Risks of Wheel Spacers?
Discussion in 'Wheels & Tires' started by DSully72, May 19, 2013.
  1. May 19, 2013 at 5:38 PM
    DSully72
    DSully72 [OP] 2WD Problems
    Daniel
    Appling, GA
    04 PreRunner TRD Off Road
    Alright guys, I searched for a thread about this particular topic and couldn't find one, so I'm sorry if its already been posted, but I have a question that I hear one answer to and then I'll turn around and hear another. What are the risks if I use wheel spacers rather than buy new rims with a smaller backspacing? I do understand that widening the stance can increase stress on the hubs and studs and perhaps some suspension components, but is it that big of a deal? Is it negligable?
  2. May 19, 2013 at 5:46 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Wheel spacers or even different wheel specs can put more stress on wheel bearings and wear them out faster. Wheel spacers, you just have to be careful with, make sure you use the provided loc-tite, torque them on and check them frequently. Go with a reputable brand. Personally, I wouldn't want them on my truck, I'd rather get wheels with the proper backspacing, I wouldn't want the potential failure point.
  3. May 19, 2013 at 5:51 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    X2
  4. May 19, 2013 at 5:53 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    thousands of miles here with spacers with no problems, a lot of Long travel guys run them without issues
  5. May 19, 2013 at 5:59 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Wheel spacers and different wheels with back spacing just put more stress on your wheel bearings/wheel studs. Expect your wheel bearings to last a little shorter time. I have spacers in the rear. Work fine.
  6. May 19, 2013 at 6:08 PM
    jandrews
    '09 FourDubDee TRD OR
    As noted, a little bearing wear, but frankly running larger tires and getting in the dirt does way more in the way of wear and tear than spacers do.
    Take your time to ensure they are installed correctly. Clean the hub and studs thoroughly. Use red loctite. Give each spacer a full 10 minutes for the locktite to set before putting the wheel on. Do not overtorque the lug nuts.
    Common sense will prevail.
  7. May 19, 2013 at 6:13 PM
    PLC721
    Patrick
    Chandler, Az
    Did you end up running spacers in the rear? the Stealth 6's are 4.3" backspacing right?
  8. May 19, 2013 at 6:17 PM
    jandrews
    They are and I ended up running 1.25s all around. The rear needed 'em, did the front for symmetry.
    Should help when it's time to clear dirty-fives :spy:
  9. May 19, 2013 at 6:20 PM
    PLC721
    Patrick
    Chandler, Az
    Okay thats what i have too, i was hoping to go down to a .5" with the stealth 6's
  10. May 19, 2013 at 6:30 PM
    DSully72
    Daniel
    Appling, GA
    Thanks guys! As far as of road applications go, would I be hurting anything running spacers more so than if I was running smaller backspaced rims? I have 265/75R16 and I eventually wanna go to 285, so I'm going to have to space out one way or another. I'm already rubbing slightly on the drivers side at full lock.
  11. May 19, 2013 at 6:34 PM
    jandrews
    Offroad just takes onroad wear and multiplies it by orders of magnitude.
    So no, nothing new. What would've happened in 50,000mi on pavement will take 5,000 off it.
    Might be able to. I got the 1.25 because I knew I wanted to go to a larger tire later on.
  12. May 19, 2013 at 6:35 PM
    Crydaddy
    Crydaddy Well-Known Member
  13. May 19, 2013 at 6:37 PM
    DSully72
    Daniel
    Appling, GA
    Well would it be the same difference to add say a half inch spacer to a 16x8 inch rim with 4.5 back spacing as running a 16x8 inch rim with 4 back spacing?
  14. May 19, 2013 at 6:37 PM
    redtacoma88
    redtacoma88 Well-Known Member
    John Austin
    TN
    2012 TRD Off Road
    See Build Page...
    ive had my 1.25" wheel spacers for 5000 miles. on road and beaten them offroad, not a single problem plus my truck has the perfect stance with them!
  15. May 19, 2013 at 6:37 PM
    jandrews
    The physics are identical.
  16. May 19, 2013 at 6:37 PM
    Pugga
    Massachusetts
    That's a good answer.
  17. May 19, 2013 at 9:27 PM
    bajatrailrider
    bajatrailrider Bajatrailrider
    Larry
    CALIF
    12 prerunner SR5
    Prerunner bumper,Lifted 4-3
    I already have over 10,000 miles on my 12 DC 1.25 spacers on frt 50% street 50% hard Baja off road.So far no problems
