Alignment results and pulling to the right
Old 12-11-2013, 11:15 PM   #1
Saratogian
DefyInertia is on a distinguished road
DefyInertia's Avatar
DefyInertia's Tacoma Gallery
Just had new tires installed and alignment done. I have Toytec coil overs with LR UCAs and AAL out back. Tires are BFG A/T KO 265/75/16
Steering wheel must be turned to the right quite a bit to hold a straight line (pulls hard left when steering wheel is straight). Alignment results are as follows.
I'll be taking it back to the shop ASAP. What a pain in the a$$.
Old 12-11-2013, 11:24 PM   #2
Salesman by trade, Gentleman by habit
Mr. Biscuits is one of the sharper tools in the shedMr. Biscuits is one of the sharper tools in the shedMr. Biscuits is one of the sharper tools in the shedMr. Biscuits is one of the sharper tools in the shedMr. Biscuits is one of the sharper tools in the shedMr. Biscuits is one of the sharper tools in the shedMr. Biscuits is one of the sharper tools in the shedMr. Biscuits is one of the sharper tools in the shedMr. Biscuits is one of the sharper tools in the shedMr. Biscuits is one of the sharper tools in the shedMr. Biscuits is one of the sharper tools in the shed
Mr. Biscuits's Avatar
Mr. Biscuits's Tacoma Gallery
did you have a question?
Old 12-11-2013, 11:51 PM   #3
Saratogian
Venting I suppose. Open to advice or Confirmation that they messed it up. Dude also smudged the hell out if my white lettering and forgot one valve stem cap, which I noticed before leaving.
But all my searching tells me I need something close to 0 toe, 0 camber, and 2.5 caster. Also, should the rear be dead straight or what? Mechanically inclined but new to lifts and alignments.
Still reading...
Old 12-12-2013, 12:10 AM   #4
I believe camber and caster are inversed. where you gain one, you lose the other. so the mechanic has to not rely on the computer and actually do some work.
and just looking at that sheet there's definitely work to be done. where did you go for the align?
Old 12-12-2013, 12:11 AM   #5
OZ-T's Avatar
OZ-T's Tacoma Gallery
You can adjust camber and caster with the LR UCAs as well as with the LCA cams
Old 12-12-2013, 12:12 AM   #6
OZ-T's Avatar
What did you clock the LR UCA ball joint to ?
Old 12-12-2013, 12:14 AM   #7
Saratogian
I set it per the instructions, which I believe was 2.0 but would have to check. I went with what was to recommended by LR. I installed it all my self and am assuming I need to recheck/torque everything once these folks are done messing with alignment.
Edit - confirmed, +2.0 (position D) for total arm + ball joint caster change, which is 0 for the ball joint setting.
Old 12-12-2013, 12:16 AM   #8
Saratogian
I was there at end of the day and tech seemed lazy. He left before I even got my truck back or paid.
Rolling Stock in SF at 16th and Vann Ness. Good rep on yelp, FWIW.
Thanks for the help
Old 12-12-2013, 12:25 AM   #9
OZ-T's Avatar
There is a chance they are fighting seized alignment cam bolts , that's pretty common
If they aren't aware , they can adjust camber at the top nut of the balljoint to at least get your camber numbers equal
Old 12-12-2013, 12:26 AM   #10
Thanks for the help
I know most will disagree, and the quality of work had varied from store to store, but Sears offers a great deal on alignments. you can get one, but the value is in their 6 month, 12 month, and unlimited plans. you can go back every day and get a new alignment free of charge! makes it easier for us truck guys who will see our vehicles out of alignment very often.
Old 12-12-2013, 12:29 AM   #11
OZ-T's Avatar
OP , the first post of this thread is a good read for alignment using the LR UCA's
http://www.tacomaworld.com/forum/sus...cing-ucas.html
I'm off to bed , so perhaps I'll check back in tomorrow
Old 12-12-2013, 12:32 AM   #12
Saratogian
And here is before and after
Old 12-12-2013, 08:19 AM   #13
Saratogian
Perhaps. Truck has been in Cali all it's life and has 68,000 miles, no rust or corrosion really anywhere.
Massively helpful, thank you.
So the fact that my steering wheel is cocked to the right is somewhat unrelated to the alignment, yes? Meaning they probably need to fix at the same time but they are two separate problems.
Old 12-13-2013, 02:58 PM   #14
Saratogian
telling me best they can do. Truck still pulls left so discussing refund and go elsewhere. Nice people, but not getting it done.
Old 12-13-2013, 05:10 PM   #15
Saratogian
Final result and steering wheel still slightly off
2012 Alignment Results with 2" leveling Kit JRod4928 2nd Gen. Tacomas 12 10-16-2012 05:15 AM
Alignment is pulling wheels HARD jeremy_283 Wheels & Tires 5 10-10-2012 05:21 PM
Help me analyze my alignment results DNG Suspension 11 12-04-2011 06:48 PM
Alignment results - 1st Gen, 2.5" lift, Stock UCAs phidauex Suspension 0 11-16-2010 01:33 PM
Truck Pulling To The Right After Alignment 09tacomg 2nd Gen. Tacomas 11 08-12-2010 01:24 AM
