New tires, new problem..
Discussion in 'Wheels & Tires' started by Lost Bushman, Jul 30, 2014.
  1. Jul 30, 2014 at 9:42 AM
    Lost Bushman
    Lost Bushman [OP] Member
    Arizona
    2015 TRD Offroad
    Stone Soup Metalworks sliders
    So...
    I went from 265/70-16's Toyo Open Country's up to 265/75-16 BFG AT's, I experienced no rubbing with the Toyo's but the BFG's are rubbing the UCA and LCA, BUT ONLY ON THE DRIVER'S SIDE. I'm also experiencing a gentle rolling vibration from that side, but only intermittently. Also didn't happen before the tire swap. I bought them new from a reputable shop...
    What's going on here? :confused:
    My truck is an '05 DC TRD Offroad, if that matters.
    THANKS!!!!!
  2. Jul 30, 2014 at 9:47 AM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    That's really odd considering they should be the same width as the Toyos. Pictures?
  3. Jul 30, 2014 at 10:43 AM
    Lost Bushman
    Arizona
    2015 TRD Offroad
    That's what I thought. I'll get some when I get home.
  4. Jul 30, 2014 at 12:48 PM
    karmatp
    karmatp Well-Known Member
    Trevor
    Chandler, AZ
    2016 4x4 4Runner
    Weird. I am running 265/75/16's on my 14 with rims that have 4.5 backspacing and they are close but do not rub at all. I had tons of room with the OEM rims, but with the tire pushed out a tad more, I am really close in the upper part of the front flaps.
  5. Jul 30, 2014 at 1:08 PM
    Lost Bushman
    Arizona
    2015 TRD Offroad
    I snapped these real quick....
    Driver's LCA
    Driver's UCA
    Passengers LCA
    Passengers UCA
  6. Aug 11, 2014 at 8:23 AM
    EastTx
    EastTx Well-Known Member
    Texas
    2017 Super White DCSB TRD OffRoad 4x4
    Width is the same. The BFG is an inch taller. Guessing that's causing the rubbing problem.
  7. Aug 11, 2014 at 8:29 AM
    TacoREX
    TacoREX -TacoREX
    Evan
    NORCAL
    01 Taco 2.7 5spd
    2.5" lift, 285's, CB, DIY HiLift Bed Mount, AllPro Sliders,Warn
    Might want to try swapping wheel/tires, left - right, vice-versa. It may be a tire issue. Sometimes there are inherent defects from the factory. Also might be a good idea to double check width with a tape measure on the tread pattern and also from the frame to the WMS and compare left - right.
