Wheel and Tires
Old 05-28-2013, 12:24 PM   #1
Newby [OP] Newby is offline
Newby is on a distinguished road
Newby's Tacoma Gallery
Wheel and Tires
Hello everyone,
I just bought a Tacoma and the Wheel and Tires are now size 235/75/15. I would like to change the tires to size 31x10.5R15. I looked at the label on the Driver Side Door and it says 10.50R15. What does the 10.50R15 mean? Is it the recommendation size? Since the Wheel is 15, can I change the tires to size 31x10.50R15? I need your help please.
Newby
Old 05-28-2013, 12:44 PM   #2
Wheel and Tire Guys
Discount Tire Direct has a brilliant futureDiscount Tire Direct has a brilliant futureDiscount Tire Direct has a brilliant futureDiscount Tire Direct has a brilliant futureDiscount Tire Direct has a brilliant futureDiscount Tire Direct has a brilliant futureDiscount Tire Direct has a brilliant futureDiscount Tire Direct has a brilliant futureDiscount Tire Direct has a brilliant futureDiscount Tire Direct has a brilliant futureDiscount Tire Direct has a brilliant future
Discount Tire Direct's Avatar
Discount Tire Direct's Tacoma Gallery
What year and trim is your Tacoma? Also, is it lifted? We'd be happy to check the fitment for you.
Old 05-28-2013, 12:51 PM   #3
It's 96 Tacoma Ext Cab SR5 V6 4x4. It's not lifted. It looks regular to me. The Rims are seem original with the truck but they are painted in black now.
Old 05-28-2013, 01:34 PM   #4
I'll keep the overall diameter of the wheel, 15 as I mentioned above, can I keep this diameter by going with a wider and taller tire? According to the label on the Driver Side Door, the recommendation is 10.50R15, isn't it? Please give me the Pro and Con on the wider and taller size.
Old 05-28-2013, 01:52 PM   #5
You can't see me
dand has much to be proud ofdand has much to be proud ofdand has much to be proud ofdand has much to be proud ofdand has much to be proud ofdand has much to be proud ofdand has much to be proud ofdand has much to be proud ofdand has much to be proud ofdand has much to be proud of
dand's Avatar
dand's Tacoma Gallery
31x10.5x15's will fit fine.
Old 05-28-2013, 03:02 PM   #6
Thank you so much.
Old 05-28-2013, 05:03 PM   #7
Wheel and Tire Guys
Yes, it looks like some models in 96 came stock with optional 31x10.50R15 tires. These should fit like a glove. Running a taller tire will give you some additional clearance off road and it will help fill your wheel wells. Con would be less MPG than you are probably getting now.
Old 05-28-2013, 05:18 PM   #8
Ok, good. Thanks for your subjection. I'll take the 31x10.50R15. I like it best.
Old 05-28-2013, 05:28 PM   #9
Wheel and Tire Guys
You are welcome any time.
Tire/Wheel Package - TPMS Sensors, Tires, Steel Wheel, Caps, Lugs (2012 Used) Kevoh Buy / Sell / Trade 11 04-17-2013 06:30 PM
B/S/T for wheel and tires only tostidos Site Suggestions 8 08-21-2012 09:25 AM
WTT: my wheel's and tires for yours? MattDubs Florida 1 06-26-2011 04:16 PM
lift wheel and tires ? jordando89 2nd Gen. Tacomas 4 04-04-2011 07:15 PM
Wheel's on the way....now I need help with tires. BluTaco08 Wheels & Tires 1 02-12-2009 04:17 PM
