* Tire Finding Tools | Thread Tools | Search this Thread | Display Modes |
#21 |
There should be no diff between mine and yours. I went with the 265 70 16s on mine and they look good. From what most of the guys have said on here that is as big unless you get a lift. yours may have 17s but same theory 265 75 17 or 265 70 17. There is a bunch of things on here about tires but I think this to be true. I think they look real good on the truck
#22 | |
Pill it till you kill it!
-265/75-16 -265/70-17 Lol either way, it will look a lot better then the 245's!
__________________
#23 |
Search you fools!!
I was just playing around with sizes for the hell of it.
Anyone try a wider tire but not necessarily taller (TRD Sport wheel/no lift)? Say for instance: 285/65/17 = 31.6"/11.2" 275/70/17 = 32.2"/10.8" Just curious.... was looking for something a little wider but not necessarily taller. But then again, my tire choices are probably limited eh? Just dreaming of what's to come....I'll probably need tires before next winter.
__________________
Our Homepage http://www.lieblweb.com/ My truck photo gallery http://www.lieblweb.com/cpg/thumbnails.php?album=16 I know I'm in my own little world, but it's ok, They know me here. 2007 Toyota Tacoma 2006 Acura MDX 2001 Chevy Corvette |
#24 |
Taco Rookie
Tire fitment on my 2010 Tacoma
Hey guys new to tacomaworld, i would really appreciate your help/advice/knowledge of the tacoma. Im having trouble with tire fitment, I have a 2010 tacoma double cab long bed Non Trd Stock. I bought some 20" moto metal 951 rims and i know for sure 265/50/20 will fit. But i am getting an awesome deal on yokohama parada tires 285/50/20 but i am unsure they will fit/rub. I dont plan on lifting the truck since i didnt get the offroad package(my mistake) and dont see the point of lifting a 2wd truck, but maybe i will. But oh well whats done is done, I just want to know if it'll fit with my stock suspension, i dont even have bilstein shocks, just the plainest tacoma.
#25 | |
just totaled the Xterra
If you are in fact concerned about inaccuracies in your speedo, there's a computer you can buy that does the conversion for you before the speedo/scangauge. I had a scangauge in my Xterra, but totaled it last weekend, now i'm looking into a 2010 Taco |
#26 | |
Search you fools!!
The Scangauge II can adjust for different tire sizes and give you a readout of the actual (or close to) speed. Here is the scangauge manual - scroll down to page 16 (MORE/SETUP/SPEED) http://www.pureenergysystems.com/sto...SGIIManual.pdf The calculated Scangauge read-out does not change the ECU data and does not change the speedometer needle. It's best to get a GPS and test the actual speed from the GPS to the needle and the Scangauge data after you put different tires on.
__________________
#28 | |
Legend in my own mind
My buddy has 275/60/17 on his 07 Tacoma 4x4 = wider and lower profile with no rubbing on the stock wheels and suspension. His truck sits lower than mine though with his current set up, which may or may not be a bad thing depending on what you are looking to achieve. I personally don't really like it myself. I prefer taller with the same width.
__________________
K&N Intake - Magnaflow Catback w/Dual Tips - Trinet Motorsports Front Rotors w Ceramic Pads - - TSB AAL - Alpine CDA-9886 w TacoTunes Dash Kit/ Pioneer TSA-1673R 6.5 x 4 w TacoTunes Mounts - TRD Seat Covers - WeatherTech Floor Liners - Xenon Lights and Fogs - Sockmonkey Bed Decals - Tailgate Pop N Lock - Stant Locking Gas Cap - 265/70/17 Nitto Terra Grapplers - ReadyRamp Bed Extender |
#29 | |
Search you fools!!
I just wanted to keep it atleast stock height (or maybe slightly taller) and a little wider and still fit under the stock suspension. Hmmm.... The 285/65/R17 looks decent. I used to run 32x11.50's on my 96 tacoma on stock 15x7 rims. The 11.50's were (technically) too wide for that rim, so I ran lower tire pressure. With 7.5" rim and 11.2" - wondering if that'll work/fit. I'll have to do some research. But then again, I'm limited to tires. Booooooo
__________________
#30 |
Just put on some Bridgestone Deuler AT in 265/70/17. That is how the stock truck should look!!! Very happy.. Costco went ahead with a "test fit" to see if it would clear before mounting (because I went up from the 65s). Took them 3 1/2 hours to get it done, but happy that I could get it done with them (price and free balance/rotate)
Now for a small lift via 5100's.. and I'll be good to go.. |
#31 | |
#32 |
Banned
265/70 is the biggest WITHOUT a lift. With a 3" lift you can stuff 285/70 AT tires; 265/70 MT tires.
when you get new UCAs you can stuff a 285/70 MT tire **** |
#33 |
#34 |
#35 |
#36 |
No rubbing at all.. gave the truck a very small ~1" or so lift as well..
No.. not the revo 2s..These are the regular ATs They would have had to special order them at Costco.. I do like the look of the revos, (a little more offroad/agressive look), but like the guy said, may have a bit more road noise in the long run.. Gonna put on my "small lift" on friday.. 5100's set at 1.75 and 1.5" fabtch aal.. will have some pics of the 265/70/17s with the lift later.. hope it doesn't look silly.. |
#37 | |
Did you you mount a 265/70/17 on the spare rim ? Did it fit without modification ? Your truck is gonna look great with the lift. Did you already have the TSB done ? Guessing not if you're doing an AAL. |
#38 |
hmmm.. No I didn't do anything to the spare. Figured I could run "crooked" for a small distance from wherever to tire shop.
no TSb. Serial # wasn't covered when I checked earlier.. Now over miles anyway.. I sit about 1-1.5 higher in rear with snugtop shell. |
#39 | |
But I could be of base. Hopefully someone who is smarter than me can chime in. |
#40 | |
Banned
But It wont hurt it that much because you'll only be driving to get somewhere quick |
| Products Discussed in this Thread |
| Display Modes | |
| biggest A/T tires for my 07 TRD Sport | haivan | Wheels & Tires | 15 | 05-20-2013 08:26 PM |
| TRD Sport 17' rims and biggest Tires | TacoAngler | Wheels & Tires | 9 | 01-03-2011 09:04 PM |
| Tire help on 07 Sport 4x4 | off road yota | Wheels & Tires | 12 | 06-16-2010 05:11 PM |
| WTB oem tire for 07 tacoma sport | RDAY | Buy / Sell / Trade | 1 | 05-24-2009 07:55 AM |
| Tire advice for stock TRD Sport 07 | jedvf114 | Wheels & Tires | 10 | 03-31-2009 05:14 AM |
