35/12.50/20 backspacing+rim width?
Discussion in 'Wheels & Tires' started by Imndabuildin, Mar 5, 2013.
  1. Mar 5, 2013 at 8:05 AM
    Imndabuildin
    Imndabuildin [OP] Not your avg junior member
    Drake
    Louisiana
    I have an 06 with procomp 6 inch + icon coilovers. Currently running 35/12.50/17 with no rubbing. I'm going to a 20 inch rim now. Could really use some help on what backspacing I need. I know this lift min-max backspace is 4.0-4.65 wheel width range 8-9
    I'm seeing people going 35/12.50/20 with 20x10? I'm aware the lower the # of backspacing the more the tire sticks out.. I'm looking for my tires to stick out but not 100% sure what I can fit. I want 9-10 inch wide rim for sure.
    Anyone have any info on this?
  2. Mar 5, 2013 at 8:08 AM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    Keyser West Virginia
    2010 white double cab
    8 inch alcan custom leaf packs, ome 885's powdercoated white, bilstein 5100's all the way around with 12 inch travel on the rear, Light Racing Upper Control Arms, Sway bar removed, 17x9 kmc strike. 35x12.50 nitto Trail Grapplers. Satoshi Grill made by (homertaco), Black Headlight housings,retrofits, Tinted Tailights, color matched grill, Bought a TRD sport hood,elite off road front plate bumper,elite off road sliders, 13% tint on the front windows, 5% on top of the facotry rear windows and back glass, 5% tint stip across the windshield, Lo Pro Truxedo tonneu cover, Herculiner bed liner, Weather Tech Window Visors, Exhaust- Flowmaster Super 44 dumped above rear axle, Maglight Mount on side of drivers seat, Scangauge II, Mossy Oak Camo Seat Covers, Weather Tech Floor mats, Spatter painted A-Pillars, Spatter painted headunit trim and shifter trim, Headunit= Pioneer 4300 double din touch screen, Speakers- Precision Power 3 way component stage, Precision Power 8 i
    why do you want a 20 inch wheel? tires are a hell of alot more expensive
  3. Mar 5, 2013 at 8:14 AM
    Imndabuildin
    Drake
    Louisiana
    I'm tired of my wheels I have now. Also not a huge fan of having so much sidewall showing with 17s
  4. Mar 5, 2013 at 10:01 AM
    3boyztaco
    3boyztaco Well-Known Member
    in the middle of the sea
    PreRunner
    drop a note in the Hawaii section I'm pretty someone will have the 411 you are looking for. Lots of trucks run 20's out here.
