Help! Did my 17x9 wheel decision come back to bite me?
Discussion in 'Wheels & Tires' started by STLTaco09, Jun 16, 2009.
  1. Jun 16, 2009 at 5:28 PM
    STLTaco09
    STLTaco09 [OP] Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    I did a TON of research before getting my 17x9 moto metal 951B's (4.5" B.S.). I really wanted these, and from what I could tell, there were no really pros or cons to going with an 8" wide rim opposed to a 9" wide rim (and the 951s aren't available in 17x8). I come to find out that tire mounting choices are a bit limited in 265/70/17 on a 9" rim. OK, I'll live with that.
    What issues did I create for myself if I decide to go with 285's in the future? Am I going to have more rubbing than I would have had with 17x8? Does a 17x8 rim make the side wall look better than a 17x9? It seems some have frame rubbing issues, etc.
    Just curious on the input. Is this really a non-issue?
  2. Jun 16, 2009 at 8:59 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    don't hold me accountable here but i have the moto metal 951b's and they are great. but i do think you will have more rubbing issues with a 9" wide wheel over an 8" wide wheel. most 285's have a maximum wheel width of 9" so if you want that "bubble look" you are going to have to look a little harder. if i had it to do over again, personally, i'd find an 8" wide wheel. but i'm perfectly content with the 951's, they are great looking wheels.
  3. Jun 16, 2009 at 9:05 PM
    TEX357
    TEX357 TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    I bought mine 17x8 because I was told i would rub the UCAs with the 17x9 Wheel
  4. Jun 16, 2009 at 10:33 PM
    Tacomaui
    Tacomaui Well-Known Member
    Middle of the Pacific Maui, Hawaii
    2007 TRD Double cab 4x4
    3" Revtek kit, , Wet Okole seat covers. Now with 285/70/17 BFG all terains on Moto Metal 955 17x9 chrome wheels. Tube steps, Tinted windows. Used to have 265/70/17 BFG all terrains on Mickey Thompson Classic Bead lock wheels,
    Mine with 285/70/17's on MotoMetal 955's. Some trimming needed to be done. Mainly that knob that sticks down on the front side of the fender liner and about 1/2 inch of the fender flare on the lower front inside edge. Also neede to remove front mud flaps. I have no rubbing at all now. But I dont do any off roading wit it either.
  5. Jun 17, 2009 at 2:13 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    I have 265/70/17 on 17x9 MotoMetal 957b and that is where mine rub also, but my rubbing is mostly when the suspension is being compressed like over bumps, driveway etc. I run Nitto Terra Grappler's which fit up to a 9" rim, they look normal to me. I don't know about the 285 issues though.
  6. Jun 17, 2009 at 10:06 AM
    STLTaco09
    Now I remember why I got 17x9 wheels. There are no 17x8 wheels that I like... Everything is a compromise.
    Seems that 17x9 is no big deal. Thanks to pics from FoxySandChick of her tire/wheel setup.
    Thanks again.
  7. Jun 18, 2009 at 6:44 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    Can you post some pictures of your set up from a head on angle? And from the rear? I'm thinking about a 275 on 18x9 set up, hopping that going one size thinner will help keep the tires from sticking out too much. But I'm concerned about the width of the rim also... Why can't moto metal make 18x8's:mad:
  8. Jun 19, 2009 at 4:13 AM
    FoxySandChick
    Kristin
    Henderson, NV
    I don't have the best pics of my set-up, but I'll give you what I have at the moment. Mine do stick out pretty far, maybe 2inches I'd guess.
    Basically the 1st row of thread is how far it sticks out from the bottom edges of the fenders. I don't have mud flaps on and I don't have an issue with rocks chipping the paint behind the tires, I have more chips on my hood...if that is your concern. I love the way it looks with the wider stance.
    I'm not sure that a thinner tire would keep it from sticking out, I think that is more about the offset of the rim and also the width of the rim...maybe someone else can clarify that??
    275/65/18 are approved for the 9" rim but 275/70/18 are only approved for 8.5" with the Nitto TG.
  9. Jun 19, 2009 at 11:27 AM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    In the Procomp 7089 17x9 -6offset 4.75bs, that's too much backspacing, that's why you had to go with the 17x8 0 offset 4.5bs.
    I just had my new tires/wheels installed Wednesday and they are 17x9, 4.53bs -12offset xd revolvers. 4WP even trimmed it for me cutting off that little bump hanging from the fender and other minor wheel well covering. No rubbing at all with 285/70/17 when at full turn L or R. Haven't gone offroading yet, but the street stance is awesome. Pics coming this weekend.
  10. Jun 20, 2009 at 4:38 AM
    FoxySandChick
    Kristin
    Henderson, NV
    Looking forward to pics, could you possibly take a pic of the area they trimmed. I have to do the same, cut off the bump, and I'd like to see how they did it.
  11. Jun 21, 2009 at 1:14 PM
    STLTaco09
    So I got new shoes installed. I was at the local Firestone getting new tires on our Solara, and I got into a discussion about the Tacoma and about how I was going to go to NTB to get the Terra Grapplers installed. After a good bit of discussion (negotiation), they said they'd give me 4 Bridgestone Dueler A/T Revos 265/70/17 installed with road hazard for the same price as NTB would give me for the Nitto's, $685. Thats OUT THE DOOR. This is LITERALLY a deal I couldn't pass, so I jumped on it.
    Now, we've given this firestone about 100,000 miles worth of maintenance work on our Solara, and they've worked with us ever step of the way. Plain and simple, he said he wanted my business. Well, he got it!.
    I'll post pics eventually. But my initial impression is that they are definitely aggessive looking (which was my concern based of pics I've seen of the tire).
    As FoxySandChick along with someone else mentioned, I do get a small amount of rubbing on a nub on the front mud flaps when turning. It's not full lock, maybe half or so. I'm curious on what has been done to fix this besides removing the front mud flap. How much was ground down? Was it all mud flap material or also fender material? Its not really bothering me that much, it'll probably go away in a few thousand miles, but its still something I'd be interested in hearing.
  12. Jun 21, 2009 at 10:37 PM
    Simon2150
    Austin, TX
    Here are some pics. I have more, but hopefully this will do for now.
    Passenger front tire
    Driver Front
  13. Jun 22, 2009 at 4:52 AM
    STLTaco09
    If you've got any pics of the actual bump or the area that was trimmed, that would be appreciated.
    Thanks.
  14. Jun 22, 2009 at 6:47 AM
    Simon2150
    Austin, TX
    Sorry, I didn't get a pic of what they trimmed, just what they look like now. You can go out and look at yours for comparison though.
  15. Jun 22, 2009 at 7:27 AM
    STLTaco09
    I was under the impression that your mudflap was what was trimmed. Those pictures don't show your mud flap. Sorry, maybe I misunderstood.
  16. Jun 22, 2009 at 10:15 AM
    Simon2150
    Austin, TX
    I took off my front flaps and just left the rears as is. sorry for the confusion
  17. Jun 23, 2009 at 2:06 AM
    FoxySandChick
    Kristin
    Henderson, NV
    http://www.tacomaworld.com/forum/wheels-tires/41969-brilliant-minds-unite-please.html
    In this thread, his 4th pic down, the part he has marked in the square...the outer corner of that knob is where mine rub on full turn. I'm just going to cut that entire piece off straight across. Then I will see if the tire is also hitting the inner corner of the fender flare and trim or file if needed, it doesn't look like I will have to though.
    I took all my mud flaps off before I got these tires, I don't have any rubbing where the flaps were.
    Simon2150-thanks for the pics, looks good. I don't think I'll have to trim as much as yours.
    STLTaco09- Congrats on the deal, post some pics :D. My bf has duelers on his Z71, they seem to have held up well for him.
  18. Jun 23, 2009 at 6:33 AM
    STLTaco09
    Here are the new shoes:
    I did have some rubbing of the mud flaps. I didn't want to take them off though as to protect the paint on the doors a bit. I trimmed the fronts so they weren't so long, and I cut the nub off where it rubbed at about 1/2 lock (and only sometimes), noted by the number 1 in the picture. I also snipped a piece of the fender flare which was under the nub (1 in pic) on the modflap.
    The number 2 in the picture is where it also sometimes rubs at full lock, but I felt that trimming this would significantly weaken the mud flap. I'll live with this rubbing as it is pretty minimal.
  19. Jun 23, 2009 at 7:35 AM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    I went through your posts and see that you have the TSB springs but do you have the 5100's installed? If so, what setting? I just ordered the same setup over the weekend and probably wouldn't have if I had seen your latest pics. They look okay but it's pretty clear that a 9" rim should have a larger tire on it. Oh well! If there is a good side to this, at least the tread appears to be under the flares. Good luck with yours.
  20. Jun 23, 2009 at 7:48 AM
    STLTaco09
    I dont have the 5100's installed, but yes, the TSB springs are on there. The tread is definitely under the flares too. It looks aggressive for sure, and I got a lot of compliments about it when I got the tires put on (3 people were in the Firestone parking lot standing around complimenting me on the truck).
    It sucks about the pictures, they really don't do it justice. Like FoxySandChick mentioned, it looks fine. And to add to that, it looks a lot better in person, especially with the 265/70/17 opposed to the 265/65/17. The larger side wall helps. I dont think it looks bad at all. I was nervous about my 17x9 wheel purchase, but after looking around again, I can't find any 17x8 wheels that I like. So I'm definitely happy with this setup.
