285/75/16 on first gen
Discussion in 'Wheels & Tires' started by MattHKD, Apr 25, 2013.
  1. Apr 25, 2013 at 9:54 AM
    MattHKD
    MattHKD [OP] Well-Known Member
    Hi, I've tried searching but I can't seem to find an answer to my question. I'm looking at picking up a set of the TRD fj wheels which are 16x7.5 4.5" backspacing (I believe) with 285/75/16 tires on them. I have about 2" of lift front and rear on my '02 4x4, and I was wondering if these will fit, and if they won't, how much trimming would be needed and where? I do take my truck offroad, so flex compression needs to be considered too.
    Thanks for your help!
  2. Apr 25, 2013 at 7:13 PM
    MattHKD
    Any ideas?
  3. Apr 25, 2013 at 11:14 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    You should be good. You'll rub the frame at full lock, but it's going to be minor. Between the tire and your UCA, you'll have about 1-1.25" of clearance.
  4. Apr 25, 2013 at 11:19 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    I had 285s on my stock wheels and rubbed on the frame at full lock and on the UCAs.
  5. Apr 25, 2013 at 11:20 PM
    livel0veryde
    livel0veryde Well-Known Member
    josh
    missouri
    Tacoma based buggy
    it will rub a little bit, but nothing to worry about.
  6. Apr 26, 2013 at 5:37 PM
    MattHKD
    Thanks everybody, I'll go ahead and get them then.
  7. Apr 26, 2013 at 6:43 PM
    Poorboyota26
    Poorboyota26 Well-Known Member
    Kevin
    Frisco, CO
    Your standard farm truck
    3" Lift, Rock sliders, Winch, 32's, 4.88's
    this is with stock springs on rear
  8. Apr 26, 2013 at 6:52 PM
    02goldie
    02goldie Well-Known Member
    Brock
    Lenoir, NC
    2016 Sport DCSB 4x4
    OME lift, spidertrax, 285 duratracs
    just installed mine. 3" lift, 1.25" spidertrax wheels spacers, 285/75/16 duratracs. i just hammered the pinch weld a little bit and im good
    cb25fec0-22ce-4330-8d37-079bf52051fa_zps_c39da3da6d7e2844478d5d3e7c31623f092b2109.jpg
    cwtoy likes this.
  9. Apr 27, 2013 at 11:24 AM
    MattHKD
    Thanks for all your help, I'll post pictures when I get them on. I hope it turns out as good as goldie's. Looks so good.
  10. Nov 7, 2014 at 9:46 PM
    AppMtnTaco
    AppMtnTaco No Colon, Still Rollin’
    Nick
    Littleton, Co
    Black 2003 SR5 4X4
    3in Lift with Toytec/Bilstein Coilovers, AllPro 3 inch rear leafs and ToyTec shackles. Trail Gear front tube bumper and sliders. Satoshi Grille with custom Hella light mount. Custom bedrack with Yakima Basket. Future mods- Going long travel!!!!!!!
    No rubbing at all? what about mileage with those 285s?
  11. Nov 8, 2014 at 10:41 AM
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    You didn't have to trim the valence?
  12. Nov 8, 2014 at 10:59 AM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    I use to have them with 1.5" spacers
  13. Nov 9, 2014 at 7:55 AM
    02goldie
    Brock
    Lenoir, NC
    2016 Sport DCSB 4x4
    No rubbing at all under normal driving conditions. only time it happens is if the wheels are turned and going over a pretty big bump or something. ive had an ultraguage for a while now and it stays around 17.3 mpg. i do mostly city driving so could be better if i drove more highway.
    I trimmed jus a small corner out of the valence closest to the tires jus to be sure. probably doesnt need it but only takes 5 min to cut.
  14. Nov 9, 2014 at 8:00 AM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Ok, just wondering cause I'm getting the OME 3" lift and wanted to know if I had to trim that or not. Just got it replaced after an accident so I didnt want to have to cut it up or anything like that
  15. May 11, 2016 at 1:13 PM
    kiteboarder
    kiteboarder Well-Known Member
    Danny
    SoCal
    I drive stick. Only.
    To come.
    17.3 MPG. Any idea what it was before the 285s?
  16. Nov 13, 2018 at 1:38 PM
    Marcoma91
    Marcoma91 Well-Known Member
    Marc
    Los Angeles
    2002 Tacoma PreRunner Dbl Cab. Bilstien 5100, OME 883, AAL, 265/75 R16
    I have 3 inch lift and icon uniball UCA. Does anyone know if 285/75 R16 would still rub? Im guessing that when turned and hitting bumps yes. Thanks
  17. Nov 13, 2018 at 1:58 PM
    Icon_Madison
    Icon_Madison Member Vendor
    Madison
    Riverside CA
    You shouldn't have a problem running that size tire with our kit as long as your wheel are within our recommended spec which is 8.5" Wide, 4.75" Backspace!
    if you have any other questions, feel free to ask!
    951-689-4266 EXT 109
    Madison@iconvehicledynamics.com
  18. Nov 13, 2018 at 4:49 PM
    Marcoma91
    Marc
    Los Angeles
    Awesome. Thanks for the info. If I have any other questions ill be sure to reach out to you.
    Icon_Madison[QUOTED] likes this.
  19. Jun 30, 2020 at 11:34 PM
    Cinchman19
    Cinchman19 Active Member
    Mark
    Las Vegas
    2001 2wd prerunner v6 Tacoma
    Hey guys I have a icon lift at 2.75in and a spc uca. Just got some new wheels 16x8 0 offset. And 285/75/16 Patagonia MTs. Will I rub on the frame rail? Should I get spidertrax wheel spacers?
  20. Jul 1, 2020 at 9:26 AM
    Poorboyota26
    Kevin
    Frisco, CO
    I would say yes because it will rub on the top of the spindle. I don't know though because I have only used stock offset rims. the other bit is that some tire shops wont touch it with wheel spacers so when you get tire work done it's a pain so keep tires to run on when you need to get a balance done or something.
