Check my math for new wheels/tires setup...
Old 04-11-2013, 12:58 AM   #1
Bravo1 [OP] Bravo1 is offline
Bravo1 is a splendid one to beholdBravo1 is a splendid one to beholdBravo1 is a splendid one to beholdBravo1 is a splendid one to beholdBravo1 is a splendid one to beholdBravo1 is a splendid one to beholdBravo1 is a splendid one to behold
Bravo1's Avatar
Bravo1's Tacoma Gallery
After reading up on the specs in the stickies, I think I have this figured out for my new wheels/tires to replace stock ones. I have a 2010 DC 4x4 Sport with Bilstein 5100s set at 1.75 in the front and the replaced TSB leafs in the rear.
I'm looking at getting the Pro Comp La Paz 5029 which are 17x8.5 with b/s of 4.75. Tires will be 265/70/17 General Grabbers AT2. Since the new wheels are 1" wider than stock (7.5) and the b/s is 4.75 on the new wheels vs 5.5" on stock, my calculation is that the new combo will stick out 1.75" farther than the stock tires do. Am I correct???
I don't want too much of a protrusion outside of the fender wells but I'm hoping this will be enough to give the truck a better looking stance.
Old 04-11-2013, 05:39 AM   #2
KPT KPT is offline
sees what you did there.
KPT's Avatar
KPT's Tacoma Gallery
You sir, are correct.
Old 04-11-2013, 11:29 PM   #3
Bravo1's Avatar
Thanks for the help KPT.
Would you happen to know about the TPMS and whether the OEM system would work on a Pro Comp wheel? I've searched both here and the web and found some that say it will and some that say no, but not for this specific wheel. I looked on Pro Comps web site but there is no info that I can find.
Is my best bet to call Pro Comp or is there any other place you might suggest I look?
Thanks again
Old 04-11-2013, 11:37 PM   #4
2010 double cab TRD Sport
El Tano is one of the sharper tools in the shedEl Tano is one of the sharper tools in the shedEl Tano is one of the sharper tools in the shedEl Tano is one of the sharper tools in the shedEl Tano is one of the sharper tools in the shedEl Tano is one of the sharper tools in the shedEl Tano is one of the sharper tools in the shedEl Tano is one of the sharper tools in the shedEl Tano is one of the sharper tools in the shedEl Tano is one of the sharper tools in the shedEl Tano is one of the sharper tools in the shed
El Tano's Avatar
El Tano's Tacoma Gallery
I have 17x9, BS: 5.00" and P265/70R17 (113S) - Terra Grappler.
This is how it looks. Hope it helps.
Old 04-12-2013, 03:48 PM   #5
KPT KPT is offline
KPT's Avatar
Thanks again
If you have alloy wheels now, the sensors will fit on most all aftermarket wheels.
Old 04-15-2013, 09:53 PM   #6
Bravo1's Avatar
I do have the alloys now on my Sport model. I'm hoping the TPMS will work in the Pro Comps; the price of having to get new ones, PLUS the requirement to have them "registered" (or whatever they call it at the dealer) really jacks the price up overall. Ah for the good ol' days of just using a tire gauge on a regular basis...
Thanks a lot for the help guys, I appreciate it.
Can someone check my math - buying a travel trailer Ryan5150 2nd Gen. Tacomas 0 11-28-2012 09:48 PM
Swapping Wheels/Tires/TPMS - Best Way To Resell OEM Setup MikeyMcFly Wheels & Tires 5 11-21-2012 09:06 AM
New wheels and tires check them out Sanders17 2nd Gen. Tacomas 32 10-09-2011 10:31 PM
Check it! New wheels/tires/light bar gassman 2nd Gen. Tacomas 14 02-03-2011 09:19 PM
3 guys check into a hotel... (Math Problem) thecoldone06 Off-Topic Discussion 29 03-26-2009 09:17 AM
