turn hard. I drilled a hole through the inside of the mudguard and tie-wrapped it back to the body mount to stop it.
    Sometimes it touches the front fender liner when off-roading, but I'll be cutting that back once I put the off-road front bumper on - haven't bothered to trim the fender liner at this point.
    All that being said, you can just put on spacers until you're ready for new rims with less backspacing - they're about $100 a pair...
  6. Feb 12, 2013 at 10:04 PM
    Boost JuNkY
    Boost JuNkY Well-Known Member
    Billy
    Vancouver, BC
    2003 TACOMA DC OFF ROAD
    35'S ON 3s
    You shouldnt need to cab mount chop with 285s. unless your offset is very low. Not familiar with those wheels but imo 0 offset is perfect. Maybe slight trimming or bending of the plastic.
    Definitely go with 285's over 265's, especially since you have a winch bumper.
  7. Feb 12, 2013 at 10:12 PM
    Sloweburn
    Steve
    Woodstock, ON
  8. Feb 12, 2013 at 10:13 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    LED Headlights, Volant CAI, 32" Duratracs
    http://www.fueloffroad.com/specs.cfm?id=177
    The wheel P/N that would fit is D53416808345, 16x8" with 108mm centerbore and 1mm offset (assuming you want the black finish).
    285/75/16 is a 33" tire. You would need to remove the mudflap, trim away the portion of the fender flare that wraps around the bottom, and do a cab mount shop. The last one requires cutting away metal in your truck's frame and welding in a closeout piece: http://www.tacomaworld.com/forum/2nd-gen-tacomas/256842-cab-mount-chop-tut.html
  9. Feb 12, 2013 at 10:23 PM
    GTABurnout
    GTABurnout Well-Known Member
    Tucson AZ
    2012 Tundra Crewmax Rock Warrior TRD SC
    Icons, TRD Supercharger, TRD Exhaust, TRD Intake
    Method Double Standards with 285 MTR's. Icon Extended length coil overs with total chaos arms. Did the cab mount chop. Cut a bunch of fender flair away. And hammered the pinch weld. Still when I hit good sized bumps at speed I hit the tire in to the wheel well. Raised it up a little still happens. So next is spacing down the super bumps. So be aware. You may not rub on the street or rock crawling but if you drive fast off road you might still have trouble.
  10. Feb 12, 2013 at 10:27 PM
    KenLyns
    Belly of the Beast
    ^Then get fiberglass fenders. Slippery slope, as more than one TW member have said. :D
  11. Feb 12, 2013 at 10:44 PM
    Boost JuNkY
    Billy
    Vancouver, BC
    35'S ON 3s
    If your wheel offset isnt too crazy and caster is 2* or more, it shouldnt be that much of a problem with 285's. Assuming youre atleast 2.5" lift. Ran both my 2nd gens with 5100s and trimmed the front flare a little and no mud flaps. Ran it like that for a while, fairly easy and it did get wheeled at time. It did rub slightly on full stuff/lock.
  12. Feb 13, 2013 at 8:47 AM
    GTABurnout
    Tucson AZ
    Trying to avoid that step. But if some popped up local I would grab them.
    Like i said its easy when your going slow or just on the road. Hammer some fast rough roads and its a big deal to slam the fender at 50....
    Honestly I regret 285's I love the look but the abuse the truck is taking from the tires is more then I fell comfortable with.
  13. Feb 13, 2013 at 8:50 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    285s ain't shit!
  14. Feb 13, 2013 at 8:55 AM
    SaraLynn44
    SaraLynn44 Well-Known Member
    Sara Lynn
    Fresno CA
    08 PreRunner
    Engage Long Travel Deaver's 2 10" Kicker subs Fuel Rims Nitto Tires
    I have 285/70R17 with Fuel Boost I had no issue getting them to fit. My Trail grapplers rub a bit more then my Terra Grapplers but thats simply because they are a mud tire with more tread. My Fuel Boost are 17x9 with a 4.5 backspacing thats the norm when you buy 17's anyways. I dont understand why they said they were rubbing unless they ordered you 17x12 which is just retarded on a tacoma with a leveling kit.
  15. Feb 13, 2013 at 8:58 AM
    BigHeadTaco
    BigHeadTaco GFY
    Big Head
    Full OME lift 885's with Dakar leaf springs. LR UCA's. ImMrYo relocation bracket.
    Get the 285's
  16. Feb 13, 2013 at 9:08 AM
    sofiasdad11
    sofiasdad11 Reads more than posts
    John
    Near the Windy City, but in the country
    2011 BLACK 4X4 DCLB TRD SPORT
    Flux capacitor (2nd gen version), toytec ultimate liftkit, amp research powersteps, custom katzkin heated leather incl. console cover, retraxpro retractable bed cover, earnhardt jr. cannons@18x9(summer),ballistic jesters@18x9 (winter),285/60/18 nitto grapplers, bodymatched bushwackers, the original Homertaco full satoshi " raptor" grill, viper 5704 remote/smart-start/alarm w/viper cellulor app, ravelco anti-theft device, ipcw tails, redline hoodstruts, oem roof rack, led maps/dome, backup light mod, swingcase storage box, jl audio stealthbox and amps,focal drivers,alpine carplay unit, pop&lock premium handle, seatbelt chime disabled, tailgate hoseclamp mod, rich evans caliper covers, weathertech digitalfit mats, flyzeye V2W,oem bedmat, salex console organizer,speeddawg shiftknob
    ^^^this. runnin' 285's with a -12 offset, which only required minimal trimming of the oem wheelwells and shedding the oem mudflaps (since replaced with custom flaps for winter-purposes). no cabmount-chop required, as i do not offroad. DSC02781_e5795d27b8b2d6d07d12edff92a509df5e8b04d9.jpg
  17. Feb 13, 2013 at 12:25 PM
    GTABurnout
    Tucson AZ
    The issue for me is not driving around town or crawling, its high speed stuff. Its hard to keep a 285 from hitting stuff at speed.
    But yes if your goal is to have the cool look and you don't do any fast off road stuff you will be fine.
  18. Feb 13, 2013 at 12:43 PM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    ^ With an ARB bumper?
  19. Feb 13, 2013 at 2:16 PM
    SaraLynn44
    Sara Lynn
    Fresno CA
    08 PreRunner
    I Jump my truck all the time i have no issues if your putting them on a stock vehicle then of course your going to rub and they wont fit he stated he had a leveling kit therefore there should be no issue
  20. Feb 13, 2013 at 8:52 PM
    GTABurnout
    Tucson AZ
    You jump a truck with a spacer lift? :eek:.
    here is a video you can hear the tire hitting the top of the wheel well.
    http://www.youtube.com/watch?v=LoELT74Qvy4&feature=share&list=UU5v4m8KmNmTkiII0Yr_JaxQ
