Tacoma World Forums mjp2's 2006 Tacoma
Register Site Information Glossary Calendar Search Today's Posts Mark Forums Read
is a 3" revtek lift with a 285/75/16 on stock wheels possibile without rubbing??
Old 10-04-2007, 09:38 PM   #1
redline929_e is on a distinguished road
redline929_e's Tacoma Gallery
i would like to us 285/75/16's on my stock trd wheels with a revtek 3" lift. i understand there is still some rubbing with wheels that have 4.5" backspacing but only when turned all the way and hitting a bump pretty hard. will i have to remove the oem mudflaps?? fender trimming?? or use wheel spacers?? if it does rub will it be on the frame?? a-arm?? or just on the outside inner fender?? any help will be much appreciated. thank you!!
Old 10-04-2007, 10:27 PM   #2
jmurf21 is on a distinguished road
jmurf21's Tacoma Gallery
im not quite sure with that size wheel........does anyone know if the 285/70/17 would rub? that might be a better fit, but im not sure
Old 10-05-2007, 01:22 AM   #3
toco389 is on a distinguished road
toco389's Tacoma Gallery
wow lol you must be looking for the same look i was! i have the 3" revtek lift with 285x75x16 and they sometime rub when turned locked. yet all i had to do was very minor trimmimg to the inner fender well (just plastics) it clears them nicely
Old 10-22-2007, 10:26 PM   #4
well i did it! i used the revtek 3" lift and stock wheels with pro comp extreme mt's in a 285/75/16. i had to use a 1/4 inch wheel spacer because the tires were only about an 8th of an inch away from the a-arm. now they only rub when turned all the way on the upper a-arm but only on the side wall of the tire and very little.
Old 10-22-2007, 10:28 PM   #5
by the way i got to keep my mudflaps,did not have to trim anything and do not have any rubbing when turning and hitting a bump at the same time!
Old 10-23-2007, 11:04 AM   #6
nd nd is offline
AKA: "The Velour Fog"
nd is infamous around these partsnd is infamous around these partsnd is infamous around these partsnd is infamous around these partsnd is infamous around these partsnd is infamous around these partsnd is infamous around these partsnd is infamous around these partsnd is infamous around these partsnd is infamous around these partsnd is infamous around these parts
nd's Avatar
Gender: Female
nd's Tacoma Gallery
you need to post some pics, i'd love to see your setup
__________________
When life gives you lemons, just say 'Fuck the lemons,' and bail.
Display Modes
3" REVTEk LIFT KIT NEW IRISHDEVIL Buy / Sell / Trade 8 08-19-2008 01:57 AM
Wheel Spacer for 2007 with 3" lift and stock rims hawkdrvr Wheels & Tires 1 11-04-2007 11:41 PM
tires for stock wheels with 3 inch lift?? redline929_e Wheels & Tires 2 08-01-2007 03:44 PM
3" Revtek Lift Question Godfish Suspension 2 07-27-2007 08:48 PM
Stock 15" Wheels to OEM 16"? EvilBetty Wheels & Tires 7 06-02-2007 12:09 AM
Copyright © 2008 Tacoma Forum
