Wheel Specs
Discussion in 'Wheels & Tires' started by replica9000, Mar 18, 2009.
  1. Nov 9, 2012 at 8:40 AM
    #121
    joyotaco
    joyotaco Tenderfoot
    Ken
    Ann Arbor, MI
    98 2.4L 2wd
    Removable ladder/sailboat rack, Pioneer DEH-6400BT, clear bumper signals
    I got so excited to see this thread only to find out my truck's specs weren't here. :( I'm sure my breed of Tacoma's specs aren't in as high demand as 2nd gens, but since I've had a devil of a time trying to find this information, I just went ahead and took some of my own measurements off my stock '98. Here ya go.
    95-00 Base 2wd steel wheels: 14x6, 5.04" backspacing (128mm), hub center bore 67.1mm, 5x4.5"/114.3mm lug pattern. I calculated offset to be between +37mm and +40mm.
    OEM Tire size: 195/75 R14, but my truck has 205/70 R14s on it now.
    If you want to know how I came up with the calculated offset, read on.
    I didn't have the exact offset specs but based on my measurements and making a reasonable assumption (based off of CAD drawings I've seen for Ford and Toyota rims) that the wheel's bead rim is 12-14mm wide, here's what I came up with.
    6"/2 = 3" * 25.4 (to convert to mm) = 76.2mm
    76.2mm + 12mm (for the bead rim) = 88.2mm or 76.2 + 14mm = 90.2
    backspacing - distance from outer edge of rim to the centerline = Offset
    So, 128mm - 88.2mm = 39.8mm or 128mm - 90.2mm = 37.8mm
    Measuring the hub in mm
    Measuring the backspacing using the two straight-edge method.
  2. Dec 30, 2012 at 6:25 PM
    #122
    jermoids
    jermoids Well-Known Member
    Jeremy
    Winnipeg, Manitoba, Canada
    2021 TRD Sport
    17x9 Fuel Mavericks +1 offset 265/65/17 duratracs NFAB Epyx step sides AVS hood protector Thule xsporter pro rack Weathertech floor liners Tacoma rubber bed mat
    does anyone know how accurate these specs are for a 2012 trd sport?
    TRD Sport Alloy Wheels: 17x7.5, +30 mm offset, 5.5" backspacing, 6x5.5" bolt pattern, 108 mm hub bore, ? lbs
    i thought the bore was 106mm? i'm guessing things have changed a little since this thread was started?
  3. Jan 6, 2013 at 12:53 PM
    #123
    Fightman80
    Fightman80 Well-Known Member
    Capreol Ontario Canada
    05 TRD DCLB Speedway Blue
    Tinted Tail lights, Nerb Bars, Tonneau Cover, Vent Visors, Hood Deflector, Foglight/highbeam mod, Custom homemade grill, Carbon Fibre Interior.
    Does this mean that I CAN"T run a 9.5" wide wheel???
  4. Jan 6, 2013 at 3:12 PM
    #124
    TexasTacoma37
    It does not.
    What is the backspacing of the 9.5" wheel you want, what size tires are you going to run, how much lift do you have, and how much trimming and chopping are you willing to do?
    It's all a case by case basis.
  5. Jan 7, 2013 at 4:59 AM
    #125
    Fightman80
    I plan on running a 3" Skyjacker lift, 285/70/17.... Butt don't know the back spacing, as they are a Nissan Rim. They came with low profile tires, but I tossed them, and will more than than likely run a wheel spacer, because I want them to stick out about an inch and a half. I don't mind trimming, but don't want it to be noticeAble.
  6. Jan 7, 2013 at 10:49 AM
    #126
    replica9000
    replica9000 [OP] Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I'm running 305/60's on a 18x9 0 offset rim with a 3" lift. They stick out maybe 1/2" to 1" from the fenders. I had to trim most of the mudflap, some of the inner fender flare, and some of the body mount. Not horribly noticeable.
  7. Jan 9, 2013 at 1:15 AM
    #127
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    The hub bore is still 106mm and the wheel weights approx. 25lbs.
  8. Jan 27, 2013 at 7:54 AM
    #128
    Adi
    Adi Active Member
    Adi
    Iowa
    2010 DCLB
    Black Sand Pearl
    I'm ready to pull a trigger on some new wheels just wanted some confirmation that they would fit fine. The wheel is 17x8.5, -12mm offset, which puts it at a 4.25" backspace. I'm planning on running 265/70/17 (32") ???
  9. Jan 27, 2013 at 8:10 AM
    #129
    TexasTacoma37
    I'd expect a small amount of trimming.
  10. Jan 27, 2013 at 10:12 AM
    #130
    jermoids
    Jeremy
    2021 TRD Sport
    i just put on my new wheels, 17x8.5 0 offset and around 4.88 backspace and same size tires. had to remove that weird little mud flap in front of the front tire and still have to trim a bit of the front mud flap, probably just a little where it bulges out in front of the cab mount.
  11. Jan 27, 2013 at 10:44 AM
    #131
    Adi
    Adi Active Member
    Adi
    Iowa
    2010 DCLB
    Black Sand Pearl
    Trimming? hmmm I do have a 3" toytec spacer lift which i'm also replacing with a 2.5" OME setup. Sorry i didn't mention that. I'm planning on running the bfg's 265/70/17 C-rated, althou tempted to go 275/17/70 but E-rated might be a bit much for a Taco. ???
  12. Jan 27, 2013 at 10:48 AM
    #132
    Adi
    Adi Active Member
    Adi
    Iowa
    2010 DCLB
    Black Sand Pearl
    Do you have a lift and where did you find those mk19 one of my favorite wheels they look amazing
  13. Jan 27, 2013 at 12:23 PM
    #133
    TexasTacoma37
    With the lift you should be fine with the 265s or the 275s. Minor trimming if any.
    I would say E rated is definitely overkill
  14. Jan 27, 2013 at 3:31 PM
    #134
    jermoids
    Jeremy
    2021 TRD Sport
    thanks, i have 5100's at 1.75" up front and 1" readylift blocks in the back.
    i wanted them because there aren't a lot of people out there with them, and i think they're awesome looking of course.
    http://mrwheeldeal.com/b/ is where i got them and had a great experience with steve there.
  15. Jan 27, 2013 at 4:13 PM
    #135
    Adi
    Adi Active Member
    Adi
    Iowa
    2010 DCLB
    Black Sand Pearl
    Sweet i have spent the whole day doing some final research on wheels and tires and actually ended up emailing mr.wheel and have him shoot me a price. I'm thinking those M19 in 18" and same size tires as KPT, Toyo Open Country AT/2 C-6ply. We'll see what kind of price i get on em. Thanks for the response.
  16. Jan 27, 2013 at 5:13 PM
    #136
    jermoids
    Jeremy
    2021 TRD Sport
    you're welcome, good luck, hope he gets you a sweet quote. also, i lurked around online to find the lowest price possible on those wheels, sent him the link and he beat it.
  17. Jan 28, 2013 at 8:16 AM
    #137
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    Are these 15" or 16" wheels? I thought this style of steel wheel was 16". They are listed as 15", but I also thought 6 lug Tacomas come only with 16", 17" or 18" wheels and not 15". Thanks.
  18. Jan 28, 2013 at 8:19 AM
    #138
    TexasTacoma37
    16x7
  19. Jan 28, 2013 at 9:21 AM
    #139
    kryten
    Canada
    Perfect, thanks.
  20. Jan 28, 2013 at 10:19 AM
    #140
    tstege
    tstege Well-Known Member
    tyler
    Los Angeles
    2000 3.4 4x4 5spd
    sleeping platform-six pac utility shell
    Hey guys I tried to fing this but may e it's so common sense it's not listed. Ihabe a line on some 17" and some tires a guy was running on his second gen w/ 31x10.5 and I am running 31x10.5 R15 currently. Can I swap to a bigger rim or does that involve brake and other issues? Thanks Tyler
