17" FJ Cruiser wheel cleaner
Old 07-13-2013, 10:23 PM   #1
TAC1 [OP] TAC1 is offline
TAC1 is one of the sharper tools in the shedTAC1 is one of the sharper tools in the shedTAC1 is one of the sharper tools in the shedTAC1 is one of the sharper tools in the shedTAC1 is one of the sharper tools in the shedTAC1 is one of the sharper tools in the shedTAC1 is one of the sharper tools in the shedTAC1 is one of the sharper tools in the shedTAC1 is one of the sharper tools in the shedTAC1 is one of the sharper tools in the shedTAC1 is one of the sharper tools in the shed
TAC1's Avatar
Name: Petros "Peter" AGE: 41
TAC1's Tacoma Gallery
Hello Forum,
I have a set of FJ wheels that I will be purchasing 275/70r17 BFG A/T's for towards the end of the year. I have a questions regarding the clear coat. In the pics you'll notice some scuff & scratch marks.
I know that:
* I can take my wheels to a body shop & have them strip the clear coat off & apply a new coat of clear (don't have any idea how much that will cost me).
* I can strip off all the clear but then the wheels will probably require frequent polishing to maintain the shine.
* I can leave them as is.
* Or, is there a way to polish or wet-sand the scratched/scuffed parts of the wheels to at least be able to remove some of the scratches?
Here are the pics.
Let me know your opinions, personal experiences, cost to have these re-clear coated, or advice.
Thanks Forum
Is there a way for me to polish or clean those scratches off of the wheels?
Old 07-13-2013, 10:40 PM   #2
Fortified with horsepower-adding goodness...
WHPLSH3 is one of the sharper tools in the shedWHPLSH3 is one of the sharper tools in the shedWHPLSH3 is one of the sharper tools in the shedWHPLSH3 is one of the sharper tools in the shedWHPLSH3 is one of the sharper tools in the shedWHPLSH3 is one of the sharper tools in the shedWHPLSH3 is one of the sharper tools in the shedWHPLSH3 is one of the sharper tools in the shedWHPLSH3 is one of the sharper tools in the shedWHPLSH3 is one of the sharper tools in the shedWHPLSH3 is one of the sharper tools in the shed
WHPLSH3's Avatar
WHPLSH3's Tacoma Gallery
2 threads?!
Unless your local bodyshop repairs wheels, they won't touch them. Machined wheels take a special clear that 1) is designed to stick to unprimed metal, and 2) is more durable (harder) than regular clear. It's actually powdercoated on...
My suggestion- aquire a 3" dual action polisher with appropriate pads & compound and polish them. They won't be perfect, but I'd say you could probably get back 75%.
Removal of all the clearcoat requires machining on a wheel lathe if you want them to look right
Old 07-13-2013, 11:07 PM   #3
TAC1's Avatar
Yeah. I should have just put it in the Wheels & Tires section. You're right.
Just to make sure I understand you. I can polish the areas that are scratched & get some improvement & NOT remove the clear coat? Basically, I am polishing, not removing the clear coat?
I just want to make sure.
Thanks!
Old 07-14-2013, 09:13 AM   #4
WHPLSH3's Avatar
Thanks!
Yes. Unless you're using very heavy cut compound on a very agressive pad, on a machine that's turning too many rpm, it's unlikely you will wreck the clearcoat.
Just remember to keep the pad flat on the surface. Never let it dig on an edge, and always motion the machine so the rotations sweep off an edge, not grab it. (This applies to a non dual action machine. DA makes it nearly impossible to ruin anything, regardless of inexperience.)
I think you should do just fine
17" FJ Cruiser wheel clear coat (with pics) TAC1 2nd Gen. Tacomas 1 07-13-2013 10:57 PM
FJ Cruiser Air Pre Cleaner ? scotch 2nd Gen. Tacomas 2 07-02-2013 03:52 PM
WHEELS: 17" Tacoma TRD vs 17" FJ Cruiser TAC1 2nd Gen. Tacomas 27 02-02-2013 08:57 PM
FJ Cruiser 17" Wheels Bama_TACO 2nd Gen Tacoma Marketplace 0 06-21-2012 02:16 PM
FJ Cruiser 17" alloys gusher 2nd Gen. Tacomas 19 01-07-2010 11:43 AM
