Wheel Specs
Old 12-04-2013, 06:48 PM   #181
mike2100 is on a distinguished road
mike2100's Tacoma Gallery
Originally Posted by shackley View Post
I pieced this together from the TRDparts4U and discussions with my Discount Tire guy for the TRD Baja wheels:
TRD Baja Alloy Wheels: 16x7.5, 6 to 10 mm offset, ? backspacing, 6x5.5" bolt pattern, 106mm hub bore, 5.5 inch bolt circle, ? lbs
Didn't find weight or backspacing.
http://www.trdsparks.com/displaypart...&parts_id=4699
Same info here. Original post needs to be updated...
Old 12-16-2013, 08:10 PM   #182
Granite Guru
Spoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shedSpoonman is one of the sharper tools in the shed
Spoonman's Avatar
Spoonman's Tacoma Gallery
Anyone running a 17x9.5 with 4" or 4.75" backspacing?
I can't decide which to go with.
Old 02-03-2014, 11:53 AM   #183
jeffvt0508 is one of the sharper tools in the shedjeffvt0508 is one of the sharper tools in the shedjeffvt0508 is one of the sharper tools in the shedjeffvt0508 is one of the sharper tools in the shedjeffvt0508 is one of the sharper tools in the shedjeffvt0508 is one of the sharper tools in the shedjeffvt0508 is one of the sharper tools in the shedjeffvt0508 is one of the sharper tools in the shedjeffvt0508 is one of the sharper tools in the shedjeffvt0508 is one of the sharper tools in the shedjeffvt0508 is one of the sharper tools in the shed
jeffvt0508's Avatar
jeffvt0508's Tacoma Gallery
I read... I might have misread but whats the weight difference btw 16in. alloy wheels ( trd off-road) and 16in. spare wheel ( black steel ones under the bed) just the wheel
Old 02-04-2014, 04:55 AM   #184
I weighed both back to back on the same scale and there was a 2 lb difference.
21 lbs vs. 23 lbs.
On a separate scale I weighed the spare and came up with just under 25 lbs. I couldn't confirm the 2 lb weight difference from the TRD Off Road wheels because by that time they were mounted back on my truck.
Old 02-04-2014, 04:59 AM   #185
jeffvt0508's Avatar
no worries thanks that helps a lot.. I was wondering if it was my crappy tire or the steel wheel makin my truck sluggish
Old 02-08-2014, 01:51 PM   #186
‹^› ‹(ಠ_ಠ)› ‹^›
NYCO is one of the sharper tools in the shedNYCO is one of the sharper tools in the shedNYCO is one of the sharper tools in the shedNYCO is one of the sharper tools in the shedNYCO is one of the sharper tools in the shedNYCO is one of the sharper tools in the shedNYCO is one of the sharper tools in the shedNYCO is one of the sharper tools in the shedNYCO is one of the sharper tools in the shedNYCO is one of the sharper tools in the shedNYCO is one of the sharper tools in the shed
NYCO's Avatar
NYCO's Tacoma Gallery
from TRD, http://www.toyotaracing.com/trd/part...categories=all
10mm offset with the 7.5" width should be 4.14" BS
centerline=3.75"
positive 10mm offset=0.39"
calculated BS 4.14"
https://www.rsracing.com/tech-wheel.html
Old 02-09-2014, 06:05 AM   #187
http://www.customwheeloffset.com/tir...et-calculators
4.64" according to this
Old 02-09-2014, 07:00 AM   #188
‹^› ‹(ಠ_ಠ)› ‹^›
NYCO's Avatar
Dafaq now I'm confused
Old 02-09-2014, 07:01 AM   #189
‹^› ‹(ಠ_ಠ)› ‹^›
NYCO's Avatar
Makes sense per that chart I posted
Old 02-09-2014, 07:05 AM   #190
‹^› ‹(ಠ_ಠ)› ‹^›
NYCO's Avatar
Looks like centerline is .5" from what I was thinking center is.
0 offset on 6" is 3.5". 0 on a 8" is 4.5"
Not quite center
Old 02-09-2014, 07:06 AM   #191
‹^› ‹(ಠ_ಠ)› ‹^›
NYCO's Avatar
There's the difference in my 4.14" versus the 4.64".
Old 03-01-2014, 01:45 PM   #192
gtokarski is on a distinguished road
gtokarski's Tacoma Gallery
Did some research for comparison purposes:
Wheel Specs-185737d1355965532-toyota-tacoma-trd-off-road-alloy-wheels-tires-wheel-close-up.jpg
TRD Off-Road Wheels: 16x7, +32 mm offset, 5.25" backspacing, 6x5.5" bolt pattern
Part Number:
69461
42611AD030
42611AD031
Item Weight: 22.3lbs http://www.tacomaworld.com/forum/2nd...el-weight.html
1st Gen Tacoma:
5 spoke 'Star' TRD alloys 16x7 4.5" backspacing, 15mm offset
Part Number:
69395
TWTP15UN5992Z
426110C020
4261135170
Interchange:
Sequoia '01-'02
Tacoma '01-'04
Tundra '00-'04
16 hole The 16"x7" steel (from a 1st gen tacoma)
4.5" backspace
15mm offset
Item Weight: 26-31.8 lbs (unverified)
Manufacturer's Part Number: 426010C010
Interchange Number: 69392
WTAM SKU#: STL69392U20
Interchange:
Sequoia '01-'04
Tacoma '01-'04
Tundra '00-'04
2nd gen 16x7" steel spare: 2005+
oval hole next to valve stem
Interchange Number: 560-69482 (69482)
TUNDRA STOCK WHEELS (general info):
2003-2006:
16" wheels - Width: 7", Offset: +15mm, Backspacing: 4.5", Hub Bore Diameter = 106mm
17" wheels - Width: 7.5", Offset: +18mm, Backspacing: 5", Hub Bore Diameter = 106mm
http://www.hubcaphaven.com/tacoma_wheels.htm
Visual offset calc:
http://www.rimsntires.com/specspro.jsp
Old 03-02-2014, 06:11 AM   #193
I measured a 2 lb difference between my aluminum off road wheels and the steel spare. 2nd gen
Old 03-02-2014, 09:00 AM   #194
Banned
davelee94 is on a distinguished road
davelee94's Tacoma Gallery
trying to get this set up.. what offset and backspace do you think this is??? its 35s with 20 inch wheels, what kind offset and backspacing though?
Old 03-19-2014, 04:29 PM   #196
stattonmw has a brilliant futurestattonmw has a brilliant futurestattonmw has a brilliant futurestattonmw has a brilliant futurestattonmw has a brilliant futurestattonmw has a brilliant futurestattonmw has a brilliant futurestattonmw has a brilliant futurestattonmw has a brilliant futurestattonmw has a brilliant futurestattonmw has a brilliant future
stattonmw's Avatar
stattonmw's Tacoma Gallery
Originally Posted by BORNWILDGUY View Post
20 x 9 -12 4.5bs
spot on!
Old 03-23-2014, 03:55 PM   #198
Stoltz1 is on a distinguished road
Stoltz1's Tacoma Gallery
I thought the hub bore for 17x7.5 was really 106mm???
Old 03-25-2014, 12:55 PM   #199
attack ships on fire off the shoulder of Orion
OZ-T's Avatar
OZ-T's Tacoma Gallery
So , 17" FJ Cruiser Alloys
Ad says
All rims 17 x 7.5"- offset +15 Bolt pattern 6x139.7mm
Do they stick out 15mm farther than the Tacoma TRD Sport alloys ?
Wheel specs Taco Guy11 Wheels & Tires 6 09-26-2011 03:04 PM
Wheel Specs speedfreek Wheels & Tires 0 06-24-2011 07:04 PM
Help with wheel specs whiteboytoy05 Wheels & Tires 3 04-14-2011 12:09 PM
What wheel specs? SuperWhiteTaco Wheels & Tires 4 02-07-2011 01:23 AM
someone knowledgable on wheel specs HELP!!!!!!! Detective_Dan Wheels & Tires 20 01-05-2011 03:05 PM
