255/75 on Stealth 6/SR8
Discussion in 'Wheels & Tires' started by backcountryj, Oct 13, 2014.
  1. Oct 13, 2014 at 1:26 PM
    backcountryj
    backcountryj [OP] Pending Approval
    Jonathan
    GA
    Is anyone running a 255/75/17 on the SCS Stealth 6 or SR8? I'm not a fan of the pizza cutter look but the weight savings on a slightly taller tire could make them worth while.
    I'm curious to know/see if mounting that size tire on an 8.5" wide wheel would reduce the narrow-ish appearance without looking too out of proportion.
  2. Oct 13, 2014 at 2:31 PM
    Darryle
    Darryle It is just a truck
    Darryle
    Weatherford, Texas
    I run the 245/75 Michelin LTX M/S 2, I gained 2 mpg average. They don't look all that different from the original 265/70, The weight is why I chose them.
    How much different is the weight on the 255 vs the 265?
  3. Oct 13, 2014 at 3:57 PM
    backcountryj
    Jonathan
    GA
    Depends on the tire obviously. I currently run Cooper AT3s in 265/70. They weigh 41lbs according to TreadDepot. They list the AT3s in 255/75 to be 38lbs.
  4. Oct 17, 2014 at 5:17 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Just for reference, here's 255/80/17.
    4F24392D-9DBB-48F6-9227-3729DE8D43B4_zps_3fffad2e03858d6010a1f47723afeba4390d0809.jpg
    7D257461-ABA5-4527-A330-79E1D38FE9CB_zps_906ef59e4eabec174acb6710a8a01b03e14d0109.jpg
  5. Oct 18, 2014 at 8:07 AM
    backcountryj
    Jonathan
    GA
    Thanks for posting the pics Vin. Do you know if the truck pictured is running spacers?
  6. Oct 18, 2014 at 1:42 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    No spacers, but note that this truck doesn't have fender flares.
  7. Oct 18, 2014 at 4:35 PM
    backcountryj
    Jonathan
    GA
    Gotcha. That definitely makes for an 'extra' wide stance appearance.
  8. Apr 14, 2015 at 5:14 AM
    redletter
    redletter Member
    Joe
    Western, MD
    '13 Tacoma
    Vin, any idea what the largest aspect ratio for 255/ is that would work with stock DCSB OR and SR8
  9. Apr 14, 2015 at 2:32 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    On a 17" SR8, you could run a 255/75/17 which is a 32" tall tire. On that white reg. cab Tacoma, he was able to run 255/80/17 at stock height and not rub for daily driving with the fender liner removed.
  10. Jul 13, 2019 at 4:27 AM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    do you think a 255/75/17 with my SR8's would be fine on my 2017 Pro,, looking at some firestones destinations at's,, thanks
  11. Jul 13, 2019 at 4:35 AM
    backcountryj
    Jonathan
    GA
    Yes
