Wash rims well, both inside and out, rinse with clean water, dry with towel
* Tire Finding Tools | Thread Tools | Search this Thread | Display Modes |
#1 |
Make mine a Double!
Painting Stock Rims Easy
#2 |
Make mine a Double!
#3 |
How many words can be fit in this s
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Name: Jonathan
__________________
MY BUILD http://www.tacomaworld.com/forum/2nd...ner-build.html Waitress: What can I get you? Me: I'll have the ultimate scramble please. Waitress: How would you like your eggs? ryanjboutin: The gayest way possible. |
#4 |
Make mine a Double!
#5 |
Make mine a Double!
yes - i am not using any primer. Scuffing the original factory paint ( its not coming off ) is a better acting primer than anything else i could spray on. spray the inside of the rim first ( no picture ), one good coat. then flip rim/tire over. insert playing cards / index cards. start by painting through the holes to get into the inside of rim. then paint the outside of rim working from the outside edge in, yes i walked around the tire as i went along, nice easy thin wet coat, you dont want drips. allow to dry for about 5 mins, apply 2nd easy coat. i used a semi-gloss black, rustolium spray paint can. one can did two rims. |
#6 |
Go with the flow
i kept my wheels on and just spray painted them. figure the paint will eventually chip so i can always just spray over. but good write up though
__________________
#7 |
Make mine a Double!
#8 |
Make mine a Double!
#9 |
Make mine a Double!
#10 |
Ability is a poor man's wealth.
Nice!!!!
#11 |
Murdered X
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Name: Brett
The index cards make it so easy... I used them when i painted the rims on my X before i p/c'ed them..
Nice write up.. |
#12 |
UG legend wannabe
nice write up, not trying to give ya a hard time but there is a write-up on this already that i looked at a few weeks ago, same methods and everything.
still tho, good detail and write-up |
#13 |
Bear Down!
Looks great! Nice job!
__________________
#14 |
Those look like the first gen rims.... are they?
__________________
#15 |
What's the matter, Colonel Sandurz? CHICKEN?
looks good!
__________________
#16 |
Make mine a Double!
2009 stock sr5 steel 16 inch rims
#17 |
__________________
#18 |
Make mine a Double!
original 2009 stock sr5 16 inch steel rims
i have seen other threads , did use the card trick, but they seem over complicated and unesassary. all i used was some scotch brite and a couple cans of spray paint. as long a you scuff the original paint enough, it better than primer. |
#19 |
Senior Arshole
Shoulda put the weights back on but on the inside of the rim. That's where mine are....
#20 |
Senior Arshole
oh yeah, still looks SICK!
| Display Modes | |
| Painting stock rims! | Hurley0568 | Wheels & Tires | 24 | 03-20-2012 05:56 PM |
| painting stock rims? | NACooner | Wheels & Tires | 5 | 08-01-2011 10:44 PM |
| painting stock rims | austinstaco | Wheels & Tires | 3 | 09-30-2010 06:50 PM |
| Help:Painting my Stock Rims | Rizzz818 | Wheels & Tires | 7 | 10-17-2009 01:34 PM |
| painting stock rims | socal19 | 1st Gen. Tacomas | 2 | 08-27-2009 09:07 AM |
