Biggest tires without lift..please advise
Old 04-15-2013, 10:32 AM   #1
jsroth17 [OP] jsroth17 is offline
jsroth17 is on a distinguished road
EMS:
jsroth17's Tacoma Gallery
What are the largest tires I can fit without a lift on my 11' double cab 4x4 trd?
Also, if I use a leveling kit, what can I use then tire wise?
Old 04-15-2013, 10:35 AM   #2
Red
Large's Tacoma Gallery
Probably the most asked question on here. There is really too many variables to answer your question. Try using the search button or there are similar thread links on the bottom of this page.
Old 04-15-2013, 10:37 AM   #3
Resident Jackass
Krazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shedKrazie Sj is one of the sharper tools in the shed
Krazie Sj's Avatar
EMS: EMT - Alberta Health Services - Olds
Krazie Sj's Tacoma Gallery
265x75R16
265x70R17
Leveling kit won't give you anything extra unless you go up 2.5". Which is now a lift kit versus a leveling kit. Additionally when you start going bigger than the tires I listed you run into problems with the tires hitting the UCAs. So you need more off set. Additionally you need new UCA's to fix the alignment so you don't get shitty handling.
Old 04-15-2013, 11:23 AM   #6
uncoordinated dirtbox
Brandon9402 is one of the sharper tools in the shedBrandon9402 is one of the sharper tools in the shedBrandon9402 is one of the sharper tools in the shedBrandon9402 is one of the sharper tools in the shedBrandon9402 is one of the sharper tools in the shedBrandon9402 is one of the sharper tools in the shedBrandon9402 is one of the sharper tools in the shedBrandon9402 is one of the sharper tools in the shedBrandon9402 is one of the sharper tools in the shedBrandon9402 is one of the sharper tools in the shedBrandon9402 is one of the sharper tools in the shed
Brandon9402's Avatar
Brandon9402's Tacoma Gallery
you could fit 380/90/24 but you might have to trim a small amount
Old 04-21-2013, 03:41 AM   #7
Longtime Toyman
4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed4Wheelin4Banger is one of the sharper tools in the shed
4Wheelin4Banger's Avatar
Navy: DDG 996
Location: Ferntucky, NV Halfway between Reno & Falabama
4Wheelin4Banger's Tacoma Gallery
Sticky: Largest Tacoma Tire Sizes On Stock Suspension by tcBob
tcBob 12-30-2009 08:44 PM
Old 04-21-2013, 06:31 PM   #8
Gearheadesw is one of the sharper tools in the shedGearheadesw is one of the sharper tools in the shedGearheadesw is one of the sharper tools in the shedGearheadesw is one of the sharper tools in the shedGearheadesw is one of the sharper tools in the shedGearheadesw is one of the sharper tools in the shedGearheadesw is one of the sharper tools in the shedGearheadesw is one of the sharper tools in the shedGearheadesw is one of the sharper tools in the shedGearheadesw is one of the sharper tools in the shedGearheadesw is one of the sharper tools in the shed
Gearheadesw's Avatar
Gearheadesw's Tacoma Gallery
I have 275/70r/17's on my stock 2012 Sport
Old 04-22-2013, 12:40 AM   #9
DevL's Tacoma Gallery
3" style lifts do not change what tire can fit. The tires still extend to the same point and compress to the same bump stops. If it rubs with stock suspension it will rub with a lift... it might just take a little more compression to do so.
Old 04-22-2013, 12:45 AM   #10
BMOC is one of the sharper tools in the shedBMOC is one of the sharper tools in the shedBMOC is one of the sharper tools in the shedBMOC is one of the sharper tools in the shedBMOC is one of the sharper tools in the shedBMOC is one of the sharper tools in the shedBMOC is one of the sharper tools in the shedBMOC is one of the sharper tools in the shedBMOC is one of the sharper tools in the shedBMOC is one of the sharper tools in the shedBMOC is one of the sharper tools in the shed
BMOC's Avatar
BMOC's Tacoma Gallery
pretty big if you tubbed the fender well and trimmed your bedsides.
Old 04-22-2013, 04:40 AM   #11
joeyd27 is on a distinguished road
joeyd27's Tacoma Gallery
Does anyone run 265/75-16 BFG A/T on stock TRD OR? I know that different brand tires, even though labeled the same can be quite a bit different. Just want to be sure before I buy!
Old 04-22-2013, 04:56 AM   #12
Red
Pics?
Old 04-22-2013, 10:39 AM   #13
Fuck this piece of shit phone
Old 04-22-2013, 04:56 PM   #14
Resident Jackass
Krazie Sj's Avatar
265x75R16 on stock TRD OR.
Old 04-22-2013, 05:17 PM   #15
Thanks... Looks great!
Old 04-23-2013, 06:42 PM   #16
Kinda crappy pics, but those are 275/70r/17's, stock suspension, and wheels.
Biggest tires without lift..please advise-img_0140.jpg   Biggest tires without lift..please advise-p5050018.jpg   Biggest tires without lift..please advise-p5050024.jpg
Biggest Tires that will fit without lift 05PreRunner Wheels & Tires 16 12-28-2013 07:28 PM
What are the biggest tires that fit without a lift? ChaseUA 2nd Gen. Tacomas 14 10-14-2010 06:27 PM
Biggest tires on 3 inch lift Grey Jay 2nd Gen. Tacomas 22 04-30-2010 02:35 PM
Biggest tires without a lift lancef Wheels & Tires 13 12-21-2009 07:34 PM
Lift and tires, advise... cctaco Suspension 2 11-11-2009 01:30 PM
