Biggest 17 inch tire with 3 inch lift
Old 03-15-2013, 10:36 AM   #1
Gloade16 [OP] Gloade16 is offline
Gloade16 is on a distinguished road
Gloade16's Avatar
Gloade16's Tacoma Gallery
Getting a 3 inch procomp lift put on my truck with UAC's, and deciding on tire size. Anyone know what size i could run without trimming? 17 inch wheels, heard people can run 285/70/17 with no rubbing but also heard that people are rubbing with this size as well.
Pictures would be appreciated!!
Old 03-15-2013, 11:21 AM   #2
IKA fabrications
bullaculla is one of the sharper tools in the shedbullaculla is one of the sharper tools in the shedbullaculla is one of the sharper tools in the shedbullaculla is one of the sharper tools in the shedbullaculla is one of the sharper tools in the shedbullaculla is one of the sharper tools in the shedbullaculla is one of the sharper tools in the shedbullaculla is one of the sharper tools in the shedbullaculla is one of the sharper tools in the shedbullaculla is one of the sharper tools in the shedbullaculla is one of the sharper tools in the shed
bullaculla's Avatar
bullaculla's Tacoma Gallery
Yep, Its different for everybody. Some people claim 285s don't rub with a lift, some people had to cut and CMC.
Some people even said that 265s will rub on their front mudflaps!
So it really depends on the backspacing and offset of your wheels, amount of caster, and if you plan on off roading or not. I like the look of 285s, but i'll stick to 265s because I plan to wheel mine, and its my DD. Gas prices suck here...
Maybe when it gets a little older, i'll be more willing to cut and go bigger, but right now it only has 3,500 miles on it.
There are a few threads here about perfect offset and backspacing to minimize rubbing, but it still differs truck to truck.
Old 03-18-2013, 05:44 PM   #3
DevL's Tacoma Gallery
Every 285/70/R17 is different in size. That said I had to do quite a bit of plastic cutting, metal trimming, mud flap removal and cab mount chop to fit 285/70R17 Nitto Trail Grapplers on 17x9 4.5" BS wheels -13mm offset.
I guarantee you, without a doubt, you cannot run 285/70R17 without trimming. Noone can. If they say they don't rub I GUARANTEE you they are lying. I had to cut quite a bit of metal and ripped off one of my rear fender flares offroading. I had to add a Ubolt flip and axle relocation plates to get the rear to clear with stock bumps.
ABOVE is PRE axle relocate plate and Ubolt flip...
ABOVE is POST cab mount chop and trimming with minimal compression... needed to set caster to over 3 degrees to clear.
ABOVE is the very start of my trimming...
You will need a cab mount chop, then cut the plastic and the black liner plastic I am holding up to and including that bottom lip below that bolt above my finger. You need to cut back the sheet metal there so its almost even with the cab mount chop then roll the lip. You need to pound the pinch weld FLAT up to thatupper cut I made in the plastic there.
ABOVE metal mount for the mud flaps cut out and the edge folded over. You can see how the tire sweeps through that area when turning and arcing side to side, especially under compression.
ABOVE you can see how you need to cut back the black liner to expose the pinch weld... it must go from sticking out into the wheel well at a 90 degree angle to being FLAT, not just folded over gently, but FLAT. Requires extensive use of a full sized sledgehammer.
With UCA that add caster by moving the UCA BACK to add 2 degrees you move the tire BACK as well meaning you compound rubbing issuus. I had PERFECT 2.5 degree caster but the wheel was too far rearward and was rubbing... had to get max caster which was over 3 degrees to get the tire to clear my cab mount POST CHOP. This first alignment was NOT ENOUGH.
Remember that 3" and lesser lifts (non drop bracket and non spindle lifts) DO NOT change rubbing... only how much compression is needed till it rubs. DO NOT let some asshat tell you that a 3" lift will "fit 285s without rubbing." Its going to rub and you need to do what is necessary to stop the rubbing. Its not rocket science. Its not difficult. It does take some tools and elbow grease and about 5 rounds of trimming bit by bit till you get a perfect, rub free fit. I was very pissed off because I listened to so many people say this would be easy as pie... it is not.
Old 03-19-2013, 05:48 AM   #4
KPT KPT is offline
sees what you did there.
KPT's Avatar
KPT's Tacoma Gallery
If you are not going to flex the suspension much, you could go with 275/70/17 and not have to trim much, if any.
But DevL's post above mine is right on, the lift won't change what rubs and doesn't rub when the suspension is compressed. Only trimming changes that.
Old 03-19-2013, 05:57 AM   #5
cbe513 is on a distinguished road
cbe513's Avatar
cbe513's Tacoma Gallery
I have 3" procomp and ride with 285x70x17 with no issues at all. Nitto Terra Grappler
Old 03-20-2013, 07:45 PM   #7
crazyasu45 is on a distinguished road
crazyasu45's Tacoma Gallery
Arrrrgggghh...I was so close to pulling the trigger on 285/70/17's till I read this thread lol back to the drawing board...
Old 03-20-2013, 07:48 PM   #8
05taco2.7 has a brilliant future05taco2.7 has a brilliant future05taco2.7 has a brilliant future05taco2.7 has a brilliant future05taco2.7 has a brilliant future05taco2.7 has a brilliant future05taco2.7 has a brilliant future05taco2.7 has a brilliant future05taco2.7 has a brilliant future05taco2.7 has a brilliant future05taco2.7 has a brilliant future
05taco2.7's Tacoma Gallery
i run 265/70/17 general grabbers
before that had 255/70/17 bfg mud terrains
both had slight rubbing at full lock
ended up shoving caster WWAAYYY forward and trimming the front bumper to fit
Old 03-20-2013, 08:00 PM   #10
Monster Coma is one of the sharper tools in the shedMonster Coma is one of the sharper tools in the shedMonster Coma is one of the sharper tools in the shedMonster Coma is one of the sharper tools in the shedMonster Coma is one of the sharper tools in the shedMonster Coma is one of the sharper tools in the shedMonster Coma is one of the sharper tools in the shedMonster Coma is one of the sharper tools in the shedMonster Coma is one of the sharper tools in the shedMonster Coma is one of the sharper tools in the shedMonster Coma is one of the sharper tools in the shed
Monster Coma's Avatar
Monster Coma's Tacoma Gallery
Just trim and CMC.. trimming is only plastic and the CMC doesnt effect anything and you'd never know..
Old 03-30-2013, 07:58 AM   #11
Speak English..it's America
testedone is a glorious beacon of lighttestedone is a glorious beacon of lighttestedone is a glorious beacon of lighttestedone is a glorious beacon of lighttestedone is a glorious beacon of lighttestedone is a glorious beacon of light
testedone's Avatar
Army: 11B
testedone's Tacoma Gallery
True on the CMC, but if you don't have access to the tools to do it or shops that are "reasonable" then it is a pain...
Couple local places told me 3 hours to do it at $95.00 an hour.... (and these were SMALL independent shops)
Old 03-30-2013, 11:14 AM   #12
IKA fabrications
bullaculla's Avatar
My biggest concern with the CMC is rust.
Old 12-18-2014, 02:21 PM   #13
sbates is on a distinguished road
Army:
sbates's Tacoma Gallery
Cbe513,
I'm interested in the same setup, including the same Nitto Tires. Just curious, did you have to install new UCA's?
Old 12-18-2014, 02:39 PM   #14
SHOKER
manethon has a brilliant futuremanethon has a brilliant futuremanethon has a brilliant futuremanethon has a brilliant futuremanethon has a brilliant futuremanethon has a brilliant futuremanethon has a brilliant futuremanethon has a brilliant futuremanethon has a brilliant futuremanethon has a brilliant futuremanethon has a brilliant future
manethon's Tacoma Gallery
i run 315/70/17s on mine and i have a 3 inch lift,
Lots of trimming for sure,
285's are super easy to fit.
Old 12-18-2014, 04:58 PM   #15
The Dank Tank
Blacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shedBlacktacoma23 is one of the sharper tools in the shed
Blacktacoma23's Avatar
Blacktacoma23's Tacoma Gallery
Do you have to? No but its worth every penny IMO. Helps with alignment and the ride!
Old 12-18-2014, 05:02 PM   #16
Hawksdenn2 has a brilliant futureHawksdenn2 has a brilliant futureHawksdenn2 has a brilliant futureHawksdenn2 has a brilliant futureHawksdenn2 has a brilliant futureHawksdenn2 has a brilliant futureHawksdenn2 has a brilliant futureHawksdenn2 has a brilliant futureHawksdenn2 has a brilliant futureHawksdenn2 has a brilliant futureHawksdenn2 has a brilliant future
Hawksdenn2's Avatar
Firefighter:
Hawksdenn2's Tacoma Gallery
I ran 285's with my 3" lift and only rubbed at full lock to the left in reverse. I trimmed a little bit of plastic and removed my flaps. Any kind of off-roading with crazy flex of course your going to rub but everday mall crawling you'll be fine! Lol
Old 12-18-2014, 05:21 PM   #17
TacoMAUI95 is on a distinguished road
TacoMAUI95's Avatar
TacoMAUI95's Tacoma Gallery
Cbe513,
Haha BUMPed.
Actually Nitto trail grapplers 265s are 31.97 and 285s are 32.67. Not a big difference really. Besides regular 265s still look good on a lift and you don't lose any suspension travel, etc. No trimming no cutting nothing necessary.
Old 12-18-2014, 06:34 PM   #18
MIGHTY TACO
PUBCRAWL will become famous soon enough
PUBCRAWL's Avatar
PUBCRAWL's Tacoma Gallery
I have 275/70-R17 Mickey Thompson STZ's on stock TRD wheels with a less that 3" lift.
OME 885's LR UCA's and 5100's on all four wheels with Wheeler 1 1/2" Progressive 3 leaf AAL with a 1" block with the overload spring removed.
No rubbing or issues at all.
Biggest 17 inch tire with 3 inch lift-uploadfromtaptalk1418956068774.jpg   Biggest 17 inch tire with 3 inch lift-uploadfromtaptalk1418956112408.jpg
Old 12-31-2014, 05:29 AM   #19
lickskillet is on a distinguished road
lickskillet's Avatar
lickskillet's Tacoma Gallery
Noob here and Im getting ready to do the same thing... I have to ask,,, what is CMC?
Biggest tire for 3 inch lift 06 tacoma owner Suspension 7 01-09-2013 02:58 PM
What's the biggest tire size you cat fit on a stock off road wheel? 16 inch ToyotaKTMracing 2nd Gen. Tacomas 3 03-26-2012 09:16 AM
Biggest tires on 3 inch lift Grey Jay 2nd Gen. Tacomas 22 04-30-2010 01:35 PM
wtb- 33 inch tires for 17 inch rims toyotadude5 Buy / Sell / Trade 1 11-23-2009 02:46 PM
BIGGEST tire for 3" inch Lift? 09SWTacotrd Wheels & Tires 4 09-10-2009 10:27 PM
