Pro Comp 5001
Old 10-15-2014, 03:47 AM   #1
blueline6729 is on a distinguished road
Law Enforcement:
blueline6729's Tacoma Gallery
Pro Comp 5001
I am looking for some new wheels on my 2014 prerunner. I have looked for days for an answer but have not been able to find exactly what I'm looking for. Everything is stock including steel wheels. I am wanting to upgrade but leave the stock tires on. They are 245/75/16. I have been looking at the procomp 5001 16x8. Will these work with everything else being stock. I don't want to have to lift or cut anything. Just wanting a nicer look on my truck. I have black predator bars and a black bull bar. Just want some black wheels to go with it. Any help is appreciated.
Old 10-15-2014, 06:32 AM   #2
Darryle is one of the sharper tools in the shedDarryle is one of the sharper tools in the shedDarryle is one of the sharper tools in the shedDarryle is one of the sharper tools in the shedDarryle is one of the sharper tools in the shedDarryle is one of the sharper tools in the shedDarryle is one of the sharper tools in the shedDarryle is one of the sharper tools in the shedDarryle is one of the sharper tools in the shedDarryle is one of the sharper tools in the shedDarryle is one of the sharper tools in the shed
Darryle's Avatar
Darryle's Tacoma Gallery
As long as the backspacing works out the same, you should be golden.
Do you have the specs on the wheel you're wanting? Have you called 4 Wheel Parts or tried looking up the wheel on Tire Rack?
Old 10-15-2014, 06:57 AM   #3
Law Enforcement:
The specs on the wheel I'm wanting is 16x8 with 0 offset. I have spoken with several different wheel dealers. Some say I need a +15 offset some say 0 is fine. That's where I'm getting confused.
Old 10-15-2014, 07:07 AM   #4
Law Enforcement:
The exact wheel I like is the pro comp 5001. It's a 16x8 0 mm offset. 4.5 backspacing.
Old 10-15-2014, 10:08 AM   #5
Darryle's Avatar
Check out this site, if your current wheel is 15mm offset, then a 0mm offset is moved out by 1/2" approximately.
See What Fits
Fs: pro comp 2.5" rear lift block with u-bolts, pro comp 1.5" rear add a leaf slodc4 2nd Gen Tacoma Marketplace 15 06-24-2014 08:14 PM
Pro Comp 5001 fitment & lug nuts Slizzy Wheels & Tires 1 11-21-2013 10:46 AM
any 2nd gen tacomas with 17" pro comp 5001 wheels. post pics please itzyoboipaul 2nd Gen. Tacomas 3 10-28-2013 07:56 PM
Pics of Pro Comp 5001's installed? Justin626 Wheels & Tires 1 08-06-2013 07:00 AM
pro comp extended lug nuts(needed to run pro comp rims)-$35 marintacoma Wheels & Tires Marketplace 0 11-26-2012 04:39 PM
